vonLeitn
Das neue MS2Ginger 4.0 von Walter79:
Ich hafte nicht für Beschädigungen an deinem Telefon
Big thanks to: iaio72, spear1403, tgzw, Quarx, Simondo, ein1002, santimanuel, epsylon3 and ...
MS2Ginger 4.0
- based on 4.5.2-109-DHT-25 - Android 2.3.6 blur lite rom
- support for Defy, Defy+, Milestone 2, Bravo
- MS2Ginger4 can used as 2nd-system (tested on GB kernel only) !! system image file have to be >= 350 MB
- multibootmanger app by royale1223
- new bootmenu 1.1.8, CWM 5.0.5/6, multiboot big thanks to m11kkaa
- 2 way to boot the rom: normal and via 2nd-init (default)
- new reboot option form cm7.2 --> trigger: all keys at the same time vol- , vol+ , power (only tested on Defy)
- disabled blurhome rotation
- button backlight can set from 10-100 % via build.prop
- mmcfix from CM7
- CPU settings default safe 30/300 38/600 {48/800} 58/1000
- Camera will work on SOC and Bayer camera (green* and red)
- better camera support for bayer camera
- new 720p record* and play (Milestone 2 - Android 2.3.6 files)
- 720p record in m4v (h264 can be enabled via build.prop)
- Milestone 2 froyo camara app for SOC camera (fixed green strips)
- BlurHome from Milestone 2 - 2.3.6 (no widget updating bug)
- Battery min. 2-5 mA/h
- no wifi, apn, vpn bugs
- wifi channels 12, 13, 14 enabled
- bootmenu + cwm (vsel4/clk4 added) "did not work for SOC camera with greenbreadMOD"
- bootmenu with Stable, Custom, Stock-Recovery
- call record libs
- init.d support
- zipalign at boot
- ramscript
- backlight button fix for Defy with bayer camera (can removed via optional patch)
- deepsleep support
- max 10 finger multitouch
- support for farsi-arabic, hebrew (thanks to MMarv)
- CyanogenMod-settings not finished (alpha) - sorry, will try to fix it if i have more time.
(* via greenbreadmod for MS2Ginger4.0 and if you never flashed a Android 2.3.6 full sbf with bl7)
(* 720p record only for Bayer camera Defy and Milestone 2)
Download: ROM, BlurApps, Greenbread: (MS2Ginger4.0.zip, BlurApps-MS2Ginger4.zip, MS2Ginger4-greenbread-with-3.4.2-179-kernel.zip, MS2Ginger4-greenbread-witout-kernel.zip, 4.5.3-109-DPP-11-gingerbread-BL5-kernel.zip)
Mirror 1 (google)
Mirror 2 (Dev-Host)
Mehr Information zu den BlurApps --> LINK
Soft-sim-unlock for MS2Ginger 4.0
based on Dabb guide: [GUIDE] Soft Unlocking Defy with CM7.1 and Debricking Defy - xda-developers
Install Anhang 1129769 via CWM.
If you like MS2Ginger feel free to donate!
Bugs und Probleme Reporting: Issues - ms2ginger - Custom Android rom - Google Project Hosting
- wifi bug wie in allen 2.3.6 Motorola roms [Solved]Wifi problem with all Motorola Android 2.3.6 rom - xda-developers
(fix, deaktiviert "unlimited lease time for IP adress" in eurem Router)
HOW to INSTALL, Bitte alles lesen !!!:
Zu Beginn:
*2 This GreenbreadMod will only works with MS2Ginger4.0
Für alle Defy and Defy+
Defy with bayer (red) camera and Froyo kernel:
Defy Defy with soc (green) camera and Froyo kernel:
Timeline:
2012.06.19 - added MS2Ginger 4.0
2012.06.14 - added soft-simunlock for MS2Gigner 4
2012.04.25 - fixed GreenbreadMod for MS2Ginger 4 beta 4 working now
2012.04.25 - GreenbreadMod for MS2Ginger 4 beta 4 - no bootanimation
2012.04.21 - BlurApps update.zip for MS2Ginger 4
2012.04.11 - MS2Ginger 4.0 beta 4 released
2012.03.05 - MS2Ginger - new bug reporting system: Issues - ms2ginger - Custom Android rom - Google Project Hosting
2012.02.26 - MS2Ginger - Blurhome 2 3d update 4shared.com - free file sharing and storage
2012.02.05 - MS2Ginger 3.0 release
Team:
- walter79
- spear1403 (theming)
- santiemanuel
- Defy red lens tests spear1403
- Defy greens lens tests luciferps and Cristi_10
- Defy plus tests Dollo73 and free2live
- Milestone 2 tests Carolinux and Motodoido
Translation Team: (each language max. 4 person) Anhang 806172
Brazillian Portuguese: pupiloalpha , Cassinander , filipeazev
Bulgarian Auris 1.6 vvt-i
Farsi: MMarv
Hungarian: szabof1 , balika01
Polish: yackoo , szacuken , Antszej
Serbian: atomskasarma
Spanish espaciosalter20
Spanish-Argentina YaPeL
FIXED SBFs / kernel
Defy/Defy+ - 4.5.2-109-DHT-22-fixed.sbf: Mirror 1 (google)
Defy red/Defy+ - 4.5.2-109_DHT-22 kernel only: Anhang 804956 (latest kernel) recalibrate your battery after this update
Defy/Defy+ - 4.5.3-109fixed.sbf: Mirror 1 (google)
Defy red lens / Defy+ - 4.5.3-109fixed.sbf via install zip from sdcard in CWM-recovery:
Anhang 794187
Milestone2-4.5.3-109fixed-sbf Download Mirror 1 (google)
Changlogs:
http://forum.xda-developers.com/show....php?t=1140839
__________________
http://sites.google.com/site/rhobuntu/
Alter Teil des Posts:
Ich darf euch hier zwei Custom Roms von Walter79 vorstellen!
Ich habe lediglich die Batteriekomponenten und das boot.img mit dem Kernel ausgetauscht, wie von Walter79 vorgeschlagen. Anschließend ein neues Backup gemacht und hier hochgeladen
Mit diesem Rom funktioniert die Batterie vollkommen normal wie im Defy+ Stock-Rom.
Achtung: Diese Version ist nicht aktuell, neue(3.0) ist hier zu finden!
https://www.android-hilfe.de/forum/...efy.577/ms2ginger-3-0-bugsammlung.203799.html
Gingerbread Multi Editon 19.11.2011 und Lite Edition 02.11.2011:
MS2Ginger 2.1 - Multilanguage Editon Blur 19.11.2011:
- rom basiert auf dem 4.5.2-109 Defy+
- undervolted (30/300 38/600 48/800 58/1000), wenn Ihr Probleme habt, stellt es zuerst ab.
- Sprachen: ger, it, pt, nl, fr, es, gb, us, ch, tw and more
- !! Bootmenu 1.0.4 and CWM-recovery 5.0.3.1 !! Danke dem Defy CM7 Team
- !!! Für Blur SocialNetworkAccounts braucht Ihr einen Blur-Account oder Ihr flasht den "no bluraccount patch" MS2Ginger2.1-nobluraccount.zip
- 720p mit der Stock-Kamera App (red lens + defy+) mpeq4/m4v codec only
- Anrufaufnahme funktioniert mit 3rd party apps aus dem Market. (total recorder)
- init.d ready
- zipalign @ boot
- multitouch > 2
- deodexed
- panorama mode für die Kamera
- 1% Batterieanzeige Schritte
- Keine ultra hellen Button auf dem Defy (red lens) und dem Defy+
- Power menu mit Sleep Mode and Reboot . WICHTIG: Wenn Ihr den Sleep Mode verwenden wollt, stellt sicher dass das Telefon nicht mit Ladegerät oder mit einem Computer per USB verbunden ist! Es verursacht sonst einen FC und es fehlt anschließend der Lockscreen! (Kann mit wipe data im CWM Menü behoben werden).
- Sleep Mode schaltet WLAN Verbindungen ab, und deaktiviert die Tasten, zum aufwecken des Telefons drückt 4 Sec. die Power-Taste.
Screenshots: xda-developers - View Single Post - [ROM]MS2Froyo 2.2.2 and MS2Ginger 2.3.4 (01.08.2011) blur, 720p record
Download: MS2Ginger2.1-Defy+ Edition: Multiupoload.com
Installationsanleitung
Außerdem gibt es die noch Defy+ Lite Editon 2.0 :Multiupload.com (ADW Launcher, viele Motorola Apps entfernt, Calender Fix breits installiert) ACHTUNG! Bei der Lite Edition muss die App Prefixer konfiguriert werden !!
Vorhandener Fehler und Patches:
- Panorama FC --> fix MS2Ginger2.0-panorama-fix.zip via CWM einspielen
!! weitere Patches findet ihr im XDA Thread !!
Changlogs:
Bitte bei den Xda-developers.com schauen.
Der besondere Dank gilt Walter79 für sein Rom.
Alte Versionen:
Download MS2Ginger 2.0: Multiupload.com
Download Lite Editon 1.0 : Multiupload.com (ADW Launcher, viele Motorola Apps entfernt) ACHTUNG! Bei der Lite Edition muss die App Prefixer konfiguriert werden !!
Fotos von der "Lite 1.0" - Edition:
MS2Ginger 4.0
- mmcfix from CM7
- call record libs
- init.d support
- zipalign at boot
- ramscript
- deepsleep support
Mirror 1 (google)
Mirror 2 (Dev-Host)
Zu Beginn:
- Gilt für alle Defy and Defy+: Kopiert den Nandroid backup Ordner MS2Ginger in diesen Ordner auf der SDCard : /sdcard/clockworkmod/backup
- Für ein Defy mit bayer (red) Kamera und Froyo kernel: Kopiert "4.5.3-109-DPP-11-gingerbread-BL5-kernel.zip"*1 auf die sdcard
- Für ein Defy mit soc (green) Kamera und Froyo kernel: Put "MS2Ginger4.0-Greenbread-......zip"*2 to the root of your sdcard
- Installiert ein Froyo- oder Gingerbread Motorola rom
- Root your DEFY and Install BOOTMENU - CWM (2ndInit-Installer 2.0.apk (CWM-Recovery >5.0.3.1 wird benötigt)
- REBOOT
- Startet das Bootmenu (voldown on blue LED)
- Geht zu "Recovery"
- Geht zu "Latest or Stable or Custom Recovery"
- "wipe data and cache"
- Geht zu "Backup and Restore"
- Geht zu "Advance Restore"
- Wähle "MS2Ginger4.0"
- "restore system"
- Geht zu "install zip from sdcard"
- Auswählen und installieren "4.5.3-109-DPP-11-gingerbread-BL5-kernel.zip"
- Auswählen und installieren "MS2Ginger4.0-Greenbread-......zip" via install zip"
- Auswählen und installieren "Defy+battery.zip"
Timeline:
Team:
- walter79
- santiemanuel
Farsi: MMarv
FIXED SBFs / kernel
Anhang 794187
Changlogs:
__________________
- init.d ready
- zipalign @ boot
- multitouch > 2
- deodexed
- Basis ist das offiziele Stock-ROM (Sollte Ihr schon ein gerootetes Gingerbread mit 2nd-init installiert haben gehts weiter mit Schritt 4)
- Ihr müsst das Gerät rooten.
- Installiert CWM via 2nd-init vom Market.
- Reboot und geht ins 2nd-init Menü (Lautstärke runter Taste wenn die blaue LED erscheint)
- "Recovery" auswählen
- "Custom Recovery" auswählen
- "Wipe data" auswählen
- "Install zip - Bootmenu-Update" auswählen und dort die Datei:
bootmenu1.0.4+CWM5.0.3.1.zip
- REBOOT, sofort wieder ins 2nd-init Menü
- "Backup and Restore" auswählen
- "Restore" (system+data) auswählen
- Wählt "Ms2ginger-Nandroid Backup Verzeichnis" und bestätigt
- Reboot. Das erste Booten kann etwas dauern. (max 10 Min.)
- Ladet das Telefon auf 100% auf und last es noch 1 Stunde am Ladegerät.
- Kalibiert die Batterie mit dem vorinstallierten App!
Changlogs:
Alte Versionen:
