Passer
Stamm-User
- 49
- Themenstarter
- #241
[KERNEL][CM10/CM10.1/ICS - OLD/NEW BL][011p4 - 2013/02/03] Kowalski Kernel - xda-developers011p4 - 2013/02/03 - Bugfixes and some goodies
* Backported OnDemand governor from kernel 3.2
* Added Boost Pulse support in the kernel for Interactive and OnDemand governors
* Added tegra.power.so blob to the installer
* Optimized CFQ and BFQ schedulers
* Fixed shutdown crash
* Fixed USB fast charge on the old bootloader
* Updated Kowalski Manager to the latest version
Unfortunately we can't![]()
That stupid idiotic pengus77 implemented OC in a smart way, it will throttle once it hits critical temperatures.
Yes, it ensures my battery won't overheat and will protect the phone from damage.
Yes it probably is the best and most stable OC implementation the Optimus 2x ever had.
Yes, this is OCing how it's supposed to be.
But come on, no more inbuild pocket heater? Sucks hard!I think I will abandon this stupid kernel.![]()
Paladin schrieb:Jooo.. und wenn ich mir die Kommentare von tonyp:
So durchlese, scheint ein OC Kernel von Pengus schon bei den Testern zu sein.
Und nicht über den Ton von denen untereinander wundern, der Sergeant (=tonyp) bei den Pinguinen nennt ja Kowlaksi immer einen Idioten
Changelog:Ok guys, after a month of no-updates due to my work on the kernel, i finally got the time to repack a cm10 for you to enjoy![]()
Tons of fixes and small mods in here. It's been tested for three days without major problems, so i'm quite confident that it's stable enough for release.
On a side note i'd like to thank all the testers and contributors that helped me in this effort: massimo69, wfd, CarloIt and stonebear have been so helpful and present that i really don't know if i could have done this without them. And, well, Tonyp for his nitz fix patch and for helping out discovering awesome cherry picks on gerrit![]()
If major bugs pop out i'll surely try to fix them and repack and update, otherwise this will be the end of line for this rom and i'll join my forces with Tonyp to produce TheRom™. No more spoilers, but i think that this rom and Tonyp's one are becoming closer and closer in terms of fixes. We keep in touch on gtalk on a daily basis and we share most of our findings. We also agreed to work together on TheNextBigThing™![]()
2013/01/08 General mods
- Nitx fix by TonyP
- After flashing reboot again to make it work
- Updated wpa supplicant 8
- Updated dhcp daemon
- Trickster Mod preinstalled
- Kowalski Manager preinstalled
- PDroid Apk preinstalled
- Holo Launcher as default launcher
- Trebuchet removed
- Added iwconfig/iwlist
- Added alsa_amixer / alsa_ctl / alsa_aplay
- Removed VideoEditor apk
- Added libjpeg-turbo from Linaro Android
- Optimized CFLAGS for C and C++ parts
- Enabled Purging of Assets in performance -> memory menu
- Kowalski Kernel 011p4
Cherry-Picks from CM Gerrit
- FM Radio: Add support for FM Radio in Android
- SMS Usage Monitor: Prevent recurring usage Alerts
- Added cooler weather icons (thanks wfd)
- Fix for custom button and keyboad light values
- extend PreferenceActivity for title text on a single pane mode
- add criticalBatteryShutdownLevel; fix plugged/charging status
- bluetooth: prevent Android restart with buggy devices
- Allow purging of asset bitmaps
- Stop supplicant and dhcp before start
- audioflinger: Fix to release wakelock after closeoutput
- libstagefright:Buffer size needs to be set on Native Window
- Fix for NULL pointer deference when Audio Record fails
- Fix for audio playing on speaker when headset is removed
- surfaceflinger: Add all display connections to connection list.
- Mms: Take into account image rotation.
- MMS app: fix crash when MMSC setting is NULL
- Camera: Allow setting "profile-video-size" before recording starts
- Messaging: Add the ability to mark a message as read from the notification
- Add option to enable/disable Electron Beam Animation
- libsuspend: Correctly handle errors initializing autosuspend, to avoid exceptions later on
- Decode DHCP netmask option correctly
- Fixed an unused param warning
- libnetutils: Fix up the dhcp request arguments
- dhcp_utils: Add -f dhcpcd.conf processing
- vold: Add support for EXT filesystem on sdcard
HMM weis nicht ob das funktioniert:mikle_01 schrieb:Hört sich ja klasse an - mal flashen und sehen...Sogar mit FM Radio!
Bitte auch den Changelog genauer lesen:+Jerpelea Alin, along with +Giulio Cervera have submitted a bevy of commits that have just been merged. Theoretically, this means that FM support (using a headset as the antennae) should work on devices with Qcom/Broadcom wifi chips that have FM. Currently, Sony devices with these specs are confirmed functional.
herzog2 schrieb:Apollo und DSP manager hat er auch nicht drin
Passer schrieb:Ich hab bei der ROM merkwürdigerweise das Problem (gehabt), dass die AOSP (Standard) Tastatur ständig beendet wurde.
Mein Workaround:
4.2 TAstatur per ZIP flashen und die AOSP Tastatur per Titanium entfernen.
Paladin schrieb:Vermisse ich nicht wirklich, höre keine Musik auf dem Handy
