[Diskussion] MIUI-ROM für das Milestone
  • 11.869 Antworten
Da steht bei mir was von HTC Desire und deren CPU. Deswegen ist meine Frage ob man das so einfach ändern darf sodas da die Milestone Hardware steht.
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=MIUI
ro.build.display.id=MIUI.0.12.24
ro.build.version.incremental=0.12.24
ro.build.version.sdk=8
ro.build.version.codename=REL
ro.build.version.release=2.2.1
ro.build.date=Fri Dec 24 13:40:53 CST 2010
ro.build.date.utc=1293169253
ro.build.type=userdebug
ro.build.user=hanzhupeng
ro.build.host=builder
ro.build.tags=test-keys
ro.product.model=HTC Desire
ro.product.brand=generic
ro.product.name=libra_bravo
ro.product.device=bravo
ro.product.board=bravo
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=HTC
ro.product.locale.language=zh
ro.product.locale.region=CN
ro.wifi.channels=
ro.board.platform=qsd8k
# ro.build.product is obsolete; use ro.product.device
ro.build.product=bravo
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=libra_bravo-userdebug 2.2.1 MIUI 0.12.24 test-keys
ro.build.fingerprint=generic/libra_bravo/bravo/bravo:2.2.1/MIUI/0.12.24:userdebug/test-keys
# end build properties
# ADDITIONAL_BUILD_PROPERTIES
ro.sf.lcd_density=240
rild.libpath=/system/lib/libhtc_ril.so
ro.ril.ecc.HTC-ELL=92,93,94
ro.ril.ecc.HTC-WWE=999
ro.ril.enable.a52.HTC-ITA=1
ro.ril.enable.a53.HTC-ITA=1
ro.ril.enable.a52=0
ro.ril.enable.a53=1
ro.ril.enable.dtm=1
ro.ril.gprsclass=12
ro.ril.hsdpa.category=8
ro.ril.hsupa.category=5
ro.ril.hsxpa=2
wifi.interface=eth0
wifi.supplicant_scan_interval=15
ro.telephony.default_network=0
ro.ril.disable.power.collapse=1
ro.ril.avoid.pdp.overlap=1
ro.ril.enable.prl.recognition=1
ro.ril.def.agps.mode=2
ro.ril.def.agps.feature=2
ro.opengles.version=131072
dalvik.vm.heapsize=32m
dalvik.vm.dexopt-data-only=1
ro.media.dec.jpeg.memcap=20000000
keyguard.no_require_sim=true
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
media.stagefright.enable-player=true
media.stagefright.enable-meta=true
media.stagefright.enable-scan=true
media.stagefright.enable-http=true
ro.modversion=LibraMod-0.12.24
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.clientidbase=android-google
ro.com.android.wifi-watchlist=GoogleGuest
ro.setupwizard.enterprise_mode=1
ro.setupwizard.mode=DISABLED
ro.com.android.dateformat=yyyy-MM-dd
ro.ril.enable.managed.roaming=1
ro.ril.oem.nosim.ecclist=911,112,999,000,08,118,120,122,110,119,995
ro.ril.emc.mode=2
ro.moddevice=G7
dalvik.vm.lockprof.threshold=500
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
CertInstaller.apk -*
ThemeManager.apk - *germanized
Hier der Link
Nicht die build.prop vom N1 benutzen! Da sind ja die Einstellungen für´s N1 mit drin. Nimm die build.prop aus dem aktuellen Miui 12.24 vom Milestone.
Hier mal die fertige framework-res.apk. Da du ja schon einige Apps übersetzt hast, überlasse ich es Dir ein German Miui 12.24 fertig zu machen. :)
http://dl.dropbox.com/u/13419440/framework-res.apk
Ausserdem ist mir aufgefallen das bei der MMS.apk der Senden Button noch chinesisch ist. Habe die Png´s schnell geändert.
Habe hier die Png´s (als zip) und auch die fertige MMS.apk mit hochgeladen.
http://dl.dropbox.com/u/13419440/drawable-hdpi-v4.zip
Edit:
Bei der build.prop müssen ja nur die zwei Einträge geändert werden:
ro.product.locale.language=de (vorher zh)
ro.product.locale.region=DE (vorher CN)
Edit 1.1.11: Ich habe die Mms.apk der neuen Version angepasst und brauche den Platz bei Dropbox, deswegen gibts es die alte Mms.apk hier nicht mehr!
Reaktionen: omniaholic, anime und eybee1970
Ausserdem ist mir aufgefallen das bei der MMS.apk der Senden Button noch chinesisch ist. Habe die Png´s schnell geändert. Habe hier die Png´s (als zip) und auch die fertige MMS.apk mit hochgeladen.
http://dl.dropbox.com/u/13419440/Mms.apk
Ich kann das nicht alleine...mama :crying:
Von wo hast du die Milestone Edition?
Aus der "miui-milestone-0.12.24.zip"!
Edit:
Pack kann ich auch fertig machen. Ist ja nur ne Kleinigkeit. :)
Reaktionen: janosik
Edit:
link? die verlinkung der voherigen seite mit dropbox geht nicht da die datei anscheinend nicht mehr auf dropbox ist...
Und wo hast du die her? Hab nur die fürs Desire gefunden :huh:
Kann mal bitte jemand eine andere Gallerie.apk hochladen als diese grottenschlechte 3D Gallerie, würde gerne die normale die beim werkzustand dabei war nutzten, weiß aber nicht wo ich die finden kann - Danke und frohes Fest
Nimm QuickPic ausm Market
Auf Wunsch lade ich mein Miui 12.24 mal hoch. Ich habe beim heutige Release 12.24 die framework geändert. Das Keyboarlayout ist auf qwertz umgestellt und die 2 Fingers Animation (maps) hinzugefügt. Es sind ausser den Google Apps, nur noch die von Omniaholic bearbeiteten Apk`s auf Deutsch.
( Miui Music, Monitor, MMS App) Rest müsst Ihr hier https://www.android-hilfe.de/forum/...das-milestone.53512-page-116.html#post-875889 noch runterladen und installieren.
Das ist bis jetzt alles. Habe es drauf und vom Feeling her ist es ein Schritt nach vorne. Die letzten 2 Versionen haben mir nicht gefallen. Wobei ich die 12.18 nur 1 Tag benutzt habe. :)
Download hier:
http://dl.dropbox.com/u/13419440/Alfs-miui-milestone-0.12.24.zip
Reaktionen: cooper1988, Sörnäinen, anime und 4 andere
danke toalf du hast mich erhöhrt xD hätte es selber gemacht wenn ich miui milestone gefunden hätte^^ und nicht vom kack desire
euch allen noch ein frohes weihnachtsfest.
Hi danke alf & omniaholic
update es gerade *freu*
Macht ihr bei MUI eigtl. MEmhack von OR auch mit? bzw. wie tweakt ihr euer stein? Gleich OC? wenn ja bitte die datei hochladen.. und nutzt ihr autokiller oder was anderes?
mfg
Du muss memhack von CM installieren, das klappt immer :)
OC solltest du dir, bevor du das update installierst, in die update.zip hinzufügen, die datei findest du im How-To
Und Autokiller ist für mich der einzige gute Taskmanager, weil er nicht gegen das System arbeitet, mehr brauchst du auch nicht ;)
Marjun schrieb:
Nö, ich würde gerne die alte Gallerie wiederhaben, keine externen Programme
Die alte läuft nicht.
Es fehlen die libs, wenn mir wer sagen kann welche dazugehören dann kann ich da was machen (mir fehlt die Zeit um selber zu schauen).
Habs auch versucht
Download hier:
Meine Herren... das nenne ich ziemlich coolen Service! :O
Dankeschön!
Ist eigentlich das Wetter App mit dabei was hier zu sehen ist?
In einem englischen Forum habe ich gerade gelesen, dass das ein chinesischer Anbieter von Wetter-Daten ist und deswegen das App nicht enthalten ist in der englischen Miui Rom.
Wenn Ihr Glück habt und meine Nerven Nahrung nicht zu ende geht....habt ihr Morgen mehr als die Hälfte auf Deutsch. 23 APK sind fertig....war vorher noch bei meinen noch Schwiegereltern, deswegen hat sich das ein bissle hingezogen.
PS: Ich hab da auch lustige Sachen drin wie:
<string-array name="voice_quality_ui_values">
<item>Normal</item>
<item>Klar</item>
<item>Knackig</item> - hab da jetzt Intensiv stehen :p
<item>Hell</item>
Da viel mir und Google nix besseres ein
Geht hier noch eine Dummy-Frage? Wird die eventuell beantwortet?
Wenn ich neue Versionen von Miui via OpenRecover und Apply Update draufpacke... sind dann alle Einstellungen futsch? Oder kann man die einfach drüberpacken?
@Sörnäinen Guck mal wie spät es ist :D. Zu deiner Frage eigentlich nicht,...,ABER du ich mach immer ein Full Wipe bevor ich nen Update drauf schmeiß. Dabei gehen alle Daten Verloren außer die, die auf der SD-Karte sind oder mit Google gesynct sind (Telefonbuch und so weiter).
coolzero3389
  • coolzero3389
coolzero3389
coolzero3389
coolzero3389
coolzero3389
coolzero3389
mancloud
diloniga
diloniga
