WLAN > CM10-20130307 funktioniert nicht
  • 14 Antworten
my-defy
Ich verwende ein DEFY, Typ MB525 (nicht Defy+).
Alle Custom ROMs neuer als CM10-20130307 führen dazu, dass mein WLAN nicht mehr geht. Habe ebenfalls bereits KitKat CM11-20131210 ausprobiert mit leider gleichem Ergebnis.
Evtl. ein Problem mit dem Treiber?
Anbei ein Ausschnitt aus dmesg:
Code:
<6>[23320.710937] wl12xx: loaded
<6>[23321.707397] wl12xx: state: 0
<6>[23322.018829] wl12xx_driver wl12xx: firmware: requesting ti-connectivity/wl127x-fw-4-sr.bin
<6>[23322.309967] wl12xx: firmware booted (Rev 6.3.10.0.136)
<6>[23322.316986] ADDRCONF(NETDEV_UP): wlan0: link is not ready
<6>[23322.339874] wl12xx: state: 2
<6>[23322.340545] wl12xx: adding p2p mgmt vif
<6>[23322.347381] ADDRCONF(NETDEV_UP): p2p0: link is not ready
<7>[23324.378021] wlan0: authenticate with 00:19:cb:88:d8:78 (try 1)
<7>[23324.380157] wlan0: authenticated
<7>[23324.409454] wlan0: associate with 00:19:cb:88:d8:78 (try 1)
<7>[23324.604400] wlan0: associate with 00:19:cb:88:d8:78 (try 2)
<7>[23324.799713] wlan0: associate with 00:19:cb:88:d8:78 (try 3)
<7>[23324.995025] wlan0: associate with 00:19:cb:88:d8:78 (try 4)
<7>[23325.190246] wlan0: associate with 00:19:cb:88:d8:78 (try 5)
<7>[23325.385589] wlan0: association with 00:19:cb:88:d8:78 timed out
<7>[23327.456878] wlan0: authenticate with 00:19:cb:88:d8:78 (try 1)
<7>[23327.651214] wlan0: authenticate with 00:19:cb:88:d8:78 (try 2)
<7>[23327.846466] wlan0: authenticate with 00:19:cb:88:d8:78 (try 3)
<7>[23328.041778] wlan0: authenticate with 00:19:cb:88:d8:78 (try 4)
<7>[23328.237152] wlan0: authenticate with 00:19:cb:88:d8:78 (try 5)
<7>[23328.432434] wlan0: authentication with 00:19:cb:88:d8:78 timed out
<7>[23330.910461] wlan0: authenticate with 00:19:cb:88:d8:78 (try 1)
<7>[23330.911010] wlan0: authenticated
<3>[23332.940338] wl12xx: ERROR command complete timeout
<4>[23332.940368] ------------[ cut here ]------------
<4>[23332.940429] WARNING: at /media/quarx/home/trees/4.4-cm/hardware/ti/wlan/mac80211/compat_wl12xx/drivers/net/wireless/wl12xx/main.c:1432 wl12xx_queue_recovery_work+0x94/0xa0 [wl12xx]()
<4>[23332.940460] Modules linked in: wl12xx_sdio backlight symsearch overclock_defy cpufreq_stats wl12xx mac80211 cfg80211 compat cifs nls_utf8 modem_pm_driver netmux_linkdriver netmux [last unloaded: wl12xx_sdio]
<4>[23332.940551] [<c0038d70>] (unwind_backtrace+0x0/0xd8) from [<c0064228>] (warn_slowpath_common+0x4c/0x64)
<4>[23332.940582] [<c0064228>] (warn_slowpath_common+0x4c/0x64) from [<c0064258>] (warn_slowpath_null+0x18/0x1c)
<4>[23332.940612] [<c0064258>] (warn_slowpath_null+0x18/0x1c) from [<bf0dc340>] (wl12xx_queue_recovery_work+0x94/0xa0 [wl12xx])
<4>[23332.940673] [<bf0dc340>] (wl12xx_queue_recovery_work+0x94/0xa0 [wl12xx]) from [<bf0df7f0>] (wl1271_cmd_send+0x4c0/0x510 [wl12xx])
<4>[23332.940734] [<bf0df7f0>] (wl1271_cmd_send+0x4c0/0x510 [wl12xx]) from [<bf0df9ec>] (wl12xx_cmd_role_disable+0x88/0xec [wl12xx])
<4>[23332.940795] [<bf0df9ec>] (wl12xx_cmd_role_disable+0x88/0xec [wl12xx]) from [<bf0de50c>] (wl1271_op_bss_info_changed+0x4b0/0xca4 [wl12xx])
<4>[23332.940856] [<bf0de50c>] (wl1271_op_bss_info_changed+0x4b0/0xca4 [wl12xx]) from [<bf09a350>] (ieee80211_bss_info_change_notify+0x174/0x1ac [mac80211])
<4>[23332.940948] [<bf09a350>] (ieee80211_bss_info_change_notify+0x174/0x1ac [mac80211]) from [<bf0a99fc>] (__ieee80211_recalc_idle+0x114/0x708 [mac80211])
<4>[23332.941009] [<bf0a99fc>] (__ieee80211_recalc_idle+0x114/0x708 [mac80211]) from [<bf0aa98c>] (ieee80211_recalc_idle+0x1c/0x40 [mac80211])
<4>[23332.941070] [<bf0aa98c>] (ieee80211_recalc_idle+0x1c/0x40 [mac80211]) from [<bf0a7638>] (ieee80211_work_work+0x530/0x1268 [mac80211])
<4>[23332.941131] [<bf0a7638>] (ieee80211_work_work+0x530/0x1268 [mac80211]) from [<c00757ac>] (worker_thread+0x178/0x224)
<4>[23332.941162] [<c00757ac>] (worker_thread+0x178/0x224) from [<c0079120>] (kthread+0x78/0x80)
<4>[23332.941192] [<c0079120>] (kthread+0x78/0x80) from [<c003499c>] (kernel_thread_exit+0x0/0x8)
<4>[23332.941253] ---[ end trace 40ab67ce5adcf7d2 ]---
<3>[23332.941284] wl12xx: ERROR failed to initiate cmd role disable
<4>[23332.941284] wl12xx: WARNING idle mode change failed -110
<4>[23333.471588] wl12xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
<6>[23333.473388] wl12xx: watchdog interrupt received! continue with recovery
<6>[23333.473419] wl12xx: Reading FW panic log
<6>[23333.473693] wl12xx: Hardware recovery in progress. FW ver: Rev 6.3.10.0.136
<6>[23333.473785] wl12xx: pc: 0x181b8
<6>[23333.473846] wl12xx: removing interface f8:7b:7a:91:78:98
<6>[23333.473876] wl12xx: removing interface f8:7b:7a:91:78:97
<6>[23333.555297] ieee80211 phy3: Hardware restart was requested
Hat jemand eine Idee oder einen Tipp?
Danke und Gruß
In der ROM CM10-20130307 wird für den TI WLAN folgender Treiber verwendet:
/system/lib/modules/tiwlan_drv.ko
Danach wird in allen ROMs folgender Treiber eingesetzt:
/system/lib/modules/wl12xx.ko
Dies hilft mir aber leider noch nicht weiter.
Jemand einen Tipp?
Vielleicht dein Passwort zu lang oder komische Zeichen drin?
Oder dein Router verträgt sich nicht mit dem Defy
Nein, daran liegt es nicht.
Mit dem älteren ROM funktionierte WLAN ja.
Ich knüpfe hier an: Habe auf mein defy+ gestern zum ersten Mal ein custom-Rom aufgespielt (CanyogenMod 10-20131030-Nightly-mb526), und dort lies sich leider das wlan gar nicht erst einschalten(!) Alle wipes etc. wurden vorher ordnungsgemäß durchgeführt. Vorhin las ich diesen thread und installierte deshalb gleich die Version 20130307, ehe ich blind herumprobiere.
Ich bin an folgenden Informationen interessiert:
1. (Genau wie der Themenstarter): Welche Folgeversionen sind wlan-fehlerfrei?
2. Treten überhaupt bei allen defy/defy+ Geräten wlan-Fehler auf, oder läuft bei einigen oder den meisten die 10-20131030 fehlerfrei diesbezüglich?
3. Hat jemand, wie ich, überhaupt den gleichen Fehler: Also wlan lässt sich überhaupt nicht einschalten?
Danke für die Aufmerksamkeit.
Reaktionen: my-defy
Kann es nicht doch sein, dass das Problem am Router liegt anstatt an den ROM's?
Bei mir hat von Stock bis cm10.2 immer das WLAN funktioniert,
mein Problem ist leider, dass ich CM11 nicht zum Laufen bekomme.
Habt ihr es eventuell mal nachgesehen, ob es eine neue Firmware für eure Router gibt?
Vielleicht auch mal nur WPA2 anstatt WPA/WPA2 Verschlüsselung aktiviert?
Ich habe schon öfter gelesen, dass es zu Problemen mit der Verbindung kommt, wenn nicht nur eine Verschlüsselung eingestellt ist.
Bin momentan auf CM10.2
Schau eventuell mal in die erweiterten WLAN Einstellungen und schalte diese auf Bereich Europa.
@ExIphone: Ich weiß nicht, wen Du mit "ihr" meinst, aber bei mir ist es definitiv kein Router-Problem, weil sich mein wlan mit dem genannten cm gar nicht erst einschalten ließ, wie ich oben genaustens beschrieb.
@Badwater: Mmh, ich kann natürlich nur jetzt, bei der funktionierenen Version CM-10-20130307 nachsehen. Da ist gar kein Land markiert, und es geht trotzdem.
Meine drei Fragen bleiben bestehen.
@ Anno.Nüüm,
ich meine den Themenstarter und dich!
Was für einen Router (Hersteller und Version) nutzt Du den?
Mit welcher ROM (CM10, CM10.1 oder CM10.2) und welche Versionen (z.B. CM10.2 vom 02.02.2014) hast du es schon versucht?
Es ist wirklich nett, dass Du helfen willst, aber im meinen posts steht mehrfach, dass der Router irrelevant ist, weil sich das wlan meines Handys gar nicht erst einschalten lässt! Zum zweiten steht dort auch, dass es sich um CM10 handelt - genau wie das Thema des threads, auf dass ich mich bezog. Datum steht auch dazu. Bitte in meinem Fall nicht mehr nach dem Router fragen und Thematik aufmerksam lesen, weil das sonst nicht weiter hilft.
Mich interessieren weiter die Antworten / auch Teilantworten auf die 3 gestellten Fragen.
Hallo @Anno.Nüüm,
ich habe 3 DEFY+ und 1 DEFY bei mir im Haushalt.
Bei allen 3 DEFY+ funktioniert das WLAN mit irgendeinem ROM > CM10-20130307, auch CM11 funktioniert.
Leider funktioniert bei dem 1 DEFY WLAN mit keinem ROM nach dem 7.3.2013 ebenso CM 11 nicht.
Es liegt also definitiv nicht am Router, evtl. unterscheid sich der WLAN Chip in den Geräten und da nach dem 07.03. der Treiber gewechselt wurde, bleibt das Problem.
In den anderen Posts habe ich allerdings nicht gelesen, dass dies speziell ein Problem der Geräteversion (DEFY = MB525 bzw. DEFY+ = MB526) ist. Es scheint auch bei anderen aufzutauchen.
Es hilft dir vielleicht nicht zu einer Lösung, aber erklärt es.
Doch, das hilft mir erst einmal weiter; es wäre aber beauerlich, wenn bei meinem defy+ mit der CM10-20130307 Schluss wäre, denn diese funktioniert bei mir ebenfalls, was Dein Vorredner unter anderem irgendwie nicht verstanden hatte. Damit nochmal zu meiner ursprünglichen Frage 3: Ist es bei Deinem defy Dir auch so wie bei meinem defy+, dass sich das wlan gar nicht erst einschalten lässt (und damit ist klar, dass es nicht am Router liegen kann), oder lässt es sich einschalten und Du bekommst dann keine Verbindung zu einem wlan-Netzwerk hin?
Das WLAN am DEFY lässt sich teilweise schon einschalten, meldet aber dann grundsätzlich ein Authentifizierungsproblem oder sofortiges Disconnecting.
Bei XDA-developers gibt es dazu auch einen, ähnlich frustrierenden, Post:
Wifi "Connecting" on CM10 >march and CM11 - xda-developers
Aber eine Verbindung zum Router (ich habe hier auch verschiedene probiert) klappen nicht.
Sorry.
OK, dann ist es ein anderer Fehler als der von meinem wlan. Da rührte sich gar nichts beim Versuch, es zu aktivieren.
samdroit
jodu
ExIphone
