			mhz0015
Dauer-User
- 270
Irgendwann hat alles mal ein Ende und mit dem Stein geht es langsam zu neige, ich denke mal Mitte nächstes Jahr werden die meisten umgestiegen sein.
			CHANGELOGv0.2
- Used original MIUI framework now, no modding has been applied , except english language pack.
- HTC IME fix (no more FC's)
- Sdcard status fixed (supposed to be status of Apps2sd non-native function, which we dont have in our kernel)
- Wifi enabling ok, if the guideline is used mentioned in "ISSUES" section.
- Settings now working.
ISSUES Reported by users
- Enabled Bluetooth or Mobiledata at bootup , will disable WIFI functionality, so keep Bluetooth and mobiledata disabled at reboot, if you want to enable wifi.from here it seems you can set state all you want after bootup.
- Some settings state, cannot be changed if Wifi is enabled during bootup :-( .
Got some fixes done, and went back to beta release and started from that one..
The only conflict now, seems to be that if mobiledata or bluetooth is enabled at boot, you cannot enable wifi.. so before a reboot disable Bluetooth and mobiledata, if you intend to use Wifi connection..
If you follow this, it seems that everything can change state, if you follow this guideline.
- but else HTC_IME is fixed, missing libs included..
- SDCard problem fixed (missing /data/sd folder)
- Stock 11.05 from MIUI team now used.
- updated location.cfg to point to google servers,which should give better aGPS functionality (i read in other threads)
I think this "stock" edition is near perfect.. but let me know, if you think otherwise..
			Installation:
1. Nandoid installieren [ROM][8-nov-10][v0.1] Milestone MIUI ROM - xda-developers
2. Wifi temporary fix - download here
3. Deutsch Patch http://forum.xda-developers.com/show...postcount=3785 (Danke an eybee1970 für den todesmutigen Test)
3.1. build.prop auf die SD-Karte sichern (system/build.prop) (und noch EN + en durch DE + de tauschen)
3.2. Sprachpacket als update über die OR einspielen
3.3. alte build.prop wieder zurücksichern (und noch EN + en durch DE + de tauschen) (permission 644)
4. framework-res.apk wieder die alte kopieren MIUI rom bald für das Milestone (post von eybee1970 13:54 Uhr).
Natürlich Rechte setzen 777
			anime schrieb:Also muss man jetzt nur noch den ersten schritt und den dritten machen. Aber brauchen wir immernoch deine build.prop eybee?
 nur das mit gps liegt mir bei miui noch im magen ... da ja das sehr langsam ist also nach 2 min immer noch kein fix xD
			anime schrieb:Boah, so viele Mods gab es noch nie. Damals konnte ich immer eins ausgiebig testen und jetzt kann ich mich garnicht zwischen CronosFroyo v.1,40, FroyoMod v.2, MIUI, CyanogeonMod, was soll man da nur machen ...
Sakaschi schrieb:anime einfache lösung: für jeden neuen mod "rom" nen neuen stein kaufen und dann kannste alle testen
			moviecut schrieb:kann ich nicht auch einfach die build.prop und die framework-res.apk aus dem language-pack rauslöschen. dann spar ich mir ja das manuelle zeugs...und sollte man noch die deutschen radiofiles einspielen?
Oder gleich auf 2.0 wechseln und behaupten ich hätte ein richtig schnellen steinAleviDroid schrieb:auf 2.34 wechseln mit Wecker BUG
			anime schrieb:
gute Idee, jetzt brauch ich nur noch einen Sponsor, der das alles finanziert
Na, Interesse ???
