[Diskussion] Cronos Froyo für das Milestone
  • 1.667 Antworten
Bleib lieber bei MIUI. Von diesem Look komme ich garnicht mehr weg:)
s-i.m.o-n schrieb:
Hats schon jemand probiert?
War von Cronos auf dem Hero schon echt begeistert.
Will nur micht laden um dannach wieder das Nandroid einzuspielen (Kein DSL)
Ist das Theme von oben Standart oder ein Update.zip?
update.zip!
Neue Version.
Cronos Froyo Milestone 1.7.0
by Feeyo » December 14th, 2010, 11:36 am
Here you go the latest Cronos Froyo Milestone 1.7.0 release.
Included latest Nadlabaks Fixes. Respect to him.
How to flash Cronos Roms:
1. Wipe
2. Flash ROM
3. reboot
4. Flash Hot Fix (If any)
5. reboot
6. flash kernel (If any updates)
7. reboot
Release notes:
14 Dec 2010 | Cronos froyo Milestone 1.7.0:
By Feeyo:
* Full new compile based on my completed toolchain.
* Fully updated Sources to latest.
* New DalvikVM Optimizations.
* Better Memory utilization.
* Latest GAPPS Added.
* LauncherPro 3D Cube fixed.
By Nadlabak:
* use prebuilt TI OMX libs, additional DSP libs.
* add MID camcorder video quality.
* expose AMR wideband audio encoder.
* add cpufreq_stats module
28 Nov 2010 | Milestone 1.6.1
* Recompilation: Battery Fix Try1.
26 Nov 2010 | Milestone 1.6.0 Update #1:
* Camera Improved.
* Fix for crash in PathBarLayer::recomputeComponents" Gallery3D.
25 Nov 2010 | Cronos Froyo 1.6.0:
* Full new compile based on my latest toolchain.
* Default Mail Client updated to support more IMAP + SSL
* getThumbnail memory leak fixed.
* Used JIT+ library optimizations.
* Sound Improvement.
* OpenCore improvements.
* SKIA (2D Render Engine) Improvements.
* New Kernel tweaks.
* Android System Tweaks.
* As always included CM external application sources.
* CM Parts are included default, but filtered and added as CM Extra in menu.
* A lot of DalvikVM changes. This bad boy is a monster now.
* Shutdown and Reboot Menu is now faster.
* Removed blending and blur, to speed up system.
* Fully optimized ARM flags compile.
* Allowed unaligned memory accesses on ARM targets that support it.
* Faster Z_HUFFMAN_ONLY and Z_RLE compression for images and other specialized compression.
* Latest GAPPS.
* Talking notification sounds.
* Default 700Mhz
* Included DroidReign app. We are officially supporting them.
Cronos Froyo Milestone 1.5.0:
* Fully cleaned the blob profile to make use of proprietary only and the rest are 100% compiled.
* Hopefully battery drain fixed.
* Fully updated to latest sources.
* Default 700Mhz
* Default governor "ondemand"
Cronos Froyo Milestone 1.4.0:
* Recompile everything again based on Nadlabaks vendor profile.
* Experimental java improvements
* Used JIT library optimizations.
* DalvikVM changes to give it a bit more speed.
* Big improvement to Performance V8 and Webkit.
* Latest gapps added.
* New Talking notification sounds
* Fixed Bluetooth.
* Set default speed to 700Mhz.
Please note: You do not need the 2.2.1 SBF flash anymore.
Download Cronos Froyo 1.7.0:
Main Mirror: Multiupload.com - upload your files to multiple file hosting sites!
APAC: http://www.gigasize.com/get.php?d=wr851nnrbsf
MD5SUM: 4f575c0d4d77d9c9a0d6b15303ebdfb3
Les mal ne Seite vorher, da wurde das schon gepostet.
und was ist da jetzt anders? Nix, würde ich sagen...
Vorsicht! Mit der neuen Version landet ihr in einem Bootloop!
youp - ich hab die Version von gestern drauf (1.7.0), die läuft 1a!!!
Bei mir läuft keine einzige.Bei Cronos ist das Trend:scared: zu
wenn Du magst, mach ich ein nandroid (ohne data) und lad es hoch...
Reaktionen: janosik
janosik schrieb:
Das wäre optimal.
Danke.:smile:
ok...:smile:
EDIT:
*Link entfernt*
- Cronos 1.7.0 als nandroid (1.45, ohne Data)
- gethemed (kalagas theme)
- Animations in framework (Gingerbread und andere...)
- OC 1000/56
- bootlogo 'M' ersetzt durch 'google' https://www.android-hilfe.de/forum/...eigt-her-euer-bootlogo.61249.html#post-837954
- bin mir nicht sicher, ob screen-PW noch aktiv, falls ja, hier das PW: 1qqqqqqq
bitte feedback dazu!!!
Anleitung:
- zip entpacken
- Ordner samt Inhalt nach /nandroid/Openrecovery auf der SD-Karte kopieren
- in die OR gehen
- Wipe Cache + Wipe dalvik (evtl. auch Full Wipe, müsst ihr testen)
- nandroid über OR restoren
Reaktionen: janosik
eybee1970 schrieb:
ok...:smile:
EDIT:
hier der Link (dauert noch mind. 45 min bis upload complete): http://dl.dropbox.com/u/15679153/Cronos1.7.0_16122010.zip
- OC 1000/56
@eybee1970, würde mir gern dein nandroid mal draufziehen. Leider funktioniert der Link nicht...
noch nicht...dauert noch 5 min ;)
EDIT: noch 2 min...
EDIT2: jetzt!
läuft in einen bootloop
-FuFu-
paysano
paysano
-FuFu-
LeoHart
mancloud
diloniga
diloniga
