burningfight
Gast
with Anti - crisis - Kernel - versions
5 versions:
1 - Spica RC12-R OC
2 - Spica RC12-R NO-OC
3 - Gueste Kernel 1.1 EXT3
4 - Gueste Kernel 1.1 EXT4
5 - Fajarep SiKancil 0.2 EXT3
6 - Stock with 20q kernel - EXT3
Die 1.0 ist keine Beta mehr.Also los gehts
Changelog 1.0:
- ALL NO WIPE (so remember to convert to ext3 to install ext3 versions)
- 20q base
- New sqlite lib 3.7 with full support to WAL mode (thanks Spica!)
- No Ota update in settings (+20 Mb ram)
- No OSP in settings and fully removed
- Transparent curtain and circular battery
- ICS animation
- CM APN
- Bravia Engine Mod
- Build.prop tweaked for market compatibility
- 20q ril (suggested baseband: 20q)
- 3 new profiles for memory management in 90carbutweak script
- Enabled ADB
- Optimized host to remove spam and ads
- Stock camera from 20q
- Removed 2x reboot
- Removed Battery Calibration
- Removed LG UI 2 Weather, many animated wallpapers and other LG apps
- Added DSP Manger (Thanks Spica)
- Added Android weather (light and simple )
- Back to Adobe flash 10.3 (IMHO best performance)
- Removed LGStartupWizard
- Gmaps up to date
- ES file explorer Up to date
- Su binary up to date
- Facebook up to date
- Google Music Up to date
- Voice Search Up to date
- Titanium Backup Up to date
- Updated Supercharger script in /systems/xbin folder
- Deactivated scrolling cache
- Twitter Up to date
- 2 launchers: TW launcher and QQLauncher IMPORTANT: I added at last minute QQ launcher but I suggest to avoid using it because after reboot I never have Pin unlock phone... Use TW (that is faster too)
Hier könnt ihr die Rom fürs Optimus Speed P990 Downloaden.
DjangoManouche 1.0 - Spica RC12-R OC :
Ist gleich Verfügbar!
DjangoManouche 1.0 - Spica RC12-R NO-OC:
Noch nicht Verfügbar!
DjangoManouche 1.0 - Gueste Kernel 1.1 EXT3:
Download
DjangoManouche 1.0 - Gueste Kernel 1.1 EXT4:
Download
DjangoManouche 1.0 - Fajarep SiKancil 0.2 EXT3:
DjangoManouche 1.0 - Stock with 20q kernel - EXT3:
Download
Ich empfehle die
da diese sehr flüssig läuft.DjangoManouche 1.0 - Gueste Kernel 1.1 EXT4 und das Baseband V20q
(im Anhang zu finden/RIL V20q in der ROM enthalten)
DJANGO MANOUCHE 1.0 Transformation Packs
- ICS theme by Gabriesu
- IceComb by Gabriesu
- Swishstyle by Gabriesu
- Back to DjangoManouche Stock
- Back to LG Stock (with LG Launcher and stock framework)
!!Vielen Dank an carburano, der diese Rom erstellt hat!!!
Also Thanks to:
Topogigi
Gueste
Hell97
Spica1234
Dr4go
Flix132
Gabriesu
Mjuksel
Vadonka
jaspi72
Owain
whole XDA community
Italian forum for support (HDBlog, Androidiani, IpMart, Facebook group "LGDual"
Screenshots:
Würde mich über ein Dankeschön Sehr Freuen!
