[ROM] CyanogenMod 6 für das Milestone (CM6) - Froyo
  • 14 Antworten
AleviDroid
AleviDroid
Dauer-User
583
Der neue Release-Thread für CM! Hier wird nur Changelog und Downloadlink gepostet!
Update:
28.01.2011 0.07-11.01.28
- proprietary files update (boot.img=>kernel, modules etc from SHOLS_U2_05.26.0)
- the infamous SMS bugs fixed (the OS version should actually read 2.2.2, sorry, I left 2.2.1 there)
- Greek support added to LatinIME 2.3 (including dictionary)
- ext4 module included (can be used to mount ext2 only - writing to journalled ext3/4 is not working correctly yet)
- new separate BPSW update.zip package (same as in SHOLS_U2_05.26.0/SHLA_U2_05.0C.0)
Downloadlink:
cm-6.1.2-0.07-11.01.28
Source:
android.doshaska.net | Nadlabak's little bits and pieces for Motorola Milestone and Android
Update:
03.02.2011 11.02.03 alpha cm7
main issues - gps (satellite), compass
CM7 is not ready for release yet,
many features are still being worked on.
Remember, this is only a preview.
f_pasha's brilliant libgki patch in use!
Downloadlink:
cm-7.0.0-RC0-0.07-11.02.03
Update:
18.03.2011 0.08-11.03.18
CM6.1.2 (2.2) pre-final md5: 37f24bebe0d56c0bc5771ad4b36e1939
changelog:
- various wlan connectivity issues fixed (some N routers, wpa2, 801.x enterprise etc.), as in current CM7
Downloadlink:
https://github.com/downloads/nadlaba...one-signed.zip
Reaktionen: xxeroxx, TexasHol, anime und 2 andere
11.07.17 - 0.11
Included CM4MM Auto Updater app for OTA-like updates
Imported nadlabaks Camera overhaul
Wide camcorder profile support
Add 5-point multitouch module by nadlabak
Slightly tuned low memory killer parameters
Unlock haptics now obey the general on-off/lenght/pattern settings (much more smoother now)
Torch high brightness mode fixed
Wifi fixed for some routers (no need to apply the Wifi hotfix anymore)
Removed "Bootloader" option from reboot menu (rebooted to fastboot, which is not suitable for flashing sbf's)"
[ROM] [11.07.17] CyanogenMod 6.1.2 - 0.11 (Android 2.2.1+) - xda-developers
Download: https://github.com/downloads/milaq/a...one-signed.zip
Reaktionen: anime, raba und spoeckes
Reaktionen: jakommo, anime, seven7up und eine weitere Person
11.08.11 - 6.3.0
  • Internal screenshot option (accessible from power menu)
  • Added Crystal talk
  • Updated multitouch module by nadlabak
  • Added an option to choose between 2, 4 and 5-point multitouch
  • Added a fix to address the infamous INCOMING_RING notification bug
  • Resized GB text cursor - smaller, sleeker and not obscuring SIP
  • Camera shutter sounds can now be enabled/disabled through CMSettings
  • Updated ADWLauncher to latest version from Gingerbread
  • Build Usb.apk from source
  • ADB on boot
  • Various small fixes/improvements
NOTE: Moving away from the 6.1.2-0.xx naming convention.
Renaming from CyanogenMod 6.1.2-0.13 to CyanogenMod 6.3.0 as both
Motorola (no kernel updates expected) and CyanogenMod (CM6 branch is final)
arent providing us with updates anymore.
Downloadlink: https://github.com/downloads/milaq/android/update-cm-6.3.0-Milestone-signed.zip
Reaktionen: Totti, sixfeetunder und inazr
Neue Version vom 28.08.2011
11.08.28 - 6.3.2
  • Latest DSI/MMC-fix by nadlabak (v2.6)
  • Fix data connection icon shown instead of usbicon
  • Readded sourcebuilt Usb.apk
Die Fixes von der Version 6.3.1 vom 27.08.2011 sind natürlich auch enthalten:
11.08.27 - 6.3.1
  • New kernel and vendor modules (SHLA 5.15)
  • Updated DSIfix by nadlabak to latest version (v2.52)
  • Disabled software GL renderer (improves performance, compatibility)
  • Touchfocus support for camera
  • New Torch with Auto-Off option, high brightness
  • Updated CM4MM Updater to latest version (v1.2)
Download: http://cloud.github.com/downloads/milaq/android/update-cm-6.3.2-Milestone-signed.zip
Reaktionen: el-fuego und inazr
Neue Version vom 11.09.2011
11.09.10 - 6.3.3
  • Native Usb tethering (SkrilaxCZ/nadlabak)
  • Ergonomic date- and timepicker
  • Volume rocker wake option
  • Added an option in camera settings HUD to turn off focus beep
  • Newest motofix module by nadlabak (DSI/MMC/NAND-fix v2.61)
  • Readded CMStats (optional bootup checkin here CMStats)
  • Using rewrite branch of Usb.apk (details here http://goo.gl/Ntt5D)
  • Reduced logging
Download: https://github.com/downloads/milaq/android/update-cm-6.3.3-Milestone-signed.zip
GApps: Latest Version - CyanogenMod Wiki
Reaktionen: DeinXsicht und -FuFu-
Neue Version vom 21.09.2011
11.09.21 - 6.3.4
-Added an option to always show the battery status on lockscreen
-Minor improvements/fixes
Memory optimizations to gain more free ram if needed including:
-Kill Gmaps location service if Gmaps is not running
-Contacts and ContactsProvider are now running sperarately from acore in a dedicated process (more ram freeable w/o killing e.g. the launcher)
-Usb.apk now runs in System.UI process
GApps: gapps-hdpi-20110922-signed.zip
CM6 Gingerbread-Theme (from Milaq): theme-Gingerbread-v9.zip
Reaktionen: androbikes
Neue Version vom 20.10.2011
11.10.20 - 6.3.5
  • Added an option to show upcoming events from calendar in lockscreen
  • Separate media volumes for headset/speaker
  • Better power profile from nadlabak
  • Gmaps hack is now optional (but enabled by default)
  • Cleanup of old, unused modules
  • AC clear logging disabled
Download: https://github.com/downloads/milaq/android/update-cm-6.3.5-Milestone-signed.zip
GApps: https://github.com/downloads/milaq/android/gapps-hdpi-20110922-signed.zip
CM6 Gingerbread-Theme (from Milaq): theme-Gingerbread-v10.zip
Reaktionen: wuerfel und androbikes
Reaktionen: mastakilla, T-Mod, Alosha und 2 andere
Thanks to all the people who have made CM possible on the milestone. Thanks in particular to Kabaldan and Milaq who have carried on developing for the milestone.
I've kept the same numbering as milaq. And since he stopped at 6.3.6, I've started the numbering from 6.3.7.
Note:
Keyboard layout is by default qwerty (it was euro_qwerty in milaq's ROM). Change it on first boot through Settings -> CyanogenMod settings -> Input Settings -> Keyboard layout
CyanogenMod 6 (FroYo)
This is a forked CM6 from milaq with feature backports from kabaldan's CM7
Source: https://github.com/vikasbn/
19 Apr 2012:
* Backported option to hide hold button on in-call screen
* Backported the LED settings rewrite. So the Notification LED settings is now the same as CM7 (faster)
Downloads:
* 6.3.7
* gapps (01-11-2011)
Reaktionen: motoroller, Alosha, T-Mod und eine weitere Person
Das neue CM 6.3.8 ist da!
Changelog:
* Long press Widgets in notification bar to get to settings
* Option to disable boot animation (shaves off about 10-12s from boot time)
* Dspbridge backport from kabaldan's CM7
* LatinIME and MMS app to run in systemui process
* Changed battery capacity to 1390 in power profile
* Improve scrolling cache backport
* Added sysctl.conf from kabaldan's CM7 (has new min_free value to alleviate RAM fragmentation)
* Some ICS transitions (like while closing/opening a window)
Download: https://github.com/downloads/vikasbn/android/update-cm-6.3.8-Milestone-signed.zip
Gesendet von meinem Milestone mit Tapatalk
Reaktionen: Vauxi, aPollO2k, Blanka und 4 andere
01 Jun 2012 CM 6.3.9
Changelog:
* Latest fixes for some packages/ apps
* Changed battery capacity to 1420 (the rating on MS battery is 1390min/ 1420typ --I had read it wrong the first time)
* Lock Home in memory by default (better performance, lesser launcher redraws)
* Show CPU Info and RAM info in 'About Phone'
* Wider camera profile (854x480, was 720x480 earlier)
Download: https://github.com/downloads/vikasbn/android/update-cm-6.3.9-Milestone-signed.zip
Reaktionen: vgi, aPollO2k und Alosha
