[Custom ROM][GB]19.06.2012 - MS2Ginger, Android 2.3.6, 720p record, Panorama
  • 348 Antworten
Soll diese Version deblured werden
  • Ja
    Stimmen: 14 66,7%
  • Nein
    Stimmen: 7 33,3%
  • Umfrageteilnehmer
    21
  • Umfrage geschlossen .
walter79
Ich hafte nicht für Beschädigungen an deinem Telefon
Big thanks to: iaio72, spear1403, tgzw, Quarx, Simondo, ein1002, santimanuel, epsylon3 and ...
MS2Ginger 4.0
- based on 4.5.2-109-DHT-25 - Android 2.3.6 blur lite rom
- support for Defy, Defy+, Milestone 2, Bravo
- MS2Ginger4 can used as 2nd-system (tested on GB kernel only) !! system image file have to be >= 350 MB
- multibootmanger app by royale1223
- new bootmenu 1.1.8, CWM 5.0.5/6, multiboot big thanks to m11kkaa
- 2 way to boot the rom: normal and via 2nd-init (default)
- new reboot option form cm7.2 --> trigger: all keys at the same time vol- , vol+ , power (only tested on Defy)
- disabled blurhome rotation
- button backlight can set from 10-100 % via build.prop
- mmcfix from CM7
- CPU settings default safe 30/300 38/600 {48/800} 58/1000
- Camera will work on SOC and Bayer camera (green* and red)
- better camera support for bayer camera
- new 720p record* and play (Milestone 2 - Android 2.3.6 files)
- 720p record in m4v (h264 can be enabled via build.prop)
- Milestone 2 froyo camara app for SOC camera (fixed green strips)
- BlurHome from Milestone 2 - 2.3.6 (no widget updating bug)
- Battery min. 2-5 mA/h
- no wifi, apn, vpn bugs
- wifi channels 12, 13, 14 enabled
- bootmenu + cwm (vsel4/clk4 added) "did not work for SOC camera with greenbreadMOD"
- bootmenu with Stable, Custom, Stock-Recovery
- call record libs
- init.d support
- zipalign at boot
- ramscript
- backlight button fix for Defy with bayer camera (can removed via optional patch)
- deepsleep support
- max 10 finger multitouch
- support for farsi-arabic, hebrew (thanks to MMarv)
- CyanogenMod-settings not finished (alpha) - sorry, will try to fix it if i have more time.
(* via greenbreadmod for MS2Ginger4.0 and if you never flashed a Android 2.3.6 full sbf with bl7)
(* 720p record only for Bayer camera Defy and Milestone 2)
Download: ROM, BlurApps, Greenbread: (MS2Ginger4.0.zip, BlurApps-MS2Ginger4.zip, MS2Ginger4-greenbread-with-3.4.2-179-kernel.zip, MS2Ginger4-greenbread-witout-kernel.zip, 4.5.3-109-DPP-11-gingerbread-BL5-kernel.zip)
Mirror 1 (google)
Mirror 2 (Dev-Host)
Mehr Information zu den BlurApps --> LINK
Soft-sim-unlock for MS2Ginger 4.0
based on Dabb guide: [GUIDE] Soft Unlocking Defy with CM7.1 and Debricking Defy - xda-developers
Install Anhang anzeigen 1129769 via CWM.
If you like MS2Ginger feel free to donate!
Bugs und Probleme Reporting: Issues - ms2ginger - Custom Android rom - Google Project Hosting
- wifi bug wie in allen 2.3.6 Motorola roms [Solved]Wifi problem with all Motorola Android 2.3.6 rom - xda-developers
(fix, deaktiviert "unlimited lease time for IP adress" in eurem Router)
HOW to INSTALL, Bitte alles lesen !!!:
Zu Beginn:
  1. Gilt für alle Defy and Defy+: Kopiert den Nandroid backup Ordner MS2Ginger in diesen Ordner auf der SDCard : /sdcard/clockworkmod/backup
  2. Für ein Defy mit bayer (red) Kamera und Froyo kernel: Kopiert "4.5.3-109-DPP-11-gingerbread-BL5-kernel.zip"*1 auf die sdcard
  3. Für ein Defy mit soc (green) Kamera und Froyo kernel: Put "MS2Ginger4.0-Greenbread-......zip"*2 to the root of your sdcard
*1 best for battery, for dualboot with CM7/9 GB-kernel install Defy-4.5.2.109-DHT-22-gingerbread-BL5-kernel.zip
*2 This GreenbreadMod will only works with MS2Ginger4.0
Für alle Defy and Defy+
  1. Installiert ein Froyo- oder Gingerbread Motorola rom
  2. Root your DEFY and Install BOOTMENU - CWM (2ndInit-Installer 2.0.apk (CWM-Recovery >5.0.3.1 wird benötigt)
  3. REBOOT
  4. Startet das Bootmenu (voldown on blue LED)
  5. Geht zu "Recovery"
  6. Geht zu "Latest or Stable or Custom Recovery"
  7. "wipe data and cache"
  8. Geht zu "Backup and Restore"
  9. Geht zu "Advance Restore"
  10. Wähle "MS2Ginger4.0"
  11. "restore system"
Defy with bayer (red) camera and Froyo kernel:
  1. Geht zu "install zip from sdcard"
  2. Auswählen und installieren "4.5.3-109-DPP-11-gingerbread-BL5-kernel.zip"
Defy Defy with soc (green) camera and Froyo kernel:
  2. Auswählen und installieren "MS2Ginger4.0-Greenbread-......zip" via install zip"
Defy+ and Defy with battery from Defy+ works only with GB-kernel
  2. Auswählen und installieren "Defy+battery.zip"
Timeline:
2012.06.19 - added MS2Ginger 4.0
2012.06.14 - added soft-simunlock for MS2Gigner 4
2012.04.25 - fixed GreenbreadMod for MS2Ginger 4 beta 4 working now
2012.04.25 - GreenbreadMod for MS2Ginger 4 beta 4 - no bootanimation
2012.04.21 - BlurApps update.zip for MS2Ginger 4
2012.04.11 - MS2Ginger 4.0 beta 4 released
2012.03.05 - MS2Ginger - new bug reporting system: Issues - ms2ginger - Custom Android rom - Google Project Hosting
2012.02.26 - MS2Ginger - Blurhome 2 3d update 4shared.com - free file sharing and storage
2012.02.05 - MS2Ginger 3.0 release
Team:
- walter79
- spear1403 (theming)
- santiemanuel
- Defy red lens tests spear1403
- Defy greens lens tests luciferps and Cristi_10
- Defy plus tests Dollo73 and free2live
- Milestone 2 tests Carolinux and Motodoido
Translation Team: (each language max. 4 person) Anhang anzeigen 806172
Brazillian Portuguese: pupiloalpha , Cassinander , filipeazev
Bulgarian Auris 1.6 vvt-i
Farsi: MMarv
Hungarian: szabof1 , balika01
Polish: yackoo , szacuken , Antszej
Serbian: atomskasarma
Spanish espaciosalter20
Spanish-Argentina YaPeL
FIXED SBFs / kernel
Defy/Defy+ - 4.5.2-109-DHT-22-fixed.sbf: Mirror 1 (google)
Defy red/Defy+ - 4.5.2-109_DHT-22 kernel only: Anhang anzeigen 804956 (latest kernel) recalibrate your battery after this update
Defy/Defy+ - 4.5.3-109fixed.sbf: Mirror 1 (google)
Defy red lens / Defy+ - 4.5.3-109fixed.sbf via install zip from sdcard in CWM-recovery:
Milestone2-4.5.3-109fixed-sbf Download Mirror 1 (google)
Changlogs:
Bitte bei den Xda-developers.com schauen.​
http://forum.xda-developers.com/show....php?t=1140839
  • MS2Ginger2.1-nobluraccount.zip
  • GreenBread_1.1_For-MS2Ginger2.1.zip
Reaktionen: funtik.m, Ironic, Michiii und 29 andere
kann die mal bitte jemand testen? :D wäre schwer angetan davon wenn die auch noch richtig speed hätte :]
1% Batterie update.zip ist online. Siehe ersten Post.
matjeshering schrieb:
Du zum Beispiel?
Selbst ist die Frau, kennst du bestimmt.
Die Froyo Version wurde schon >7000 mal runtergeladen.
....und hoch damit an die Pinnwand :thumbsup:
Danke. Brauche noch Hilfe beim hinzufügen der Deutschen Sprache, Blur-Facebook und irgendwie will das FM Radio nicht. Wer kann helfen?
Coole Sache. Allerdings kriege ich Swype (die CEE Version hier aus dem Forum) nicht auf Deutsch getrimmt -trotz Morelocale2.
Außer einigen chinesischen "leftovers" jedoch ein interessantes ROM.
Probier mal die Swype Version aus dem GB ROM 4.3.1-134 rom.
Offen gesprochen habe ich keine Ahnung wie ich das hinkriegen kann.
Habe die ROM nun mal installiert.
Erster Eindruck; schön, allerdings startete das Defy plötzlich durch. Falls es noch einmal vorkommt werde ich noch mal Bescheid geben.
Mir gefällt die neue Blur Oberfläche. Ich habe ein Defy mit einer grünen Linse, habe also den GreenBread Mod noch installiert. Mir ist trotzdem aufgefallen das nach einem Foto die FotoApp ein wneig hängt.
So viel mal zu meinem ersten Eindruck. Melde mich wieder...
@ Walter79: Gut hast´s gemacht ;)
Edit 1: Kann man das Tastaturlayout auf QWERTZ umstellen oder muss man sich eine andere Tastatur installieren!?
Edit 2: Häufige FC´s von Market und BlurHome. Allgemein hängt das System an der ein oder anderen Stelle als nocht. Längere Wartezeiten bis eine Reaktion von seiten´s Defy zurück kommt.
Edit 3: Das Defy bootet sporatisch neu...
Fazit: Für mich leider derzeit nicht nutzbar :(
Kannst d
Erhöhe mal die Vsel im Bootmenu um mindestens 2 Werte
qwertz geht leider nicht nur qwerty. Es sind zwei Tasterturen installiert. Kannst du was ausprobieren?
Im Anhang findest du eine Zip. BlurKamera.apk und build.pro Kannst du diese mal austauschen in deiner Installation und dann schauen, in welchen Auflösungen du mit der Motorola Kamera App Videos aufnehmen kannst? Nicht vergessen die Permissions richtig zu setzen.
  • test.zip
Kann ich ausprobieren, werde aber erst am Montag dazu kommen. Habe mein Backup wieder zurück gespielt da ich mich am Wochenende auf mein Defy verlassen muss und heute keine Zeit mehr für weitere spielereien habe. Habe allerdings ein Backup von deiner Rom gemacht. Werde es am Montag dann gleich probieren wenn es bis dahin kein anderer gemacht hat ;)
Die Kamera App für den GreenBread Mod ist aus einem Froyo Rom. Vielleicht einmal gegen die Orginal GB App austtausche.
@Walter79, Hut ab
hab die Version auch mal auf die schnelle installiert.(Ausgehend von Deiner 2.3.4/4.5.1-134)
Da sind ja ein paar schöne neue Features drin.
Hab dieses Wochenende leider nicht nicht die Zeit um alles mal auszutesten.
Aber Backup ist gemacht, kann man ja fix wieder einspielen.
Mit Language DE(noch ein bisschen zuviele Chinnesiche Zeichen drin) und evtl. Swype Tastatur wirds der "Nachfolger" werden
Gruss
walter79 schrieb:
Weil bei diesem 4.5.1-134 rom die Akku nur so kurz hält.
aber das haben doch nun schon mehrere getestet das das nicht so ist :)
und ich bin mit der akku leistung schon zufireden...
Die Akkuleistung mag bei vielen ok sein.Da aber auch bei den XDA Leuten viele Akkuprobleme mit den geleakten GBs fürs Defy haben, hab ich hier mal was neues aufgelegt.
Fall ich Zeit habe, kann ich ja eine angepasste 4.5.1-134 Version bauen.
och so, ja schad.. und keinen stress.. mir gings eher darum, das hier halt schon DE dabei ist, und auch fm radio läuft ..
habs doch nur gut gemeint *g*
pseudodeed
Cua
  • Gesperrt
  • Angepinnt
  • Cua
Cua
Cua
Android Siggi
Android Siggi
