Clockworkmod - CPU settings
  • 3 Antworten
I
imker
Ich habe das mal hier eingestellt, da dies alle CustomRoms mit CWM betrifft.
Ich habe mal die Mühe gemacht die CPU-settings für das Defy(normal) abzutippen....:confused:
Frage an die Experten:
1.) Reicht es in den Scaling Einstellungen je nach Wunsch
Conservative,Interactive,Ondemand,Performance,Boosted,Smartass,Userspace
einzustellen?
....Oder sind noch weitere Handarbeiten (außer Clk/Vsel) notwendig...
2.)Wirken die unten angegebenen "Feineinstellungen" beginnend mit s.B. "bst_" nur bei Scaling "Boosted"?
3.)Stimmt soweit die engl. Beschreibung? Könnte man da noch was ergänzen?
Quelle CPU settings (von mir Überarbeitet und ergänzt): [Overclocking] Boot Menu CPU Settings - xda-developers
______________________________________________________________
Android Bootmenu v1.3.0
# CPU settings -->
+Status: [Enable] --> status of overclocking is enabled or disabled
+Load all modules: [Enable] --> load modules for overclocking
+Scaling: [Ondemand] --> [Conservative,Interactive,Ondemand,Performance,Boosted,Smartass,Userspace] automatic CPU frequency scaling
+Clk1: [300] --> the frequency of the first stage of the frequency in MHz
+Clk2: [600] --> the frequency of the second stage of the frequency in MHz
+Clk3: [1000] -> the frequency of the third stage of the frequency in MHz
+Vsel1: [26] --> voltage at the first stage of frequency
+Vsel2: [40] --> voltage at the second stage of frequency
+Vsel3: [50] --> voltage at the third level of frequency
+con_up_threshold: [80] --> system load in% above which increases the CPU frequency? Bus?
+con_down_threshold: [20] --> system load in% above which lowers CPU speed? Bus?
+con_freq_step: [5] --> frequency step?
+con_sampling_rate: [160000] --> interval (in milliseconds) between polls of the state of the system. In fact, the intervals between shifts the frequency of the processor? Times in 160 seconds?
+int_min_sampling_rate: [50000] --> the minimum interval (in milliseconds) between polls of the state of the system. In fact, the intervals between shifts the frequency of the processor? Every 50 seconds?
+ond_up_threshold: [86] --> CPU in% above which increases the CPU frequency.
+ond_sampling_rate: [50000] --> the second one? interval (in milliseconds) between polls of the state of the system. In fact, the intervals between shifts the frequency of the processor? Every 50 seconds?
+smt_min_cpu_load: [20] --> CPU in% above which decreases the frequency of the processor
+smt_max_cpu_load: [80] --> CPU in% above which increases the CPU frequency
+smt_awake_min_freq: [30000] --> The minimum frequency of waking up?
+smt_sleep_max_freq: [30000] --> CPU frequency during sleep?
+smt_up_min_freq: [1000000] --> How much to increase the frequency at a time?
+smt_wakeup_freq: [1000000] --> Frequency of waking up. It is important to not lose calls.
+smt_ramp_up_step: [200000] --> on how to increase the frequency at a time?
+bst_awake_ideal_freq: [800000]
+bst_debug_mask: [0]
+bst_down_rate_us: [97000]
+bst_max_cpu_load: [70]
+bst_min_cpu_load: [40]
+bst_ramp_down_step: [16000]
+bst_ramp_up_step: [16000]
+bst_sample_rate_jiffies: [2]
+bst_sleep_ideal_freq: [300000]
+bst_sleep_wakeup_freq: [300000]
+bst_up_rate_us: [52000]
+iosched_sio: [0]
[Set defaults(*req reboot/don 't save!!)]
[Save] - save the settings
con_ = conservative
ond_ = ondemand
int_ = interactive
smt_ = smartass (?)
bst_ = bosted (?)
That is, this is all profile names, one from which to choose.
sampling_rate - in Hertz likely, but not in milliseconds
awake_min_freq - the minimum frequency of not sleeping
1) mit clock/Vsel kann man übertakten/untervolten. LOHNT!
2) Es sind generelle Einstellungen, das Scaling ist ne Einstellung für sich
3) passt :)
Reaktionen: imker
