eybee1970
Philosoph
- 5.255
Release-Time MIUI 1.1.21: Google Translate
streetking77 schrieb:jo hab ich wirklich ncih lange wie kann ich syncen
anime schrieb:Hier ein Mirror zu der neuen Version:
Multiupload.com - upload your files to multiple file hosting sites!
eybee1970 schrieb:ach ja: die neuen Animationen sind sehr geil...besonders gefällt mir eine, wo beim screen-Wechsel das Fenster nach hinten wegfällt und verblasst, bzw. blass von hinten hochkommt....schwer zu beschreiben, aber ihr seht es ja dann
streetking77 schrieb:ist die version auch deutsch
omniaholic schrieb:Ich saß noch nicht dran....wenn ihr mir aber sagt was neu ist,..., dann mach ich das vlt. .......falls es mir gelingt
...bin zu faul zum suchen
Recommended features:
1. Stability and performance optimization
- Optimize memory use, so that when the multi-screen desktops in more stable (there are many screens for large memory installed many small tools and procedures is very good mobile phone)
-Milestone Brazil version of the new kernel upgrade
2. SMS Campaign Optimizer (see details below text)
Phone:
T9 contact search optimized optimized memory footprint small revision (Note: need to manually empty the Contact resync)
Contact:
Select a contact in the global optimization of call records for the recent contacts
(including telephone and text messages recently linked to filter out strangers and mass numbers)
Add contacts to resolve SMS optimize the select list are not allowed to issue letters fast slider
SMS:
Add increase in SMS center number set (SMS settings change)
Add text recommended in the Spring Lantern Festival adds a new message
Add bulk SMS name field can point to open the mass of people see all
Add bulk SMS can be inserted call, call will be replaced when it is sent to send names
New customer phone does not automatically insert a signature
Optimization of the "Add Contact" into the input box on the right
Optimize the user to read text messages sent when the box is smart to shrink by 2 to 1 line of line
Increase in the recommended optimal festivals style SMS
Optimal adjustment of SMS setting interface
Optimization "into the common language" interface optimization
Optimization of mass contact interface and process optimization
Optimal adjustment to send text messages, send in the icons and sent successfully
Save the signature in front fixed spaces if the user does not automatically add a space
Air draft text does not fix the problem disappears
Repair after adding the expressions and accessories, auto away and re-pop-up input
Desktop:
Add animated desktop, plus three kinds of new effects (point of the desktop menu - starter set of changes)
Optimize optimize memory use, so that when the desktop screen in a more stable and more
Music:
Add the third edition of a comprehensive adaptation interface style
Add edit playlists, so that students like to be able to manage music play cool!
Optimization "Now Playing" song interaction, "Now Playing" panel can be opened by clicking
Optimization to streamline "Now Playing" panel, album art, lyrics pages combo, refreshing experience!
Optimization of the local music folder and add to the music player search page to reduce the level structure
Gallery:
New home, folder, flip horizontal
Optimized to further improve the list of folders and open the speed of image
A list of thumbnail images reverse loading fix the problem
Theme:
Add new theme interface
Camera: (in MIUI network disk download)
Added features increase the widescreen, widescreen mode, full screen viewfinder
Optimized to support smooth zoom milestone
Double-screen correction milestone on the repair, the picture will change the size of the problem set
Network drive:
Add an open forum account to upload binding
Add add "one button install"
Add Update List page, in the "installed capacity must have" in the menu.
Add auto update software, update the notice to remind the function bar
Add network disk settings page, you can choose, or wifi network operators, automatic update, update reminders
Add to upload the software, just upload the software marked as "Pending"
Backup:
Optimization of the contacts, call records to optimize the backup mechanism
Settings:
Automatic brightness optimization optimized again (in the Settings - Display - brightness settings)
Optimization of the PIN from the "Security and Privacy," presented to a separate display
Global search:
First time fix to solve the global problem of the search does not return results
System Update:
New system update interface (address at the same time can not see download ROM update)
Flow monitoring:
Add a single application of the wifi, 3g flow can separate view
Add to use the new file format (Note: Because this item needs to improve flow of history is cleared, the user need to re-calibration)
Other:
Fixed dial-up dial-up HD2 key issue is not
HD2 Fixed problems recording video will be FC
HD camera supports up to eight megapixels
Milestone Brazilian version of the new kernel upgrade
sazan schrieb:So bin die tage miui fremd gegangen
CM6 , dann HONO , dann Cronos..
ehrlich nichts begeistert mich mehr wie miui^^
sazan schrieb:Männer danke für die Hilfe.. leider bin zu blöd![]()
zuviel rumfummellei CM6 Stock bin zufrieden ^^
