Bandit
Enthusiast
- 723
Changelog:
7.1.0-RC10-11.06.14 (2.3.4)
- DSI-fix kernel module - adds error recovery scheduling (in Droid kernel called from dsi_vc_flush_receive_data function, while this particular call was missing from Milestone kernel). Kernel function hooking in use made by Nothize, hooking source provided to me by Zewelor. Thanks!
(hopefully, you can safely disable the DSI workaround in CM settings>display now)
- 'Incoming call in background' option (Settings>Call settings) - option to inform about incoming call only via notification & ringtone while not leaving the currently active application in foreground, when screen is on
- ro.ringtone_query_wait_time property added, to allow override the max time allowed for getting the customized ringtone for the particular contact that is currently calling, before the fallback to default ringtone. Android default is 500ms. Set to 1500ms in this release.
- 'normal' flashlight brightness fixed
- 'high' brightness option when flashlight is invoked from notification power widget fixed
- selectable 0, 90, 180, 270 orientation options to be enabled or disabled
- Toggle2G included again
- DatePicker fix (FC e.g. in GTasks app)
- etc
- etc
