Fufu2
Stamm-User
- 987
Nachtrag wenn Empfang weg war (2x ) musste ich die Pin neu eingeben.
Positiv kein hacken läuft schön smooth.
peterpopel schrieb:Die automatische Wiederherstellung der WLAN Passwörter und Hintergrundbild und Apps.. Geht auch nicht-liegt das an den gapps? Oder weiß jemand wie es geht?
Blechd0se schrieb:Hello guys,
i just pushed v0.9.6. It has some pretty nice changes;
- Add Display Color Control (only available with recent kernels)
- Add Writeback driver control (only available with recent kernels)
- Add Control for free amount of ram (e.g. you can set 80 MB of free ram at all time, the kernel will try to keep it at least at this threshold)
- Add the "Set-on-Boot"-Feature thanks [MENTION=1892363]xdaid[/MENTION] !
- Add "low mem"-option for Kitkat devices
- Add basic multicore support (if you have a device with more than one cpu, Aero Control should display and set all values correct)
- Add reboot alert, if a sudden reboot was detected inform the user (requires a 3.x kernel, click here for a demo).
- Add language updates ( [MENTION=4514770]Husi10[/MENTION] for french, [MENTION=3897045]spear1403[/MENTION] for croatian, [MENTION=3629267]xanubisx[/MENTION] for spanish)
- Fix application would quite if back button was pressed
- Fix app would spam logcat when its not running in foreground
- Fix RefresherThread priority, for slightly better cpu handling
- Many more little fixes to give a overall better user experience
So all in all many new things in there. The biggest one is probably the new set on boot functionality which was originally developed by [MENTION=1892363]xdaid[/MENTION]. I just
enhanced it a bit. Also the new debugging features may help with our new 3.0 kernel. Many thanks to all contributors!
I hope you'll have as much fun playing with it as i making it.
Download
I will focus on the defy parts on the next update, so we can leave this alpha stage finally. If you have any suggestions regarding this or regarding the
app in general be sure to drop a small feedback post, thank you.![]()
splitti schrieb:Ich überlege gerade 4.4 zu testen, allerdings sind zwei Dinge enorm wichtig:
1. BT Verbindung zu einer BT GPS Mouse ist wichtig!
2. Apps müssen auf der microSD ausgelagert werden...
Hat schon jemand zu Punkt 1. Erfahrungen sammeln können? Ist Punkt 2. nun gefixt mit der neuen Version? Was ich lese eher nicht, oder?
eldoncamino schrieb:Kann evtl kurz jemand die downloadseite von blechdoses aero apk verlinken
Gesendet von meinem MB526 mit der Android-Hilfe.de App
