hanschke
Gast
gut habe das in den optionen gesuccht. jetzt muss ich nur noch rausfinden warum ich da ein paar sounds habe die es nicht mal mehr geben sollte. hmm
D/MediaScannerService(29804): IMediaScannerService.scanFile: /mnt/sdcard/download/downloadfile-7.apk mimeType: application/vnd.android.package-archive
D/vending (29723): [23] LocalAssetDatabase.notifyListener(): 2831247920778603671 / INSTALLING
D/vending (29723): [23] VendingNotificationManager.showNotification(): Showing notification: [AssetID=2831247920778603671, NotificationID=-866985399, Title=Radiant Lite, Message=Installation...]
E/dalvikvm(29824): could not disable core file generation for pid 29824, errno=1
V/MediaProvider(29804): /mnt/sdcard volume ID: 1206326521
D/dalvikvm(29824): GC_EXPLICIT freed 770 objects / 55528 bytes in 117ms
D/dalvikvm(29804): GC_FOR_MALLOC freed 8600 objects / 501416 bytes in 89ms
I/PackageHelper(29824): Size of container 7 MB 5449955 bytes
D/dalvikvm(29804): GC_EXTERNAL_ALLOC freed 4449 objects / 212520 bytes in 54ms
E/PackageHelper(29824): Failed to create secure container smdl2tmp1
E/DefContainer(29824): Failed to create container smdl2tmp1
D/dalvikvm(17876): GC_EXPLICIT freed 11313 objects / 509168 bytes in 124ms
D/vending (29723): [16] LocalAssetDatabase.notifyListener(): 2831247920778603671 / INSTALL_FAILED
D/AccelerometerListener(17960): orientation: horizontal
D/vending (29723): [16] VendingNotificationManager.showNotification(): Showing notification: [AssetID=2831247920778603671, NotificationID=-866985399, Title=Radiant Lite, Message=Installation fehlgeschlagen.]
I/vending (29723): [16] AssetDownloader$DownloadManagerBroadcastReceiver$MyPackageInstallObserver.packageInstalled(): Package install from content://downloads/download/173 failed: Unknown reason -18
yanardag schrieb:Wie kann ich die hw tastatur wieder auf qwertz stellen?
OR killed das ganze system!!!
dodotech schrieb:soo Fazit![]()
Themes funktionieren , wenn du dir die original Framework.res.apk aus deinem System pulst und diese in Winrar öffnest ! Vom Theme die Themeordner in die originale framework , mit adb zurückschieben reboot freuen![]()
klappt bei mir perfekt und ist nicht wirklich viel Arbeit![]()
