Thyrus
Gast
die groessten spionageapps sind:
com.guckichkongretrein.hesteone64.apk
com.istealyourbandwidth@fufu.apk
-FuFu- schrieb:
pssssst ich wollte mir doch noch ne apk machenaber jetzt installiert die bestimmt niemand mehr
und du hast die
com.thyrustakesoveryouphone.apk
vergessen![]()
hanschke schrieb:irgendwas mache ich falsch. und wieder hänge ich am bootscreen. dabei habe ich keine roten dienste oder so entfernt. eigentlich wie davor auch nicht.
bitte um hilfe!!! VeluxRacer schrieb:Es gehen 5 Werte, zumindest mit der overclock_71.sh
nadlabak schrieb:About the version:
Why do you ask here Thyrus and not me directly if you want to know the answer? Or you don't want to know it?
I build the platform after I do repo sync from CyanogenMod's Profile - GitHub
As I still use the sholes configuration that I've edited for the Milestone needs (until I finish the proper independent sholes_umts or mapphone configuration), this is what ended up in the build.prop after compilation:
ro.modversion=CyanogenMod-6.1.0-RC0-Droid
So that is what I called it. Only the Droid replaced with Milestone.
So if the 6.1.0-RC0 is a mistake and it should be 6.0.1-RC0, then such a mistake is not mine.
As I really don't have the time to read every post in every forum (and here Issue 5 - cyanogenmod4milestone - AGPS not working - Project Hosting on Google Code I explained why, I hope it's understandable), if you have important questions, ask them in the issue tracker or write me PM.
