Bandit
Enthusiast
- 723
Hab ich so oft und auch schon neu installiert. Welche Cronos Version haste laufen, 1.2.1? Mit dem neuen 10overclock und dem Governor Rumgefummel klappts irgendwie nimmer
w00kiee schrieb:Wie überprüfst du die Zeit? Unter SetCPU sieht man ja glaub ich keine Stats... Oder machst du das über die Kommandozeile, bspw. mit ConnectBot oder adb?
w00kiee schrieb:Yes, Android System can cause your phone to reboot spontaneously but often it is not that easy that only Android System is responsible for that and also other apps might be involved...
In Android System many applications are included that are used to control the system, e.g. control VPN services, accounts and syncs, basic system settings, location based services, ... Therefore you can't call it only 1 app...
Often also the OC is responsible for FC's and reboots because due to manufacturing tolerances each phone is different according to the vsel and the frequences that run stable. Maybe you can increase all vsel values in /system/etc/init.d/10overclock by 2 and test if the phone is more stable...
If this fixes your reboots but still Android System is displayed with a high percentage it is an indicator for a higher battery drain and needs further investigation... (e.g. not or badly optimized apps for 2.2)
