Matrix_
:::Beschreibung:::
Xperia D ist eine Sammlung von Mods, die das Defy wie ein Xperia wirken lassen. Der User mato_d007 von xda hat die Rom "just for fun" gemoddet. Die Rom basiert auf Quarx Nightly vom 10.01.2013.
Orginalthread von XDA.
:::Features:::
- Xperia Z leaked launcher fully functional
- Xperia Z widgets: Toggles, Weather, Top Contacts, Notes, Xperia Select widget, Walkman widget with particles effect, Album, Clocks, Calendar, Torch... etc
- Xperia Z/T Wallpapers
- Xperia T JB Keyboard (with swype, and many options)
- Xperia T JB appearance
- Sony Facebook integration fully functional (like a song in walkman, see your friends songs, see your online photos in album, etc) aka social engine (also twitter integration)
- Xperia Apps (Album, Movies, Walkman, Lounge, Calculator, Calendar, Notes, Sony select, etc)
- Walkman player with plug ins (Youtube, google search, Wikipedia) and:
- - Clear Audio+
- - Clear Bass
- - Clear Stereo
- - Clear Phase
- - Dynamic Normalizer
- - xLoud (Activated by default) can't settings xloud
- - Surround Sound VPT
- Iphone animations
- Crossbreeder 1.31.13
- Xperia JB bootanimation
- Bravia Engine 2 for Album & Movies (Nur in Album & Filme)
- Im Changelog steht mehr
:::Installation:::
- Download and copy the latest ROM zip to SD Card
- Reboot into Recovery Mode
- Select Wipe data and cache
- Select install zip from sd card
- Select choose zip from sd card
- Select the new ROM zip
- Select Yes - Install update
- Wait until the Installation is finish *IMPORTANT - DONT WIPE AFTER INSTALL THE ROM*
- Select reboot system now
- Wait 5-10 min
- Enjoy
:::Screens:::
:::Changelog:::
Xperia D 3.4
-New Google play services (fixes FC when installing/uninstalling apps)
-Updated SuperSU
-Added and option to change device fingerprint between Xperia Z (recommended) or Defy+ (choose this if you have problems with Whatsapp detecting your phone as a tablet)
-Automatic cache wipe after instalation
-Added an option to Sim-unlock the phone on Aroma -WARNING- its unstable and produces bootloops some times (specialy on first boot, remove battery and restart the phone in those cases) Not recommended.
-Updated Sony Select
-New Deskclock (Clock/Alarm app) fixed by YetAnotherForumUser (only the 4.1 version is fixed).
-Backported Quarx new camera app, with better performance. It re-opens faster when you close it.
-Added Optional Wallpapers
-New method to patch framework when iphone or fancy animations are selected
-Updated Twitter, Smart connect, TrackID, Adaway
-Added Chrome as optional on Aroma
-Added Call recorder app optional on Aroma
-Pre-configured lockscreen wallpaper from Xperia Z
-Animations speed set to x0.5, activated press back to kill app and disabled adb notification by default.
-Added an option on Aroma to activate Navbar (on screen buttons/soft buttons/Navigation bar) and automatic disable capacitive buttons and their backlight.
-New music visualizer app for Walkman from Xperia Z: No more FC and better performance. It works 100%
-Timescape is back! this time fully functional with Facebook and Twitter integration and all the widgets. Optional on Aroma.
Xperia D 3.3
-Fixed translations error
-Make calendar optional
-Added an option on Aroma to select a bootlogo:
*Original Sony bootlogo
*Motorola red, white and blue
*Keep current logo
-Added as optional JB 4.2 Clock
-Added Sony ICS SketchEF fonts as optional on Aroma
-Updated Facebook
-New Google Play services (with new features)
-Corrected some typos and errors under the hood
Xperia D 3.2
-Added Xperia Z camera sounds
-Updated SuperSU and Youtube
-Added a new optional dark theme for those who dont like the white dialer (this one is dark gray)
-Cleaned updater script
-Added both 4.1 and 4.2 native keyboard to choice on aroma
-Added an option on Aroma to choose transition animations between stock Jelly Bean, Iphone and Fancy.
-Added PlayStation mobile and maked Defy a certified Playstation phone
-Added an option on Aroma installer to pre-disable HWA for many common apps
-Fixed the bug where a selected ringtone for a particular contact will not be saved
-Added an option on Aroma installer to lock phone app on memory
-Updated Google Play to latest version (3.10.14)
Xperia D 3.1*
Same as 3.0 plus:
-Aroma installer instalation steps reduced
-Remade from scratch to make some cleaning
-Deleted Korean Nanum fonts
-Updated CM File Manager
-Added an option to select 4.1 or 4.2 camera on aroma installer
-Remaded iphone animations
-Added an option on Aroma installer to make Crossbreeder optional, so you can install seeder if you dont like it
-Cleaned and fixed many things on installer script and aroma config script
-Fixed music visualizer random FCs
-Fixed Facebook music like FC on Walkman
-Improved Social engine
-Fixed 3-way reboot not working on 3.0
-Fixed some missing permissions
Xperia D 3.0*
-Better toggles on notification drawer
-Aroma installer: now you can decide how much bloatware you want, and keep more free ram.
-New (optional) Xperia launcher by ra3al, based on Xperia T stock launcher, but with many customization options.
-Updated SuperSU, terminal emulator and google maps
-Fixed FC on Sony´s power widget (works only on Xperia launcher by ra3al)
-Added Android 4.2 photo editor, no more FC when you press the edit button. But it will FC when you hit save, so dont use the editor yet.
-Added Xperia Car Home
-Added Brainmaster Tweaks: zipaling, move dalvik cache, build.prop tweaks, etc. (Kayant´s version)
-Pre-disabled HWA for many common apps
-Free RAM after a reccomended instalation around 220mb
Xperia D 2.5
-Totally redone from scratch using new base: 20130117 UNOFFICIAL CM10 developed by Quarx and compiled by Sevenrock (thanks to both of them) this build has been reported better with battery magnament and "ringtone bug"
-Updated launcher (now is more smooth)
-Updated widgets
-JB 4.2 Camera with disabled photosphere (editor is not implemented, will give you a FC)
-Improved speed
-Improved location detection
-Removed K9 mail (is only used by timescape)
-Lockscreen wallpapaers from Xperia Z will be installed on sdcard
-Xperia Landscapes (a bravia engine demostration video) also on sdcard
-Free RAM after a clean instalation 180-200M
Xperia D 2.0.1
- Customized bootanimation
- Added SuperSU, replacing Superuser for better root magnament
- Added new Sony apps: TrackID, Xperia Link, Smart connect, Walkmate, Xperia Share, Power saver <---- Yay! more bloatware
- Removed sony´s torch app (CM10´s torch is more useful)
- Fixed "Updating-Android-on-every-boot" bug
- Added Xperia T JB system sounds and fonts
- Modified build.prop to make it look like an Xperia T (now you have VIP access on Xperia Lounge and Sony select) *you will see your phone as an Xperia T on Googleplay*
- Updated Social Engine (new Twitter integration)
- Replaced Sony´s calendar with Google´s
- Added new widgets: timer and world clock
- Added Xperia play Tetris
- More wallpapers from Xperia T JB
- Implemented Timescape, but with limited functionality. No facebook or twitter (not compatible with JB, but works fine on CM7 when i tested).
- Timescape Call log, messages, K9 mail and news feeds works.
- Fixed timescape annoying slow opening
- Timescape is provided as an add-on in a separate flashable zip, because is a very RAM hungry feature and i not recommend to use it (it makes the system laggy). In fact, i think its useless, but its just my opinion.
- Updated Weather widget
- Build.prop tweaks:
Increase photo and video recording quality
Increase jpg quality to 100%
Enable Quick Power-On mode to reduce boot-time
Phone Ringing Delay set to 0
Enable Adaptive Multi-Rate Wideband
3G tweaks
Conect speed tweaked
Lock Launcher on memory
Net Speed tweaks
Better scrolling
Better streaming
- Fixed red lens camera problem
- More things that i dont remember
Xperia D 1.0
- Initial release, based on Quarx CM10 20130110 nightly
::.Download:::
NEW -Xperia D 3.4 - 435MB, includes gapps and necesary apps for social engine + Xperia media installed on SD card + Kernel
4Shared
Google Drive
Torrent
MD5: 57FC1E1821198A7DD634AAC8E5B443D1
IMPORTANT - This is not a standard ROM, with so many features it will fill your /system partition and you will have to delete some things if you want to install another mod that you like. Also this ROM will install apps on your /data partition so you can delete the ones you dont like. Thats why you must do a full wipe BEFORE install this rom, and not after. If you wipe after install the rom, you will delete many of the apps that are important to make some features work.
NEW -Xperia D 3.3 - 390MB, includes gapps and necesary apps for social engine + Xperia media installed on SD card
Google Drive
4shared
Torrent
MD5: A5E64E80BA40B5FCCD7D87CCF7AFA0EC
NEW -Xperia D 3.2 - 388MB, includes gapps and necesary apps for social engine + Xperia media installed on SD card
Google Drive - Uploading
4shared - Uploading
Skydrive
Torrent
MD5: 1F6754052989A0017B50373D53B8DC64
Xperia D 3.1 - 312MB, includes gapps and necesary apps for social engine + Xperia media installed on SD card
Google Drive
Skydrive
Torrent
NEW -Xperia D 2.5 - 303MB, includes gapps and necesary apps for social engine + Xperia media installed on SD card
Google Drive
[COLOR="black"[URL="magnet:?xt=urn:btih:85707706A70EA6781465AE79467C187F1CDE687D&dn=Xperia%20D%202.5.zip&tr=udp%3a%2f%2ftracker.openbittorrent.com%3a80%2fannounce&tr=udp%3a%2f%2ftracker.publicbt.com%3a80%2fannounce"]]Torrent[/URL][/COLOR]
-Xperia D 2.0.1 - 276MB, includes gapps and necesary apps for social engine
Google Drive download
Torrent seeded by me (help me to seed if you can, thx)
-Timescape add-on (optional, only for 2.0.1)
Google drive downloa
