Fight4Music
Ehrenmitglied
- 2.870
- Themenstarter
- #721
pippen schrieb:Jetzt ist die nightly vom 09.07. schon wieder weg...
V2 online
http://quarx2k.ru/cm10.1-nightly-defy+/2.6.32/cm-10.1-20130709-NIGHTLY_v2-mb526.zip
Tatsache, Absicht oder aus versehen, das ist die Frage.. mal abwarten
Hier das statement
Quarx schrieb:CONFIG_SWAP affect on zRam/zCache...
I disabled CONFIG_SWAP, this option has some problem which can cause random data loss, infinity cyanogen logo etc.(even when swap not used).
Who want use ZRAM and other experimental features, can install [MENTION=4855459]Blechd0se[/MENTION]'s kernel. Until it's not will be stable.
I re-uploaded today build. Again some cyanogen commits broke our codecs, but fixed in "v2".
Hier trotzdem der Changelog
@fpriot schrieb:As usual, here is the 07-09 Quarx's build changelog from github (global CM10.1 updates and kernel updates) :
* Misc translations
* [AeroKernel] :
- fix compile
- tracing: Fix undeclared ENOSYS in include/linux/tracepoint.h
- tracepoints: Add check trace callback type
- remove cpcap audio spam
- clean defconfig
- LOAD_FREQ (4*HZ+61) avoids loadavg Moire
- Revert "disable SWAP, can cause data loss(test)"
* [android_device_moto_jordan-common]
- update egl configs
- update overclock config
- disable 2nd-boot-uart mode for public builds
- update OC script
* [android_frameworks_base]
- NotificationManager : Fix security exception
- Merge "Don't consider input restricted when the lockscreen is disable
- Merge "Add option to hide music controls in lockscreen."
* [android_system_core]
- Merge "Fixed reversed output in netstat Recv-Q Send-Q columns"
- lolcat
* [android_frameworks_opt_telephony]
- Merge "Revert "CallTracker: Add delay to reduce cpu load""
- Merge "CallTracker: Add additional check for pendingMO to verify that
* [android_packages_apps_Settings]
- Merge "Settings: privacy Guard enhance app logic"
* [android_packages_apps_Phone]
- Phone: Disable accelerometer sensor while in-call and screen UI is off
- Merge "Add android.permission.INTERCEPT_SMS permission."
* [android_frameworks_av]
- Merge "Camera: Add more htc parameters"
- Fix includes for media-caf
* [android_external_bootmenu]
- fix OC settings, add SCHED option, resort options, remove unused opti
- clean code
Falls jemand auf 09.07 v2 den Blechd0se Kernel von gestern nutzt, gibts hier dem Kernel vom Build 09.07 v2
http://www66.zippyshare.com/v/95316537/file.html
