guenter1
Stamm-User
- 355
Bei mir schlug das interne Update vom 25. auf 30.4. fehl. komplettes ROM geflasht, erst mal alles gut.
guenter1 schrieb:Bei mir schlug das interne Update vom 25. auf 30.4. fehl. komplettes ROM geflasht, erst mal alles gut.
Quarx schrieb:Please check bugs #36,#34 and #32 with gapps from OP on next nightly.
I think they solved![]()
Updating partition details...
Full SELinux support is present.
Processing AOSP recovery commands...
Installing zip file '/sdcard//cmupdater//incremental-0c190b7ddd-ea244aaf55.zip'
Installing 'sdcard//cmupdater//incremental-0c190b7ddd-ea244aaf55.zip'...
Checking for MD5 file...
Skipping MD5 check: no MD5 file found
Verifying current system...
"/system/app/Provision.apk" has unexpected contents.
E:Error executing updater binary in zip '/sdcard//cmupdater//incremental-0c190b7ddd-ea244aaf55.zip'
E:Error installing zip file '/sdcard//cmupdater//incremental-0c190b7ddd-ea244aaf55.zip'
Done processing script file
Installing '/sdcard/Download/cm-11-20140503-NIGHTLY-mb526.zip'...
MD5 matched
Verifying zip signature...
Wiping cache...
Wiping dalvik-cache...
Wiping battd stats...
Finished installing KitKat for OMAP3 devices. Enjoy!
script succeeded: result was [/system]
Android is Upgrading...
Optimising app i out of n
Starting apps
Finishing boot.
