[ROM] Cronos Gingerbread für das Milestone
  • 8 Antworten
eybee1970
eybee1970
Philosoph
5.255
Changelog:
16 Mar 2011 | Cronos Ginger 1.1.0
-Updated to latest source updates
-Updated kernel, libs, prop. files to latest leak (14 Mar)
-Changed some compile optimizations.
-Faster GUI responsive
-Bug fixes of DRM framework
-Removed dead code with no other effect than consuming battery life.
-float values equality checks : core/java/android/webkit/WebView.java.
-Patched freetype for nicer Font rendering.
-Updated to latest CM Extra.
-Removed dead store : core/java/android/os/BatteryStats.java
-frameworks/base: Fix for force close during rapid FF of cetain midi clips
-Runtime inclusion of services in the SystemServer with overlays
-Fixed memory leak in PreferenceScreen.
-Removed strict lowmemorykiller configuration.
-Changed default speed to 700Mhz.
download links: http://cronos.bertol.de/CGMM-1.1.0_.zip
Google Apps (for CM7): http://android.d3xt3r01.tk/cyanogen/...307-signed.zip
Source: Cronos Android, Android on Steroids! • View topic - Milestone Cronos Ginger 1.1.0
Reaktionen: Rbzhl, letsdoit, Calsonic und 2 andere
Cronos Android, Android on Steroids! • CGMM-1.2.0_.zip
Release Notes
07 April 2011 | Cronos Ginger 1.2.0
  • Resampler optimization routines properly patch.
  • TextView.setText memleak fixed.
  • SW renderer of Stagefright move on to draw stage after the initialization.
  • Fixed isValid() Software EGL Rendering seg fault.
  • Default WiFi sleep policy added.
  • Added sdcard tweaks.
  • Removed Default Camera.
  • Removed Default Music Player.
  • Added MIUI Camera.
  • Added MIUI Music Player.
  • OOM Error encoding images.
  • Fixed contact data updating.
  • Fixed Launcher Menu (more) Replication Bug.
  • Fixed Heavy Graphics Load System Crash. (Library Exception)
  • Gralloc Mem Leak Fix.
  • Integrated latest CM source updates. (By Nadlabak and CM)
  • Updated to latest CM Extra (By Nadlabak and CM)
  • AccessibilityManagerService death notifications proper clean up.
  • Removed dead store : core/java/android/os/BatteryStats.java Patch2.
  • Improved shutdown speed.
  • revert PIXEL_FORMAT_RGB_565 (By Nadlabak)
  • Improved Camera preview format.
  • Default speed to 700Mhz.
gapps: http://android.d3xt3r01.tk/cyanogen/...307-signed.zip
Reaktionen: anime und rookie
Hallo, CRONOS-Mod auf Gingerbread-Basis Version 1.4.0 steht zur Verfügung:
Cronos Ginger v1.4.0 (2.3.4)
27 May 2011 | Cronos Ginger 1.4.0
  • Tweak audio APIs for better compatibility.
  • Fixed draw texture when loadTexture() is called.
  • Performance of toHex() improved.
  • sdcard improve insertion notification on Gingerbread.
  • Ninepatch tweaks for better interop
  • Switch to SkSafeUnref for better portability
  • Fixed Bogus WiFi Garbage in xml's from an old patch of mine.
  • Updated to latest AOSP Sources.
  • Better Bluetooth Support.
  • Lock home in memory included.
Download-Link: Main Page - Cronos Project
Kurzanleitung zur Installation:
- download ROM + download gapps
- beide zip-Dateien in sdcard/openrecovery/updates packen
- in die OR booten
- wipe data/dalvik/cache
- apply update > ROM auswählen
- apply update > gapps auswählen
- reboot
Reaktionen: moviecut und eybee1970
Hallo, CRONOS-Mod auf Gingerbread-Basis Version 1.5.0 steht zur Verfügung:
Milestone Cronos Ginger X 1.5.0
Release Notes
14 July 2011 | Cronos Ginger X 1.5.0:
  • First release of Cronos X.
    • Settings have extended options.
    • Font size options ported by ComputerFreak.
    • Battery Percentage option added.
    • Battery Percentage Bug, fixed by ComputerFreak.
    • widget button FC on MDPI devices fixed by ComputeFreak.
    • Improved Danish Translations by ComputerFreak.
    • Extra animation option ported by ComputerFreak.
    • small GUI changes by ComputerFreak.
  • A few tweaks used with flags.
  • Fully Removed CM Extra.
  • Sources have been updated to latest AOSP.
  • Source for external and hardware support updated to latest CM.
  • libSqlite improvement.
  • Added Call Delay tweak by jyxent.
  • lowmemorykiller improvement (Again)
  • Added a few tweaks from Juwe11.
  • And of course all the Cronos speed imrpovements Added.
  • Included A2SD kernel
  • Included Nadlabak's latest non DSI kernel.
Download CGXMM-1.5.0:
Official Cronos Mirror: PHP Bertol Cronos Mirror
MD5SUM: On download link.
Download latest google apps:
goo-inside.me - gapps-gb-20110307-signed.zip download
EDIT:
15 July 2011 } Cronos X Mod Update 01:
Changelog:
  • Volume rocker wakeup - Ported by ComputerFreak
  • Enable/disable CRT on/off animation - Ported by Feeyo & ComputerFreak
  • Added option to change the indicator color in the notification widget. Ported by ComputerFreak
  • Fixed some checkboxed incorrectly checked by default by ComputerFreak
  • Fixed some incorrect text when selecting brightness mode by ComputerFreak.
(Gleiche Downloadlinks wie oben!)
1. Wipe
2. Flash ROM
3. Boot to full ROM.
4. reboot to Recovery.
5. Flash GAPPS
6. Reboot.
HINWEIS: Feeyo, der Entwickler weist darauf hin, dass die CPU auf 1.000 MHZ getaktet ist und stellt anheim, dies ggf. zu ändern.
Diskussionen zu diesem ROM bitte nur hier: diskussion-cronos-gingerbread-fuer-das-milestone.html
Reaktionen: moviecut, nightwatchdog und rookie
Hallo, CRONOS-Mod auf Gingerbread-Basis Version 1.5.1 steht zur Verfügung:
Milestone Cronos Ginger X 1.5.1
Release Notes
21 July 2011 | Cronos Ginger X 1.5.1:
  • Fixed: Android Battery Drain.
    • Please recalibrate your battery.
    • Please fully charge the battery to 100%.
  • X Settings updated to version 0.0.3
  • Font sizing will stay permanent.
  • Fixed: ScreenStatus Scaling.
    • I recommend using ScreenStatus Scaling!
  • Fixed 30tweak file, thanks bleep42.
  • Added memory tweak from pcphobic as default.
  • System should be a bit snappier.
  • Added a new version string for X Settings Mod itself.
  • Added latest nadlabak dsi fix kernel module.
  • Volume rocker wakeup port by ComputerFreak
  • Enable/disable CRT on/off animationport by Feeyo/Computerfreak
  • Added option to change the indicator color in the notification widget port by ComputerFreak
Download-Link: The Official Cronos Mirror • download CGXMM-1.5.1_.zip
Download latest google apps: goo-inside.me - gapps-gb-20110307-signed.zip download
1. Wipe
2. Flash ROM
5. Flash GAPPS
6. Reboot.
Reaktionen: straussi_754, Christoffer und nightwatchdog
Hallo, CRONOS-Mod auf Gingerbread-Basis Version 1.6.0 steht zur Verfügung:
Milestone Cronos Ginger X 1.6.0
Hi guys,
Here is a new release of your favorite Cronos ROM for your Device. This time it has the first release of Cronos X included.
This is still WIP (Work In Progress) by me and Computerfreak so please dont go flaming us about features that are not included.
If you have a wish list of functions please use a proper Forum thread to post them so that we can have a look at it.
You have bugs to report? Please use: MantisBT
Release Notes
31 July 2011 | Cronos Ginger X 1.6.0:
  • Updated to Android 2.3.5
  • Cronos X PowerWidget fixed.
  • Cronos X Settings Fixed FC Delay.
Download-Link: The Official Cronos Mirror • download CGXMM-1.6.0_.zip
1. Wipe
2. Flash ROM
5. Flash GAPPS
6. Reboot.
Reaktionen: Lizard85 und nightwatchdog
Motorola Milestone Cronos Ginger 1.7.0
Release Notes
11 Nov 2011 | Cronos Ginger X 1.7.0:
  • Added Camera.
  • Added DSI work around.
  • Added ADB USB Support.
10 Nov 2011 | Cronos Ginger X 1.7.0:
  • Updated to Android 2.3.7
  • Browser battery draining fixed.
  • Calling battery draining fixed.
  • Cronos X Settings Memory Hog Fixed.
  • This Will remove Full Cronos X CPU Memory Hog.
  • This means the CPU over clocking in X Settings will be fully removed giving you more memory to spare in your system.
  • Over clocking will be done with a oc daemon. You can find its CPU OC configurations in /system/etc/cronos directory.
  • Improved net speed 3G/H/WiFi
  • Fixed sqlite WAL Bug.
  • Fixed Call hang up Delay.
  • Default Clocked to 800Mhz
Download CGXMM-1.7.0:
The Official Cronos Mirror • 404 File not found
link funkt trotzdem
http://cmw.22aaf3.com/gapps/gapps-gb-20110828-signed.zip
Reaktionen: Gregor901
Jetzt auch mit extra OC
Release Notes
  • Added Camera.
http://cronos.bertol.de/index.php?dir=%2F&download=%2FCGXMM-1.7.0_sign.zip
CGXMM-1.7.0-OC_.zip
Overclock
The Official Cronos Mirror • download CGXMM-1.7.0-OC_.zip
[/QUOTE]
