HYUNDAI2010
- 3
This ROM is based on FR19 from MoDaCo with som fixes from me.
P.S You need to do a full wipe if you come from FR3/StockROM
For FR19 you have to use BACKTOEXT3 if you got EXT4 installed.
It's included in the download
Download:
Fear Edition 12.1:
MD5: 7D03460C82E8295704741528749D9A40
Extra:
LG Orginal Theme
Gingerbread Theme
Vanilla Theme (Froyo)
LG Widget
LiveWallpaper
Installation:
You will need CWM Recovery to install this ROM
And the newest Baseband version (20110622)
Added:
Google:
LG:
MoDaCo added:
Fear Edition ChangeLog:
Download:
Fear Edition 12.1:
Extra:
LG Orginal Theme
Gingerbread Theme
LG Widget
LiveWallpaper
Installation:
- First you need to download the ROM and lay it over to your SD Card
(It's a rar file with backtoext3 and rom!!!!!) - Boot in to CWM Recovery
- Do an backup for safety
- Flash backtoext3 in CWM (Will wipe your device. Sorry)
- You need to do a wipe before if you come from FR3/Stock ROM
- Choose "install zip from sd card"
- Choose "choose zip from sdcard"
- Let it flash (Takes 1-2min)
- Reboot and you got my ROM installed
Added:
Google:
- Calendar
- Gallery
- Standard Launcher
- Lockscreen
- Quick Search Box
- SIM Toolkit
- Youtube
- MMS (SMS)
LG:
- Alarm Clock
- FM Radio
- Fonts
- Mirror
- Music
- PC Sync + On Screen Phone + MITS
- Screen Capture
- SmartShare
- Video
- WAP Service
- Keyboard
MoDaCo added:
- Development Tools
- Gingerbread Keyboard
- HTC IME Keyboard
- Spare Parts
- Disable 'Battery Full' Popup (Stock Style ROM)
- Disable Music Controls
- Hidden Menus / Debug / Test Tools
- Silent Camcorder
- Fr19
- Bootanimation
- Sqlite is added and gives prestandard boost
- Adobe Flash Player
- Thanks to "MoDaCo" @MoDaCo For this fantastic ROM
- Thanks to "hikari" @ Swedroid for Optimus2XTouchLEDNotifications
- Thanks to "Ekkis" @Swedroid,XDA for download pictures
- Thanks to "75markus" @MoDaCo for theme (Say thx for his work and future work)
Fear Edition 12.1
Fear Edition 12.0
Changes in MoDaCo ROM:- Added BGB Theme 2.7 Final.
- Original Browser is re added.
- Back to EXT3 file is included in download.
- Added flashed option for themes
(Gingerbread, Froyo and LGs)
Fear Edition 12.0
- Lagt till FR19
- Kamera Modden är tillagt
- BGB Theme är nyaste versionen.
Jun 30 Fr19
Jun 29 Fr19 RC 2
Jun 21 Fr19 RC 1
Jun 20 Fr19 Beta 5
Jun 20 Fr19 Beta 4
Jun 17 FR19 Beta 3
Jun 16 FR 19 Beta 2
Jun 15 Fr19 Beta 1
20 May Fr18 Beta 2
20 May Fr18 Beta 1
19 May Fr17
18 May Fr17 RC 3
18 May Fr17 RC 2
18 May Fr17 RC 1
17 May Fr16 Beta 4
16 May Fr16 Beta 3
16 May Fr16 Beta 2
16 May Fr16 Beta 1
13 May Fr16 (WIP)
12 May Fr16 (WIP)
3 May Fr15
28 Apr Fr14
26 Apr Fr13
13 Apr Fr12
11 Apr Fr11
8 Apr Fr10
6 Apr Fr8
5 Apr Fr7
4 Apr Fr6
4 Apr Fr5
30 Mar Fr4
29 Mar Fr3
- Updated Google Maps
Jun 29 Fr19 RC 2
- Rebased with ALL changes from 0622 ROM
- Fix for corrupt images in Gingerbread theme
Jun 21 Fr19 RC 1
- Fixed French localisation of Fonts app
- Removed software update client (and patched Settings APK), gains 20MB RAM
- Online kitchen now saves chosen selection to a text file in the ROM zip (for debugging use)
Jun 20 Fr19 Beta 5
- Added semi transparent pulldown in all themes
- Restored Vanilla Froyo / Gingerbread themes
Jun 20 Fr19 Beta 4
- Fixed BBA support in 'remove battery full alert' option
- Fixed some corrupted PNG files (e.g. lock screen sliders)
- Updated Superuser app
- Updated Titanium Backup
- Battery improvement tweaks
Jun 17 FR19 Beta 3
- Added 'remove battery full alert' options
- Fixed incorrect '<' character in Gingerbread keyboard
- Updated Maps app
- Updated Amazon Appstore app
- Updated Google Music app
Jun 16 FR 19 Beta 2
- Added stock Google lockscreen options
- Added SQLite performance patch options
- Added disable toggle buttons / music controls / both options
- Added silent camcorder option
Jun 15 Fr19 Beta 1
- Initial Fr19 release
20 May Fr18 Beta 2
- Remove USB debugging sound and persistent notification
- Add option to include 'old' non oc/uv kernel
- Reverted Beta 1 dialer changes (should fix a number of issues)
- Updated lge-ril to a new version (previously unseen MD5 from Spanish release)
20 May Fr18 Beta 1
- More Dialer battery saving changes
- LGU660 (Korean 2X) boot animation added to kitchen
19 May Fr17
- No changes between RC3 and release
18 May Fr17 RC 3
- EternityProject kernel updated to r2, USB mount fixed (if using, install PimpMyCPU to control)
- MCK (MoDaCo Custom Kernel) updated to r14 (normal and 64MB patched versions), now with OC/UV support too as standard. The phone is NOT overclocked by default. (if using, install PimpMyCPU to control)
18 May Fr17 RC 2
- Fixed broken Camera with no Camcorder sound from RC 1
- Updated MCK with IPtables 'LOG' support (user request)
- Included an option in kitchen to flash EternityProject OC/UV kernel with MCK based configuration (if using, install PimpMyCPU to control)
18 May Fr17 RC 1
- Removed some debug code in LGEmail.apk
- Removed some debug code in Settings.apk
- Updated Norwegian resources in AccountAndSyncSettings.apk
- Updated Norwegian resources in AlarmClockNew.apk
- Updated Norwegian resources in AnalogAlarmWidget.apk
- Updated Norwegian resources in AnalogClockWidget.apk
- Updated Norwegian resources in AndroidBackup.apk
- Updated Norwegian resources in AppAdvisor_v1.5.78_production_signed_aligned.apk
- Updated Norwegian resources in ApplicationsProvider.apk
- Updated Norwegian resources in BookmarksWidget.apk
- Updated Norwegian resources in Browser.apk
- Updated Norwegian resources in Bubbles.apk
- Updated Norwegian resources in Calculator.apk
- Updated Norwegian resources in Calendar.apk
- Updated Norwegian resources in CalendarProvider.apk
- Updated Norwegian resources in CalendarWidget.apk
- Updated Norwegian resources in Camera.apk (2 versions)
- Updated Norwegian resources in CarHome.apk
- Updated Norwegian resources in CertInstaller.apk
- Updated Norwegian resources in ClockWeatherScheduleWidget.apk
- Updated Norwegian resources in ClockWeatherWidget.apk
- Updated Norwegian resources in com_lge_christmassnowcity.apk
- Updated Norwegian resources in com_lge_lgfirework2.apk
- Updated Norwegian resources in Contacts.a.apk
- Updated Norwegian resources in ContactsProvider.apk
- Updated Norwegian resources in ContactWidget.apk
- Updated Norwegian resources in cyon.apk
- Updated Norwegian resources in DefaultContainerService.apk
- Updated Norwegian resources in DeskClock.apk
- Updated Norwegian resources in DigitalAlarmWidget.apk
- Updated Norwegian resources in DigitalClockWidget.apk
- Updated Norwegian resources in DocMaster.apk
- Updated Norwegian resources in DownloadProvider.apk
- Updated Norwegian resources in DrmService.apk
- Updated Norwegian resources in EmailWidget.apk
- Updated Norwegian resources in FmRadio.apk
- Updated Norwegian resources in FMRadioWidget.apk
- Updated Norwegian resources in framework-res.apk (5 versions)
- Updated Norwegian resources in Gallery3D.apk
- Updated Norwegian resources in HomeSelector.apk
- Updated Norwegian resources in HTMLViewer.apk
- Updated Norwegian resources in JSFontService.apk
- Updated Norwegian resources in LGDisplaySettings.apk
- Updated Norwegian resources in lge-res.apk
- Updated Norwegian resources in LGEmail.apk
- Updated Norwegian resources in lgeVideoPlayer.apk
- Updated Norwegian resources in LGLauncher.apk
- Updated Norwegian resources in LGMemo.apk
- Updated Norwegian resources in LGOnScreenPhone.apk
- Updated Norwegian resources in LGSetupWizard.apk
- Updated Norwegian resources in LiveWallpapers.apk
- Updated Norwegian resources in LiveWallpapersPicker.apk
- Updated Norwegian resources in MagicSmokeWallpapers.apk
- Updated Norwegian resources in MediaProvider.apk
- Updated Norwegian resources in MemoWidget.apk
- Updated Norwegian resources in MessageWidget.apk
- Updated Norwegian resources in Mirror.apk
- Updated Norwegian resources in Mms.apk (LG Version)
- Updated Norwegian resources in Music.apk
- Updated Norwegian resources in MusicWidget.apk
- Updated Norwegian resources in NewsWidget.apk
- Updated Norwegian resources in OPP.apk
- Updated Norwegian resources in Phone.apk
- Updated Norwegian resources in PhotoFrameWidget.apk
- Updated Norwegian resources in PicoTts.apk
- Updated Norwegian resources in PreloadedApp.apk
- Updated Norwegian resources in Protips.apk
- Updated Norwegian resources in resources.arsc
- Updated Norwegian resources in Screencapture.apk
- Updated Norwegian resources in Settings.apk
- Updated Norwegian resources in SettingsProvider.apk
- Updated Norwegian resources in SmartShare.apk
- Updated Norwegian resources in SNS.apk
- Updated Norwegian resources in TodayScheduleWidget.apk
- Updated Norwegian resources in VisualizationWallpapers.apk
- Updated Norwegian resources in VoiceRecorder.apk
- Updated Norwegian resources in VpnServices.apk
- Updated Norwegian resources in WapService.apk
- Updated Norwegian resources in wdwallpaper.apk
- Updated Norwegian resources in WorldClockWidget.apk
17 May Fr16 Beta 4
- Battery optimisation changes!
16 May Fr16 Beta 3
- A new change that should give a noticeable improvement in performance!
- Reverted some changes to Phone app behaviour
- Updated Adobe Flash to 10.3
- Minor kitchen tweak (moved some test apps into the test app / hidden menu item)
16 May Fr16 Beta 2
- RAM hack is now optional (disabled by default)
- Some minor improvements to battery management
16 May Fr16 Beta 1
- Addition 64MB RAM hack (thanks Kiljacken)
- GPS improvements
13 May Fr16 (WIP)
- Chinese WiFi fix
- French fonts dialogue fix (Odustani -> Annuler)
- Low level changes for a forthcoming notifications product
- Changes to messaging app (Dialer battery drain diagnostics)
12 May Fr16 (WIP)
- MCK updated to r11 - more minor performance improvements
- Updates to try and improve battery usage (particularly around Dialer usage)
- Updated apps - Amazon Appstore, Market, Maps, Google Music, SlideMe Market, Titanium Backup
- Added option to wipe battery stats on install
- Added MarketAccess application (see in topic for more details)
3 May Fr15
- Reverted to MCK kernel - patched to .28 stable and with a ton of performance improvements
- Added gps.conf to /system/etc
- Patched settings and removed update client (gains 20MB RAM
28 Apr Fr14
- Initial v10d / 1303220460 merge
- Modified boot image config (performance improvements)
- Modified EXT4 partition options (performance improvements)
- Modified mount config (performance improvements)
- Updated Gingerbread Keyboard
- MCK-cm-r1 (MoDaCo Custom Kernel) - now with merges from the CyanogenMod kernel for the 2X
- Initial test support for Korean devices with Home button
26 Apr Fr13
- MCK (MoDaCo Custom Kernel) r9
- Changes to attempt to eliminate app install / management lag
- Added BFQ scheduler and set as default (unrelated to above fix, you can revert to CFQ if desired)
13 Apr Fr12
- Rebased on 1301920892 release including updated RIL (20110405 baseband recommended)
- All fixes / tweaks to date merged into latest release
- Removed adfree hosts file (accidentally included) - use AdFree app from the Market if you'd like this functionality
- French language Fonts app fix
- Fixed crash on Gingerbread Keyboard settings
11 Apr Fr11
- Updated kernel (performance enhancements - improved overall smoothness)
- Updates to reduce duration of 'app install / uninstall lag'
- Updated third party apps / components
8 Apr Fr10
- init.d support
- terminfo support (for nano etc.)
- Nvidia module updates / additions
- Removed some unneeded files
- Fixed an error in the keyboard layout file
- Semi transparent notification pulldown
- Additional Gingerbread sounds (alarms, ringtones, notifications)
- Optional Gingerbread Vanilla theme
- Optional bleeding edge .36 kernel patched to official P990 code release
6 Apr Fr8
- Reverted kernel to .9 (browser lagfix)
- Fixed 'dim screen' in Camera when using auto brightness
- Added an alternative Camera application with no camcorder sound
- Disabled menu button unlock in stock unlock screen
- Added option to not have the 'battery full' popup
- Includes SQLite performance patch (with option to disable)
5 Apr Fr7
- PERFORMANCE AUDIT CHANGES
- /data/data permissions now checked on install
4 Apr Fr6
- Stock Google lockscreen option
- LG Calendar now a kitchen option
- Framework image fixes
- Stock Froyo (Vanilla!) options
4 Apr Fr5
- Multitouch Fix
- SD card speed fix
- Clock size fix
- Optional Google calendar
- MoDaCo Custom Kernel (MCK) r5
- CyanogenMod APN list
30 Mar Fr4
- Stock Google Contacts / Phone now selectable in the kitchen
- Stock Desk Clock now available (for use when disabling LG Alarm Clock / Desk Clock)
- Amazon Appstore and SlideME Markets now in the kitchen (I use SlideME as the only place to buy Quadrant Advanced!)
- Boot sound is now optional
- Key items (e.g. framework-res) now signed with AOSP platform keys to aid themers
- Fixed some typos and naming in the kitchen
- Gingerbread keyboard now added (Steven Lin version)
- Minor tweaking of kitchen default options
- Minor performance enhancements
29 Mar Fr3
- Initial MCR release
Die Konkurrenz ist da echt fitter, wobei LG halt in Sachen Preis - Leistung nicht zu toppen ist, naja, zumindest nachdem der Preis rapide gesunken ist.
