[ROM-alpha] CyanogenMod 9.0.0 RC0 (Android 4.0.3)
  • 383 Antworten
Das im Speicher halten findet aber mit dem Fix nur noch wärend des SMS Empfangs statt. Somit ist der Speicher für den Rest der Zeit frei.
Das einzige was noch ein Problem sein könnte ist, dass es vielleicht noch einen anderen Grund für verlorene SMS geben könnte als nur das Beenden der SMS-App durch den OOM-Killer während des Empfangs.
Okay, vertrau ich mal darauf. Schlimm fänd ich es nicht, wenn ich Unrecht habe ;)
Das würde glaube ich jeder hier sehr begrüßen ;)
New unoffical update (May 10th 2012.)
Please read this post very carefully ("cover to cover")
This update contains a simple and clever fix for "lost messages" (an attempt actually, but seems to be working), all done and fixed by kabaldan.
It was made a few days ago but problems with my device made it impossible to provide it earlier.
The update has been tested and it is working BUT since my device is a bit messed up I could not test it "as is", instead I had to modify it (thank you kabaldan for your time, help and patience on the matter) so the update zip that is uploaded is NOT tested in a clean way like it usually was. Nevertheless, it should work for you anyway.
With above mentioned, you are encouraged to make one lovely nandroid backup of your current, running and working system before installation.
You have been warned.
Disclaimer:
Don't hold me responisble for problems you might run into by using this.
Responsibility is all yours.
OK, one burden less
Changelog
"Lost messages" fix attempt -> Please report if you loose any messages. |
Added T-Mobile theme engine
Settings: Added hungarian translation for Wifi Ad-hoc and Slide lock delay
Settings: Customizable lockscreen targets (Lockscreen : Customizable shortcuts)
Settings: fix manually adding network
Camera: Timer mode: Update Russian Translation, Added German translation
Camera: Hungarian translations
New PowerWidget icons
Camera: Fix for the barcode scanner
Camera: 848x480 video recording
Many other updates and fixes
http://www.namagi.com.hr/android/up...holes-UNOFFICIAL-signed_20120510_14-41-21.zip
Reaktionen: motoroller, papadawg und laces
neues inoffizielles update von znetroll von xda.
xda-developers - View Single Post - [ROM-alpha] CyanogenMod 9.0.0 RC0 (Android 4.0.3) [20120307]
Genauso wie zentroll bin ich nicht dafür verantwortlich, was ihr tut.
Ihr Installiert dieses Update auf euer Risiko!
Viel Spaß damit :)
New Build. Flash it and see what happens, I have no idea
https://rapidshare.com/files/1008733...IAL-signed.zip
0d80ec338f4ba124e73bcda467644fba
Seriously, don't ask me for a changelog, I'm not as good an uploader as mrvek is All I know is that nadlabak merged lots of changes before I built and none afterwards (up to the moment I'm writing this). And don't blame me, nadlabak or anyone else since this is an unofficial build and solely your responsibilty, ok?
Ah, and since apparently some people don't know: I don't really do much, I just download what nadlabak (that's kabaldan in reverse) and the upstream guys of CyanogenMod do, run a single command and upload what falls out of it 10 minutes to an hour later, so all credits go to nadlabak and CyanogenMod. All blame when something goes wrong, however, goes to you because you didn't read the disclaimer :p
Bei mir startet bei jeder Pineingabe das Handy neu. Kein benutzen möglich.
Man soll auch bevor man die cm9 flashe
Den Pin ausschalten. Den sollte es gehen.
Greetz alt
Gesendet von meinem HTC One X mit Tapatalk 2
der download ist nicht verfügbar.
Bei mir startet ständig der network location service von gapps.
Leider ist bei mir ebenfalls die Anforderung, genug RAM zu haben, um Temple Run spielen zu können.
Trotz Chainfire 3D ging es bei mir nicht.
(Mir persönlich wärs egal, aber es ist nen guter Zeitvertreib in der Schule, für Nachbarn und Co :D)
Nichtsdestotrotz, ich hatte ganz am Anfang ICS getestet, da war kaum mehr RAM als 20 MB frei.
Diesmal schwankte es zwischen 55-68 MB, was definitiv ein großer Schritt nach vorne ist.
Weiters sah ich, dass nadlabak momentan nur an ICS weitermacht bzw. die meisten letzten Updates für ICS waren.
Sehe daher ne recht gute Zukunft in ICS für unseren Meilenstein :)
Greetz
PS: Ohne SIM getestet.
Die Downloads sind Fehlerhaft und lassen sich nicht installieren.
Also ich misstraue diesen etwas zweifelhaften Quellen. Gibt es denn kein "Original" (von Nadlabak) ??
Ich hab das Thema nicht so richtig verinnerlicht, daher die Frage.....
Es gibt natürlich eine offizielle version von nadlabak, die ist aber schon ziemlich alt.
Die builds von Mavrk kann man aber auch ziemlich bedenkenlos flashen, da er recht eng mit nadlabak zusammen arbeitet bzw viel kontakt mit ihm hat und die builds auch meist getestet sind bevor er sie hoch lädt. (Steht meist dabei)
ich geb dir aber recht, die ungetesteten würde ich auch nicht installieren, das ist nur was für leute die es garnichtmehr aushalten können bis zum nächsten update.
Nadlabak müsste soweit ich das mitbekommen habe bald ein offizielles update veröffentlichen.
Mfg L3ibnitZ
Edit: Die letzte "offizielle" version von nadlabak findest du hier:
http://forum.xda-developers.com/showpost.php?p=21394145&postcount=1
Gesendet von meinem Milestone mit der Android-Hilfe.de App
Reaktionen: Gregor901
misstrauen? dann hättest auch nie die vom lieben elektroschmock nutzen können oder ;)
Kannst'e nicht vergleichen! Elektroschmock ist hier im Forum und von dessen ROM kann man hier viele Berichte und Reaktionen lesen. Von CM9-znetroll lese ich z.B. sowas:
Dann gebe ich dir mal nen gegenteiligen Bericht:
Der Download von znetroll verlief langsam, aber reibungslos (hab von rapidshare).
znetroll hat scheinbar wirklich nur kompiliert, denn das CM9-Bild beim Laden wird dargestellt, was nadlabak aber bei seinen Roms (scheinbar) deaktiviert hat.
Dadurch gestaltet sich der erste Start langwierig, aber nach dem Deaktivieren geht ein Neustart recht flott.
Die Kamera ist noch wackelig auf den Beinen, es stockt, ich nehme an, dass das auch beim CM9 von nadlabak und anderen ist.
Habe ohne SIM getestet bzw. im Flugmodus mit aktiviertem WLAN.
Konnte keine großen Probleme feststellen, die SD wurde auch nicht formatiert ;)
Schätze also, es geht keine Gefahr von seinem ROM aus.
Greetz
New nightly build (17.05.2012.) Nigthly build, May 17th 2012.
As usual, this is just an update to previous nightlies (but can be used to flash for the first time) for CM9, all made possible by kabaldan.
Some info about title and file name change
The title says "nightly" instead of "unofficial" because it has been pointed to me that "UNOFFICIAL" in the update package filename is not reffering to "not uploaded by kabaldan" but instead means "not official CyanogenMod (not officially supported by CyanogenMod team)". This was incorrectly understood by me, hence the incorrect title of previous posts.
(This still makes little sese to me because Motorola Milestone A853 was never supported by CM team and possibility that it ever will is, I assume, non-existent (especially for ICS). And filename part "unofficial" appeared about the same time as other people besides kabaldan started to upload his work. You have to admit it was a logical mistake
Changelog:
Code:
Fixes for video recording and camera Keyboard: Add Hungarian predictive dictionary support, Add Hungarian accents (required for the predictive dictionary to work) Revert Hungarian keyboard to qwertz and add alternative qwerty layout DSPManager: Add missing Brazilian Portuguese translations Camera: some German, Portuguese and Hebrew translation fixes and updates Settings: Updated Hungarian, Korean, Italian, Hebrew, PT-BR languages. Lockscreen shortcuts: updated Hungarian Volume Settings: fix link mute states checkbox (vertical rearrangement) PowerWidget: Restored icons; updated visual feedback Settings: Data usage: Linear chart option and 2GB to 100MB vertical axis limit Use low resolution bootanimation USB: Don't enable data connectivity on unplug if it was disabled before. Settings: Wi-Fi direct (peer-to-peer conectivity) Move dalvik-cache of system to cache (was on data (ext); slightly increases performance) Enabled notification LED settings Disabled dock options Removed Toggle2G
MD5: 6833201e5ed3fa778ddc0ca15b7e126a
File size: 115,159,686 bytes
Download
update-cm-9.0.0-RC0-umts_sholes-UNOFFICIAL-signed.zip.md5sum.zip (323 Bytes, 8 views)
Gute Arbeit und Fehler wurden beseitigt. Dank an Nadlabak.
Wäre schön, hier mal wieder einen Erfahrungsbericht zu lesen ... Wird es wirklich immer besser und flüssiger?
ich habe installiert aber Baseband funktioniert nicht, kein Netzwerk. Wass soll ich machen?
Danke
MFG
Some changes:
Settings: updated Italian, Turkish, Hungarian, Russian (CM9 settings), Hebrew
InputManager: Add system setting to define keyboard locales
Added Toggle2G built from source (app no longer requires root permission)
Keyboard: Add Czech QWERTY, enable predictive dictionary, missing hungarian traslation
Keyboard: enable character map option for the hardware keyboard (qwerty, qwertz, azerty etc.)
New data usage modules
Replace Music with Apollo
Fix crashes on video playback
Fix restoring network mode preference on reboot
Updated Terminal (v. 1.0.43)
Updated Toggle2G (v. 0.2.5; built from source; doesn't need root perm. any more)
Video recording: indicate frame drops by red LED
Support weather forecast on lock screen
Keyguard: Turn lock-before-unlock into a user-configurable setting (Showing the unsecured lock screen (Slider/widget screen) before the security screen is now a secure Setting (still defaulting to off))
DSPManager: Update equalizer for channel independence, Improve headsetfilter's primitive space simulation, addes Finnish, updated Italian
Camera: added German
Vibrator/airplane overrides:
Add vibrator overrides for ringer and notification:
* enable
* disable
* only when silent
Add airplane mode overrides:
* enable
* disable
Some other updates, fixes and optimizations
http://www.namagi.com.hr/android/up...sholes-UNOFFICIAL-signed_NIGHTLY_20120528.zip
