tonydl
- Themenstarter
- #101
The first source build is ready, it took me about 2 weeks to prepare everything.
This build took way more time than each build before because I had to redo almost everything from scratch.
In return we do have the smoothest and most stable build I have used ever :good:
If you appreciate my work and are happy with my newest build consider a donation - I'm happy about every amount
- donation link -
- donation link -
I will call this build 10 to prevent confusion with the previous testbuilds which some referred as build 9
You don't need to do a full wipe. Just flash and wipe cache + dalvik (but with a full wipe it will be even smoother!).
This build has every bug fixed that was reported to me (and is fixable by me and not LG etc.). :good:
Just in case someone has issues with build 10 and wants to stay at build8 I did introduce a new version name at goo.im.
This means you won't get notified that an update is available via GooManager (but you will for future versions when you use build 10 of course).
Build 10:
- from now on I build PA directly from source, no more ugly porting!
- this gives us great stability improvements and performance enhancements
- added a Center Clock option for PhoneUI - I absolutely love it!
- added a setting for system volume as requested
- lots of bugfixes and enhancements
- enabled the mobile data limit function
- fixed the broken contacts widgets
- you can enable KSM now - but beware, it is battery hungry
- many many small bugfixes
- based on ParanoidAndroid v1.6 (the latest ICS version)
- Improvements on frameworks, fixed all DPI related crashes
- SystemUI mode can be configured now
- Cleanup and speedup of hybrid code via native libs (~25%)
- this build was a lot more work than the changelog suggests, I had to redo almost everything from scratch!
You can follow my work here:
https://github.com/tonypp
