[ROM] CyanogenMod 10.1 (Android 4.2) Nightly Builds
  • 971 Antworten
Kernelupdate
Blechd0se schrieb:
[MENTION=4442286]niksy+[/MENTION] thanks, i may want to check this later, some interesting stats.
[MENTION=3344838]ccav2000[/MENTION] did you have random reboots or other issues with my kernel? or is everything as it should? :D
[MENTION=4864817]Antiga Prime[/MENTION] sounds wired, i will check this too after two days of idling.
[MENTION=4916555]okij[/MENTION] yeah its much more fun to talk about development in a development thread with some great feedback ;)
According to [MENTION=513620]Quarx[/MENTION] Swap may be the fault of those data loss, but i am not 100% since i changed something in zram
so it actually has to use swap and published my kernel, however i haven't seen much complains about data loss with my kernel
(am i wrong?). So i am only guessing its something totally different.
I just wanted to push another build anyway (compiling it in 2 minutes is just awesome), so you can test and see for yourself, the small changelog;
* fixed some warnings in zram for android
* enabled ram_console and patched it with upstream patches
* enabled swap
The last point is quite interesting, if you get a reboot or something similiar, please check if /proc/last_kmsg exists and if
it contains something usefull send me a pm or whatever. If this android feature works, development will be much easier for
Quarx or me.
Downloadlink
http://forum.xda-developers.com/attachment.php?attachmentid=2118877&d=1373920667
Reaktionen: HammDefy und fairdroid
Habe den neuen Kernel gerade installiert.
Weiss jemand, was "enabled swap" bedeutet?
Swap wurde deaktiviert, da es die Vermutung gab, das swap zum data loss führt, um das zu prüfen wurde swap aktiviert.
Hab mir mit swapper mal ein 500mb swapfile angelegt, mal sehen ob's hilft :)
Reaktionen: fairdroid
Hab den neuen Kernel auch drauf. Hab den zram noch auf 26 stehen, soll ich ihn lieber wieder runter drehen auf 18?
Das ist jetzt eher für fachleute oder?
@dotzi75:
Laut Fight4Music wird die Rom mit zram mit 26% noch etwas "snappier". Kann ich bestätigen.
@Fight4Music: Ok, heisst, jetzt kann man mit einem swapfile arbeiten. Werde ich auch mal probieren gleich ...
Reaktionen: Fight4Music
Also bis jetzt keine Probleme mit dem neuen Kernel, mal bis morgen abwarten. Laß den zram erstmal bei 26. Läuft 1a!:biggrin:
Swap angelegt mit 256MB, nix Auffälliges momentan ...
Reaktionen: HammDefy, kopimo und Fight4Music
Hatte grad nen Reboot, das Telefon wurde aufgrund eines Modemfehlers neu gestartet stand da! Hatte ich vor ein paar Tagen schon mal. Bekannter Bug?
Gesendet von meinem MB526 mit der Android-Hilfe.de App
Reaktionen: kopimo
Hey endlich infos dazu danke obwohl es bei mir jetzt besser funzt
Reaktionen: kopimo
Hallo Defy Liebhaber,
Was kann der neue Kernel?
Ich teste gerne aber mein Defy läuft gerade wie ausgewechselt.Kein Reboot seit 10.7.
Nichts was mich ärgert es ist flüssig ,schnell u.bis jetzt super zuverlässig!
Drum meine Frage was soll sich verbessern?:confused:
Reaktionen: kopimo
Hi, zusammen,
mehr Berichte bitte...
Hab gerade die V2 vom 09.07. inkl Blechdose geflashed mit Wipe. Habe ab Version 26.06. alle Versionen der Reihe nach geflashed = immer wieder "Warten auf App" "App reagiert nicht" ...
Habe dann mehrmals die V2 vom 09.07. geflashed mit Wipes. Auch mit dem Kernel von Blechdose. Ergebnis auch wieder "App reagiert nicht". Bei Facebook, WhatsApp, etc...
Mal schauen, vll regelt sich das noch nach Reboots oder ich muss mal kompletten Reset machen...
Reaktionen: kopimo
@JuggedHareBoy
Hi, könntest Du kurz schreiben wie es ausgegangen ist?
Gruß, Thomas
Scheiße... :-/ Bin gerade beim neuflashen...
Wollte FactoryReset machen, habe dafür schon den Reset im Recovery durchgeführt. Da ich das immer ohne Akkudeckel mache und ich das Handy doof zur Seite gelegt hatte, ist das Akku rausgerutscht! Hmm klasse, da hing es beim Motorola M.
Jetzt habe ich dieselbe SBF wie damals (DPF...rooted) geflasht und dort hängt es auch im Motorola M...
Boote doch mal ins Stock Recovery, dort Factory Reset & dann die SBF flashen :)
Reaktionen: fairdroid und JuggedHareBoy
Hallo ist halb so wild ,lass dir Zeit u.bügle die Sbf drüber dann den Rest.Ich glaub das ist jedem schon passiert.Mir ist damals der Akku untern Schrank geflogen super .Muste den Schrank halb ausräumen um ihn zu kriegen.
Nur Mut es lohnt sich
Jetzt läuft die geroote SBF schonmal ;) Aber erstmal laden! Durch das ganze hin und her bin ich auf 50% gerutscht...
Aber die V2 vom 09.07. ist schon die aktuellste/richtige?
So, die gerootete SBF läuft...jetzt brauche ich noch 2ndInit...ist 2.3 das aktuellste?
Eine aktuellere kenne ich nicht. Aber ist egal. Die CM bringt ja dann ein eigenes Custom recovery mit...
Reaktionen: JuggedHareBoy
samdroit
Fight4Music
  • Angepinnt
  • Fight4Music
45 46 47
Axel.B.
ExIphone
