saory
- 5
Also ich benutzt den apex launcher und da geht recht einfach
nur WLAN zieht Akku wie sau
Gesendet von meinem LG-P990 mit Tapatalk 2
JMH9477 schrieb:Komisch weis nicht was ihr alle habt, habe normale Nutzung mit dem Akku, mal den Akku neu Kalibriert und dannach zurückgesetzt.
Nehme diese Progis Battary Dr Saver und BatteryCalibration.
Wie gesagt habe keine Probs
tonyp schrieb:Okay, I finished build 5. it's already up!
I worked too long on this - am pretty tired now. You'll get the full changelog tomorrow.
Here are a couple of the new features:
- lots and lots and lots of bugfixes.
- New feature "see through lockscreen". Enable it at Settings - Lock Screen - See through. Screenshots
- New notification toggles.
Go to Settings - System - Notification Toggles. You can now choose the layout - icons or switches. Screenshot
and you can enable a AOKP like notification brightness slider! Perfect for our non working auto brightness.
(you have to resetup your toggles).
This is a WIP. There are not all buttons included, yet - and the icons won't "stretch" (you'll notice this when you have less than 6 icons only).
It will get even better over time- Superuser has been replaced by SuperSU.
- Statusbar transparency has been reverted. Will include it again with the next build.
As I said full changelog tomorrow.
If you appreciate this work as always: press thanks, rate this thread 5 stars, recommend it to your grandmother and consider a donation.
