[Rom] CM7 KANG von Temasek | Immer Aktuell
  • 176 Antworten
Fail :p
Sorry, da hab ich wohl nur den ersten Satz gelesen.
Update 10.4.2012
Heute ist die RC1-88 Rausgekommen.
Hier der Direkte Link zur Download Seite:
Link
Und hier der Link zu der XDA Seite
Link
MERGED COMMITS UP TO
Change Id5f55f6b: Add bootmenu 1.1.9 cpcap flag and remove unused progress images
http://review.cyanogenmod.com/#q,sta...ingerbread,n,z
CHERRY-PICKS
If you see any picking is missing from last build, it is because it was merged, abandoned, reverted by me or I've eaten it up.
NEW - Change If7034665: Allow using PLMN and SPN text as part of Custom Carrier text (1/2)
NEW - Change I1748108a: Allow using PLMN and SPN text as part of Custom Carrier text (2/2)
Change I19cb79b8: Fix typo in queue_property_triggers ident
Change I8541e910: Fixing a crash when doing lock profiling
Change I9cc7e309: Avoid method overriding if its super method is inaccessible.
Change I9ce24ddf: bionic: make static object initialization thread safe
Change I01dd1b62: Modify Running ProcessView as ics (claimed to be better)
Change I5511e2c3: Galley3D: Use the same screen brightness as the camera app
Change Ib1fe3118: Make PhoneToggler accept the same values as are configurable in the settings.
Change Icbbcc346: products/common.mk: remove the test statement for *.apk *.so *.jar and *.xml...
Change I06df6f1f: Don't cache toasts.
Change I5973e1aa: watchprops would go to 100% CPU after processing first change
Change I6c4cb0e4: Fix ash to read /etc/profile
Change I6011d37d: libcutils: Fix race issues in mspace_usable_size
Change Ib51fa07e: Restore fp after calling JNI method in allstubs interpreter
Change I2ad55454: Added option to hide alarm icon in status bar (1/2)
UPDATED - Change I00a21e01: Added option to hide alarm icon in status bar (2/2)
Change Ic92366ed: free memory allocated by strdup
Change I7cef7a6d: fix memory leaking
Change I64b6f0a7: Fix file descriptor leak in read_num
Change I2126e87c: Fix memory leaking in the VM
Change I368a957a: Fix possible file descriptor leaking
Change I79911e41: bionic: fixed the race condition in dlmalloc_usable_size()
Change I3c8986ec: libm: fix invalid result of function remquo/remquof
Change Ia4ecd1a6: Don't use deleted Node object in setSizeScreenWidthAndScale
Change Ib7993a6d: ipsec-tools: build racoon XAUTH client
Change I2b48c941: Undecoded jobject leaking in through attachThread
Change Ib5638156: Prevent deadlock when using fork
Change Ib31db963: Add optimized version of memset for Cortex A9
Change Ice487342: InputMethodManager: prevent Sym key from displaying the IME picker
Change Ie125c120: Don't malloc between fork and exec
Change I5271c272: Redesign dlopen() locks to be recursive per thread picked from https://github.com
Change I0e78bdcc: bm: cherry-pick one patch from freebsd to fix logb() denormals issue
Change I0ab8bca5: cleanup redundant interfaces from iftable to avoid excessive LinearAlloc use
Change I0040d662: Don't pay for filename/line number lookup unless you need to.
Change If77b8cfd: memcmp: prefetch optimizing for ARM Cortex-A8/A9
Change I1dff8419: Wifi: Added option to first initial state of WiFi service (1/2)
Change I2e7f1b76: Wifi: Added option to first initial state of WiFi service (2/2)
Change Id062a29e: Start playback when A2DP headset gets connected
Change I22f98423: FM: Allow tuner to loop from upper back to lower and lower back to upper (frequency)
Change I3d9dcbcf: SpareParts: Posibility to translate app name. Add spanish app name.
Change I6be6e26c: Development: Add possibility of translation in other languages
UPDATED - Change Ibaada8b5: add option to disable volume key beep sounds (1/2)
Change I35d940b6: add option to disable volume key beep sounds (2/2)
Change I95c987f1: Toggling the flashlight from the lock/pattern/sim unlock screens
UPDATED - Change I5db06ce5: Toggling the flashlight from the lock/pattern/sim unlock screens
Change Iacc911df: Camera: Allow focus sound muting (1/3)
UPDATED - Change I8ef31c58: Camera: Allow focus sound muting (CMParts, 2/3)
Change I1b57c6b5: Camera: Allow focus sound muting (3/3)
Change I7286eb5f: CMParts: updated french translation
Change I95b8f2b1: The Torch app had to much "old" and deprecated code.
Change I5bb6e423: add NITZ override:
Change I2894b19b: Frameworks/base: move translations in arrays.xml into strings.xml
Change I64eaca07: apns: add entry for the new free mobile operator (france)
Change Ibe80ad55: Settings: update Simplified Chinese translations
Change I27f1bc60: Added format number option to dialer
Change I5b40a39b: fix summary for compability mode
Change I913dceee: Added portuguese (pt-pt) translation
Change I067aeb3a: unecessary whitespace cleanup
Change Ib065f61a: Fix English summary for haptic feedback
Change I4ed39a28: Always follow the user's preferred contact display name format when syncing the phonebook.
Change Ie9fc0463: Add individual contact call history and show groups yes/no setting on call log. - fix
Change I6aa958e0: Add ANDROID_CPU_FEATURE_ARM_LDREX_STREX feature flag
UPDATED - Change I26b7475a: Overscroll color (1/3)
Change If920c93a: Overscroll color (2/3)
Change Ia8d8e687: Overscroll color (3/3)
UPDATED - Change Ic57f4acc: pattern unlock screen: Add an option to hide pattern error
Change Icf77cc36: Add ability to swap volume keys in selected orientation. (Frameworks)
UPDATED - Change I550604b3: Add ability to swap volume keys in selected orientation. (CMParts)
UPDATED - Change If8f37d8f: Default volume control media (2/2 CMParts)
Change I0e4ebbc0: Estonain keyboard
Da ich grade die Firmware auf mein 2x gezogen habe hab ichs mal hier gepostet. Vielleicht informierts ja noch jemanden :)
Reaktionen: Mitch
Temasek scheint mir bei den CM7 Roms die höchste Aktualisierungsrate zu haben. Seid ihr zufrieden mit der ROM (vor allem bzgl. Stabilität/Akkulaufzeit)?
Klar, weil temasek nur KANGs erstellt.
Damals, als ich temasek benutzt habe, war es top (ist aber schon einige Wochen her).
Ist immer noch top :)
also ich kann beim besten willen das RIL nicht updaten..
es kommt mit dem 218er ich hab BB725 und egal was ich im getril auswähle -> "installation fehlgeschlagen" hat jemand eine lösung?
Wurden GetRil die Root-Rechte gewährt? Einfach mal bei Superuser reinschauen...
Ansonsten findest du in Temaseks altem Download Ordner (Link im ersten Post) alle Rils als flashable Zips für CWM!
Zum Jubiläum: Build 100 von Temasek! DANKE!
Changelog: (leider wie immer in englisch, aber vllt möchte ja jdm übersetzten :D)
NEW - Forgot to change intent on bootanimation chooser
NEW - Add preference to bootanimation chooser
NEW - Add preference for bootanimation chooser
NEW - CM Boot Animation Helper
NEW - Add bootanimation changer to CMParts (1/2)
NEW - Custom action on the double tap on the home key.
NEW - Increase double-tap delay for home key extra activity launcher
NEW - Add a green gps-fixed icon to status bar
NEW - try color changes to cmbattery and cmsignal text
- Improve functionality of status bar restart + cleanup
- Add option to restart status bar to CMParts
- fix notification background changes2
- added jerryscript notification backdrop changer 1/3
- Add ability to show/hide remaining system icons in status bar (1/2)
- Add ability to show/hide remaining system icons in status bar (2/2)
- Make status bar dateview use clock's color
- dropdown menu fixes
- Statusbar color change mod by jerryscript
- notification backdrop changer by jerryscript 1/2
- notification backdrop changer by jerryscript 2/2
- center clock 2/2 by Jerryscript
- Statubar date fix
- Statusbar mods by jerryscript
Reaktionen: smaly
1a rom :))
Ist der in die CM7 KANG integrierte Kernel 2.6.32.55-cyanogenmod eigentlich der gleiche, wie der den man sich HIER bei temasek herunterladen kann (der erste, nicht der Voodoo)?
Nein, ist er nicht.
Hauptsächlich ist ein anderer Batterydriver enthalten und der ZRAM/Compcache Kompression erfolgt mit (Googles) Snappy Algorithmus statt mit lzo.
Wenn du keinen stark optimierten Kernel (wie vadonkas ETANA) willst würde ich den temasek kernel empfehlen, grade bei aktiviertem compcache merkt man einen Unterschied (Settings - Cyanogenmod - Performance/Development - Compcache).
070512-0104-temasek
1. Battery overheat patch by wkPark
050512-1911-temasek
1. Added Simple IO Scheduler (SIO) as default
050512-1024-temasek
1. Updated to latest v21y battery driver
270412-2012-temasek
1. Fixed missing /sys/kernel/mm/ksm/ folder
26Apr12-1159-temasek
1. Add vadonka's call quality tweak
2. Update KSM Values (better battery, ie doesn't drain as much as b4)
24Apr12-0030-temasek
Stock CM Kernel +
1. star_batter.c from 3.0.y backported
2. snappy compression/decompression by Google from 3.0.y backported
3. Kernel KSM support
4. Voodoo (optional)
Reaktionen: jandroid
tonydl schrieb:
Nein, ist er nicht.
Was genau ist ZRAM/Compcache Kompression und was sind die Vor- bzw. Nachteile?
Welche Vorteile hat ein stark komprimierter Kernel wie vadonkas ETANA?
Der ursprüngliche Beitrag von 15:06 Uhr wurde um 15:17 Uhr ergänzt:
Ich habe gerade mal nachgeschaut. Bei dem 2.6.32.55-cyanogenmod Kernel kann ich die Compache-Speichernutzung auch aktivieren (Ausgeschaltet/10%/18%(Standard)/26%).
Zu zRAM steht eigtl. alles bei Wikipedia: zRam - Wikipedia, the free encyclopedia
Das was im zRAM steht wird komprimiert um Speicherplatz zu sparen. Hier gibt es verschiedene Komprimierungsmöglichkeiten (das kann man sich so vorstellen wie z.B. "zip" und "rar" Archive). Snappy ist ein Komprimierungsmethode entwickelt von Google. Der Stock Kernel benutzt lzo Kompression, die komprimiert zwar etwas "besser", d.h. die gepackte Größe ist etwas kleiner, allerdings ist Snappy deutlich performanter.
Snappy: snappy - A fast compressor/decompressor - Google Project Hosting
LZO: Lempel-Ziv-Oberhumer
Natürlich, allerdings wird der zRAM hier eben mit dem LZO statt mit Google Snappy Verfahren komprimiert. Letzteres ist einfach "schneller".
Kann ich den Temasek Kernel einfach mit dem CWM Recovery drüberflashen oder muss ich wipen?
Flashen und Dalvik wipen.
Das Flashen des Kernels hat funktioniert. :thumbup:
Ich liebe die CM7 von Temasek. :thumbsup:
Jetzt stellt sich mir nur die Frage nach einem Launcher. Da gehen die Meinungen offensichtlich weit auseinander. Während HIER der Go Launcher favorisiert wird, ist man HIER entgegengesetzter Meinung. HIER wird festgestellt, dass der ADW Launcher Ex besser ist, als der integrierte ohne Ex.
Tja, wie soll man da zu einem schlüssigen Ergebniss kommen?
Indem du einfach selbst testest ;-)
Da gibt es kein besser oder schlechter, beide sind gut und es kommt darauf an, welcher einem persönlich eher zusagt.
Ich hab mir ADW Ex gekauft und es nie bereut - wobei ich es schade finde, dass schon so lange kein Update mehr kam. Bei CM9 nutze ich den Stock (Trebuchet) Launcher.
Verflixt, wie bekomme ich denn die Uhrzeit oben in der Statusleiste angezeigt? Das Häkchen bei Einstellungen -> CyangonMod -> Benutzeroberfläche -> Statusleiste -> Zeige Uhr ist gesetzt. Kann mir bitte jemand helfen?
Der ursprüngliche Beitrag von 22:34 Uhr wurde um 23:09 Uhr ergänzt:
Ich hab es hinbekommen. Die Uhrzeit wurde angezeigt, allerdings in schwarzer Schrift auf schwarzem Hintergrund. :laugh: Ich musste also nur die Farbe ändern.
Ich hab jetzt die Build 107 geflasht und weil der Akkuverbrauch von der Galerie so hoch war, hab ich sie Kurzerhand deinstalliert und QuickPic installiert.
Jetzt ist aber noch ein Überbleibsel vom der Galerie da.
Wie bekomme ich jetzt das com.coloris.media weg? Hab schon im system/app Ordner geschaut aber nichts passendes gefunden.
Vielleicht kann mich ja jemand auf den rechten Weg bringen.
Gesendet von meinem Optimus 2X mit Tapatalk 2
Das mit der Galarie ist wohl ein Bug, der Verbrauch ist nicht so hoch wie dargestellt. Irgendwie werden sämtliche Sensor-Daten der Galerie zugeschoben, obwohl diese gar nicht läuft. Ich nutze kein CM7 mehr und kann das deshalb nicht aus eigener Erfahrung bestätigen, aber temasek selbst meinte man soll es einfach ignorieren.
sgspluss
djtw09
djtw09
luk
  • luk
2 3 4
CHaindog
CHaindog
R4G3
MyFirstTablet
