fairdroid
Stamm-User
- 886
fairdroid schrieb:Mach' nicht sowas!![]()
EbensoFight4Music schrieb:Schon bestellt![]()
carlo93 schrieb:Hi there,
i've just made a fresh build of cm-10.2.
If you want to try it on your defy, i'm sharing the link of the flashable zip.
Something you should know before flashing:
- Missing DefyPart App in Settings (i'll see if i can add it and share Settings.apk later)
- The zip file isn't signed, so you can't flash it with motorola stock recovery (i removed some files and added Dialer.apk). Use TWRP instead.
- Wipe dalvik/cache, otherwise you may encounter "not entering in Deep sleep" issue.
- Last, but not least, this build is not stable. If you are ok with Quarx build, and don't want possible troubles, stay on it.
I want to thank Kayant, for his help; and all devs for their useful posts, and mostly for their hard work.
LINK: cm-10.2-20130831-UNOFFICIAL-mb526.zip
Blechd0se schrieb:I guess its kind of the root. In some of my test cases i could reproduce it when the device was inappropriate shutted down, but thats really
hard to tell and not easy to debug.
Last time i checked you logcat i couldn't find any suspicious on the first sight.
Code:That's what I suspected. More evidence that the data corruption bug has nothing to do with zram or swap. Maybe it's not even a kernel problem?
Its probably kernel related, because its corrupting something. I did enable a safety flush a while back for kernel panic,
maybe i have to check it again.
Anyway, new nightly today!
Nothing really special, except for TRIM-Support
Changelog;
* Trim-Support for ext3/ext4, therefore enabled discard in ramdisk (e.g: fstrim -v /data )
* enabled back swap&zram because of popular demand
* small cleanups and fixes (check github for more)
I am tired so no more infos today, as always only tested on 4.2. Happy flashing![]()
fairdroid schrieb:Beim ersten Pin-Eingeben hatte ich auch einen Reboot. Dann noch ein Reboot ...
Aller schlechten Dinge sind drei ;-)
Mal abwarten ...
Edit: Jetzt bootet es sich gerade zu Tode sozusagen ...
Werde wohl wieder den Kernel vom 25.08. installieren und hoffen, dass es dann wieder so gut läuft wie vorher ...
Edit2: Beim Wipen von Cache und Dalvik-Cache kam die Meldung in TWRP, dass es nicht geklappt habe,
weil data nicht gemountet werden konnte ... Ääääh ...
Ok, scheint aber der vorherige Zustand soweit wieder hergestellt zu sein ...
Bin also wieder zurück auf den Kernel vom 25.08. von Blechdose.
carlo93 schrieb:Oh thanks :good:
It worked flawlessly!
I think it's DefyParts related, since i made no changes in the source.
Download this new Settings.apk (which comes with the above patch by Kayant), and push it in /system/app (with adb or your favourite file browser). Remember to change permission to rw-r--r-- ( chmod 0644 /system/app/Settings.apk )
You'll be able to use DefyParts app and tune the button brightness ( Settings > Device > Advanced ).
Please note, it's not a flashable zip. It's only an archive which contains the apk.
Fight4Music schrieb:Hier noch die Defyparts zum inoffiziellem build:
Dl-Link:
http://forum.xda-developers.com/attachment.php?attachmentid=2226202&d=1377987832
@Blechdose, welchen log hättest du gerne?![]()
fairdroid schrieb:Hi Blechdose!
Habe den neuen Kernel wg. sähnilääähr Befftlucht ;-) nochmal installiert.
Blieb dann ca. 20 Min. bei der "Android wird aktualisiert. Apps werden gestartet" - Phase hängen.
Batterie raus. Danach wurden noch mal 2 Apps aktualisiert und leider danach auch längere Zeit Hängenbleiben beim Cyanogenlogo.
Nochmal Batterie raus und leider wieder Hängenbleiben beim Cyanogenlogo ...
Insofern keine Logs möglich ...
Also wieder den Kernel vom 25.08. installiert. Was beim letzten Mal noch so geklappt hat, blieb diesmal ohne Erfolg beim Booten.
Also wieder die Unofficial-Rom von xdaid vom 23.08. neu installiert, den Kernel von Dir vom 25.08. oben drauf ... Alles natürlich immer schön
mit vorher und hinterher cache und dalvik-cache wipen ...
Leider kein Erfolg beim Booten. Mist Mist Mist. Nexus 4 bestellt ... ;-)
Nee, jetzt bleibt dann nur noch das defyfullwipe-zip und dann nochmal das vorherige von Vorne ... und TitaniumBackup-Backups wieder einspielen. Yeah ...
Na hoffentlich klappt es ...
Ach nee, erstmal probiere ich es noch mit einem Recovery ...
