Jens_
- 7
Geht bei mir auch bestensmikle_01 schrieb:009p2 läuft bei mir 1A! Flott, smooth und keine Probleme mit WLAN. Verwirrend sind lediglich die Kernel "Addons" (CAM, PSP;...). Ich hab nix davon installiert.
010 - 2013/01/19
*Added the possibility to change leds brightness from userspace (sysfs)
*Simplified kernel flags, removed useless bloat, smaller kernel
*Backported the lowmemorykiller from kernel 3.4
*Unified wifi driver for compatibility with cm10, cm10.1 and ics
*Disabled the cpu boost when connecting usb (badly done by nvidia)
*Compiled Zram as a module, installed a init.d script to enable it
*Moved from lzo to google's snappy as compression for zram
*Fixed a couple of regressions from nvidia kernel 2.6.32 linked to bsods when suspending/resuming
*Switched to Interactive as default governor. Seems snappier for now with the latest version
*Enabled low level kernel tegra irq timers
*Added all the TCP Congestion Algorithms available in the kernel
*Backported from kernel 3.4 the latest patches for
*Backported from kernel 3.4 the BFQv5 I/O Scheduler
- - ROW I/O Scheduler
- - Interactive Governor
*Tons of patches from upstream related to
- TCP Networking
- ARM suspend/resume and smp routines
- USB memory corruption and possible lockups
- Kernel Timers
Paladin schrieb:So...Pengus ist wieder fleissig:
Kowalski Kernel 0010
Der Changelog deutet daraufhin, das der Kernel auch mit CM10.1 läuft.
Wer mag es testen??
[KERNEL][CM10/ICS - OLD/NEW BL][009p2] Kowalski Kernel - xda-developers
For CM10, to have perfect compatibility with wifi, please flash the wpa_supplicant_8_update.zip in my Addons folder on dev-host. It will update your wpa_supplicant in the system and you'll get the same behaviour as on 10.1 and ICS !Change Log
*Added USB Fast Charge mode
*Net: Various ipv4 related fixes from kernel 3.4
*Wifi: Lowered default dBm of the wifi card to 19dBm (<3 my health)
*Wifi: Raised scan time for wifi from 3s to 8s (<3 my battery)
*Wifi: fixed compatibility between 10, 10.1 and ICS
*Wifi: fixed battery drain
*Wifi: removed background scan (let Combo Scan do the job)
*Row: Multiple patches from 3.4
*Row: Implemented urgent requests (speedy gonzales style)
*Disabled LG FOTA crap in muic (and hopefully autofix some bugs)
*Disabled android compaction process (let's have the new awesome lmk do the job)
*Modified kernel entropy generation (the new black apparently)
*input: monotonic input events (fasteeeer, i said faaaaaaaster)
*increased slightly timers ticks/second (oh, this is going to be felt a lot)
*gpio timers from kernel 3.8
*android logger from kernel 3.8
*prepared makefiles for gcc 4.7.X (the next step)
011p3 - 2013/01/28 - Bugfixes Release
* Fixed wifi parameters persistency
* Fixed USB fast charge on the old bootloader
* Reverted "disable aio" commit that was causing lousy sdcard r/w speeds
* Updated Kowalski Manager to the latest version (with icon !)
* Tweaked the LMK values a bit
NTP_SERVER=0.de.pool.ntp.org
NTP_SERVER=1.de.pool.ntp.org
NTP_SERVER=2.de.pool.ntp.org
NTP_SERVER=3.de.pool.ntp.org
NTP_SERVER=0.europe.pool.ntp.org
NTP_SERVER=1.europe.pool.ntp.org
NTP_SERVER=2.europe.pool.ntp.org
NTP_SERVER=3.europe.pool.ntp.org
NTP_SERVER=1.pool.ntp.org
AGPS=http://xtra3.gpsonextra.net/xtra.bin
XTRA_SERVER_1=http://xtra3.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=http://xtra4.gpsonextra.net/xtra.bin
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_USER_PLANE=TRUE
DEFAULT_SSL_ENABLE=FALSE
INTERMEDIATE_POS=1
QOS_ACCURACY=50
QOS_TIME_OUT_AGPS=95
QOS_TIME_OUT_STANDALONE=80
QosHorizontalThreshold=1000
QosVerticalThreshold=500
AssistMethodType=1
AgpsUse=1
AgpsServerType=1
AgpsServerIp=3232235555
SUPL_HOST=supl.google.com
SUPL_PORT=7276
#SUPL_SECURE_PORT=7275
SUPL_NO_SECURE_PORT=3425
#SUPL_TLS_HOST=FQDN
#SUPL_TLS_CERT=/etc/SuplRootCert
ACCURACY_THRES=3000
CURRENT_CARRIER=common
PHONE_TYPE=UMTS
chupacabra schrieb:Macht die APP Faster Fix nicht dasselbe?
Gesendet von meinem LG-P990 mit Tapatalk 2
