[ROM] CyanogenMod 7 für das Milestone (CM7) - Gingerbread
  • 86 Antworten
Changelog:
7.1.0-RC0-11.05.03 (2.3.4)
Android 2.3.4 - lots of fixes (e.g. the RTSP stream playback - Issue 13715 - android - RTSP playback does not work with 2.3 (Tried with Nexus S) - Android - An Open Handset Alliance Project - Google Project Hosting and many others)
- qwertz/qwerty/azerty keyboard can be selected in Settings>CyanogenMod settings>Input>Keyboard layout (no need to change the layout in OR after every update any more for those who don't have euro-qwerty phone)
- backlight animations enabled
- option to display AM/PM clock in status bar
- DSP Manager: equalizer presets
- fail safe: play the default ringtone if the customized one is not available
- ADW catalogs navigation via swipe added
- other fixes
notes:
1. the gtalk voice/video chat needs updated google apps package, which has not been released by CM team yet
2. subversion number (e.g. the last 0.08) is no longer used as no new official kernel updates from Motorola are expected
Downloadlink:
https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC0-11.05.03-Milestone-signed.zip
Google Apps
Latest Version - CyanogenMod Wiki
Reaktionen: Fenri, one6one, MarioOrlando und 9 andere
Changelog:
7.1.0-RC1-11.05.08 (2.3.4)
- ADW fling gesture direction detection fix
- euro-qwerty kb layout selection typo fix, swe-qwerty added
- keep sms/mms & home in memory defaults fix in activity manager
- continuous logging is enabled and redirected to /cache/logger to ease the debugging reports. I'll usually need AOL_main.ap.bin and AOL_kernel.ap.bin files. They can be retrieved by "adb pull /cache/logger".
- various surfaceflinger and other fixes (keyboard open detection on boot, backuptool.sh updated for new gapps etc.)
- note: this version wipes out media database because of the album artist support introduced - you will need need to reassign your custom ringer/notification/alarm sounds again
Downloadlink:
https://github.com/downloads/nadlaba...one-signed.zip
Google Apps:
Reaktionen: prodigy7, MarioOrlando, Christoffer und 4 andere
Reaktionen: MarioOrlando
Changelog:
7.1.0-RC4-11.05.19 (2.3.4)
- main fixes: MMS retrieval, possible dialer crash (in landscape), 3G Mobile Hotspot start failure
- BT audio.conf tweaks (mainly for car BT)
- bionic: ARM optimized strcmp, fixed leaks in DNS threads
- optional incall screen rotation, and more...
Downloadlink:https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC4-11.05.19-Milestone-signed.zip
HOTFIX!!!: I've updated the OR ext2/3/4 updater with tune2fs binary (switch.sh updated as well to install it correctly on OR start).
http://code.google.com/p/cyanogenmod...fs_update2.zip
Google Apps: Latest Version -CyanogenMod Wiki
Reaktionen: doesdroid, loadp, NiceGuy und 8 andere
Reaktionen: Christoffer, MarioOrlando, wuerfel und 4 andere
Reaktionen: Christoffer, MarioOrlando, Sterni und 11 andere
neue Version: cm-7.1.0-RC9-11.06.06
Link: https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC9-11.06.06-Milestone-signed.zip
Changelog:
7.1.0-RC9-11.06.06 (2.3.4)
- "lock home in memory" option is now being suppressed when Camera or GMaps happen to be the front apps to prevent system freezes (sd card read_ahead_kb can be set to 2048 again)
- camcorder: video orientation hint always set to landscape to prevent video distortion during on-device playback
- torch: high brightness mode fixed
- logger re-enabled in the hope for diagnostic logs from users to be posted to issue tracker (the logs can be found in /cache/logger)
- more ergonomic date and time picker, updated translations, etc.
(quelle: http://android.doshaska.net/cm7 )
Reaktionen: FlieWaTüüT, Balu381, MarioOrlando und 2 andere
Reaktionen: Mais, FlieWaTüüT, Balu381 und 13 andere
Changelog:
7.1.0-RC10-11.06.14 (2.3.4)
- DSI-fix kernel module - adds error recovery scheduling (in Droid kernel called from dsi_vc_flush_receive_data function, while this particular call was missing from Milestone kernel). Kernel function hooking in use made by Nothize, hooking source provided to me by Zewelor. Thanks!
(hopefully, you can safely disable the DSI workaround in CM settings>display now)
- 'Incoming call in background' option (Settings>Call settings) - option to inform about incoming call only via notification & ringtone while not leaving the currently active application in foreground, when screen is on
- ro.ringtone_query_wait_time property added, to allow override the max time allowed for getting the customized ringtone for the particular contact that is currently calling, before the fallback to default ringtone. Android default is 500ms. Set to 1500ms in this release.
- 'normal' flashlight brightness fixed
- 'high' brightness option when flashlight is invoked from notification power widget fixed
- selectable 0, 90, 180, 270 orientation options to be enabled or disabled
- Toggle2G included again
- DatePicker fix (FC e.g. in GTasks app)
- etc
Downloadlink: https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC10-11.06.14-Milestone-signed.zip
Reaktionen: Mais, FlieWaTüüT, martin5t und 15 andere
Changelog:
7.1.0-RC11-11.07.06
- camcorder A/V sync fixes
- 3rd party apps LED notification fix
- new native screenshot feature (accessible via power menu)...
- usb status - adb notification fix
- volume key zoom option in camera app now working in steps instead of max/min
- fix aplogd props
- Fix touch-to-focus commit
- delete smali
- reduce the number of vid enc buffers, increase h264 min quantizer
- various fixes
Downloadlink: https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC11-11.07.06-Milestone-signed.zip
Reaktionen: motoroller, Psionman, MarioOrlando und 10 andere
Changelog:
7.1.0-RC11-11.07.10 (2.3.4)
- video recording A/V sync fix when aac encoder is in use - high and wide camcorder profiles
(some backported bits of honeycomb stagefright code are in use now in order to achieve it)
- Location Proxy is now loaded correctly, from separate jar package
(finally, no more after-build framework smali hacks are needed)
- ADW Launcher updated (see official CM 7.1 changelog), optimizations affecting drawer scrolling added
- USB status fixes - adb notifications fixed, better SD card transfer speed when shared via USB
- fix for non-working LED notifications in some third party apps
- possible fix for non-correct custom ringtone played on incoming call (needs confirmation)
- Camera: volume key zoom control option now works in steps instead of min/max switch
- new internal screenshot feature - accessible from power menu
- etc
Downloadlink: https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC11-11.07.10-Milestone-signed.zip
Google Apps: http://wiki.cyanogenmod.com/index.php?title=Latest_Version#Google_Apps
Reaktionen: motoroller, Psionman, trintyjck und 12 andere
Changelog:
7.1.0-RC12-11.07.14 (2.3.4)
- quickfix for non-repeating mp3 ringtones (Phone.apk)
- new 5-point multitouch enforcing kernel module (usually activated by the first screen off/on after boot)
- updated interactive governor kernel module (more mature - backport from 2.6.38 kernel)
- 2 new pixelflinger optimizations (thanks to elektroschmock for the pulls)
Downloadlink: https://github.com/nadlabak/android/downloads#download_112712
Google Apps: http://wiki.cyanogenmod.com/index.ph...on#Google_Apps
Reaktionen: motoroller, Psionman, phiKed und 15 andere
Changelog:
7.1.0-RC13-11.08.14 (2.3.5)
- DSI-fix v2.41 kernel module (w. error recovery), DSI workaround can be finally safely disabled
- Android 2.3.5
- limited Skia memory usage
- providers/contacts running in separate processes (not android.process.acore) to allow their separate management by low memory killer
- faster boot time (app libs are not extracted again every boot)
- Crystal talk
- logger can be enabled/disabled under performance options
- workaround for Google Maps (in Activity Manager code) to prevent GL texture related crashes in PowerVR SGX libs
- plus many more...
Downloadlink: https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC13-11.08.14-Milestone-signed.zip
Google Apps: http://cmw.22aaf3.com/gapps/gapps-gb-20110729-signed.zip
Reaktionen: Aretho, babfe, phiKed und 11 andere
