			Magiya
LG O2X GB STOCK MOD
BY TOPOGIGI
FEATURES:
- Based on Erestor6's O2X GB Flair Lite (Thanks to Erestor6 for V20C leak) - From 1.4 completely rebased on leaked LG v20e
- Choice between Stock, Neoblaze 14092011 or Swiftextreme 180822011 Kernel (Thanks to Fajarep and Imperticus for custom kernels)
- Choice between EXT3 or EXT4 filesystem for /system, /data and /cache partitions
- init.d support (only for custom kernel versions)
- CIFS (only for custom kernel versions)
- TUN (only for custom kernel versions)
- Integrated Voodoo Sound (only for custom kernel versions)
- Deadline scheduler (only for custom kernel versions)
- RAM Optimizer script in init.d (only for custom kernel versions)
- OC up to 1400 Mhz (via SETCPU, Antutu CPU Master or Pimp my CPU) - (only for custom kernel versions)
- Boot at stock speed (unmodified: 1000Mhz)
- UV (via Pimp my CPU) - (only for Swiftextreme kernel versions)
- LG Launcher with UI 2.0 meteo widget (Thanks to Fonsigno)
- Stock framework with some light mods by me
- Removed some crap from LG
- Latest GMAIL app included
- Latest Adobe Flash Player included
- Latest Youtube app included
- Latest Maps app included
- Circular Battery Mod with percentage
- Sqlite patch (Thanks to Paul from Modaco)
- Overclock daemon (Thanks to Sybregunne)
Long story short, this is a Gingerbread ROM with stock appearance, but with all the Froyo candies we are used to.
Feedbacks are welcome.
DISCLAIMER: This ROM comes with NO warranty. If you brick your phone, don't blame me, I'm only experimenting with my phone and sharing the results with you, mates!
INSTALLATION INSTRUCTIONS:
- Choose one of the versions listed below and download it
- Flash GB baseband as per Erestor6's thread Multiupload.com - upload your files to multiple file hosting sites!
- I assume you have CWM recovery installed on your phone. If not, read one of the excellent tutorials on this site and install it. (Remember to choose one of the latest CWM if you have chosen a Rom with EXT4 filesystem)
- Copy the file you have downloaded "as is" (don't try to extract the files contained in the .zip archive!) in the root directory of your SD Card.
- Boot in CWM, select "Install zip from SD Card", then choose the .zip archive you have previously copied and wait until the process ends.
- Reboot your device and enjoy your new rom.
- Remember to flash backtoext3 before installing my rom if you have chosen an EXT3 Rom coming from an EXT4 ROM!!!
P.S. This rom does not wipe your phone (see changelog for exceptions), but depending on the Rom you actually have on your device, you'll need to convert your /system and /data partitions to a new filesystem. If you are on an EXT3 based rom, and you have chosen an EXT4 rom, automatic conversion without wipe is performed during install. But if you actually have an EXT4 based rom, and you have chosen to install an EXT3 based rom, you will need to run the backtoext3 (Thanks to Paul from Modaco) provided utility to convert the filesystem back to EXT3, and this utility WIPES ALL YOUR DATA. Anyway, my personal advice is to backup all your data before installing a new Rom!!!
KNOWN ISSUES:
- With Swiftextreme custom kernel sometimes the notification curtain does not wrap up with ease swiping the bottom part of the screen. Use the back button to wrap it up (this happens only with Swiftextreme custom kernel, use Neoblaze 15092011 if possible)
- The device seems snappier with v. >1.6. So, if you don't need the special features offered by the other custom kernel versions, choose v.1.6 at least.
- Sometimes when you charge the device, the battery indicator becomes unresponsive and battery seems not to be charging. Workaround: Detach and attach the charging cable. (solved in v20e/v20i based releases)
- With Neoblaze kernel in v. 1.3, you can't use Pimp my CPU to undervolt. Overclock is available via CPU Master.
- Very long Boot time in some custom kernel releases, due to DEXOPT performed at every boot time (working on it, should be solved ASAP) - Use a release >1.5 if you need shorter boot times!
- Market works properly on 1.5/1.6/1.7 only after first reboot. Will solve it ASAP. DON'T TRY TO FIX PERMISSIONS OR OTHER WORKAROUNDS LIKE WIPE! A simple reboot is enough to make market work
- Custom kernels in v20e based version have a dead zone along the right edge of the screen that makes scrolling and typing hard. (solved in 1.6 release)
- Some people reporting battery drains with 1.7, some other reported that this is the most battery efficient rom available.
- In v. 1.9 during initial setup language is not changed automatically
All these issues (besides market issue) seem to be disappeared with v. >1.6 release.
Good luck!
DOWNLOAD:
1.2a - Stock LG GB kernel with EXT3 partitions MEGAUPLOAD - The leading online storage and file delivery service
1.2b - Custom Swiftextreme kernel with EXT3 partitions MEGAUPLOAD - The leading online storage and file delivery service
1.2c - Custom Swiftextreme Kernel with EXT4 (/system and /data) partitions MEGAUPLOAD - The leading online storage and file delivery service
1.3 - Custom Neoblaze Kernel with EXT4 (/system, /data and /cache) partitions MEGAUPLOAD - The leading online storage and file delivery service
1.4 - Stock LG GB v20e kernel with EXT3 partitions MEGAUPLOAD - The leading online storage and file delivery service
1.5 - Custom Neoblaze Kernel with EXT4 (/system, /data and /cache) partitions adapted for LG V20E MEGAUPLOAD - The leading online storage and file delivery service
1.6 - Custom Neoblaze 21092011b Kernel with EXT4 (/system, /data and /cache) partitions adapted for LG V20E MEGAUPLOAD - The leading online storage and file delivery service
1.7WIPE - Custom Neoblaze 21092011b Kernel with EXT4 (/system, /data and /cache) partitions adapted for LG V20E MEGAUPLOAD - The leading online storage and file delivery service
1.7NOWIPE - Custom Neoblaze 21092011b Kernel with EXT4 (/system, /data and /cache) partitions adapted for LG V20E MEGAUPLOAD - The leading online storage and file delivery service
1.7 SP1 Service Pack 1 for 1.7 - It contains: The new 28092011 Neoblaze kernel with my ramdisk, a new (I hope final) version of services.jar only with GPS patch, S07cpufreqenabler script that allows monitoring programs such as System Panel to have access to the current CPU frequency and S08volt_scheduler script that allows you to UV and choose one of the available schedulers. http://forum.xda-developers.com/atta...1&d=1317234854
1.8 Custom Neoblaze 28092011 Kernel with EXT4 (/system, /data and /cache) partitions adapted for LG V20i MEGAUPLOAD - The leading online storage and file delivery service
1.8 SP1 Service Pack 1 for 1.8 - It contains: - unsecure adbd in ramdisk: now you can run adb shell as root directly and adb remount will also work without issues- back to the original juwee ramscript. The new one caused some issues such as frequent launcher redraws - New services.jar based on GR3 for BBA support but patched by me for GPS instant fix. Quicker than ever - Tweaked volt-scheduler so that undervolting is executed without delay - Terminfo support for editors like nano, etc - Nano editor in /system/xbin for easily editing of text files under adb (Linux supported, Windows "cmd" does not support curses) and with terminal emulator. http://forum.xda-developers.com/atta...2&d=1317911938
1.9 Custom Neoblaze 28092011 Kernel with EXT4 (/system, /data and /cache) partitions adapted for LG V20i MEGAUPLOAD - The leading online storage and file delivery service
1.9SP1 Introduced vsnet patch from CM: now the phone will sleep correctly also when your network supports fast dormancy (better battery life) and switching between wireless data and wifi does not lead to missing routes.- Some adjustements to SystemUI.apk, but no solution to the USB mass storage icon disappearing when you hit the home key. - Attempt to make USB tethering work (need feedback). http://forum.xda-developers.com/atta...0&d=1318346596
2.0 Custom SPICA HP RC1 Kernel with EXT4 (/system, /data and /cache) partitions adapted for LG V20e MEGAUPLOAD - The leading online storage and file delivery service
2.0SP1 - LG IME updated from v20j for better international keyboard support - Reverted some libraries from v20j to the v20e originals. Did not notice any improvement using those and some people complained about worse audio quality - Modified wpa_supplicant for those having problems with wifi - Added BBA support (so I hope, cannot check it as I didn't buy the app, just followed lilhermit's infos found on Modaco) - Removed startup and shutdown sounds as per many requests. MEGAUPLOAD - The leading online storage and file delivery service
2.0SP2 - Reworked and debugged the poweroff menu: now the bug in trapacska's version is defeated - Back to latest Neoblaze kernel: I had some issues with Spica's HP and some people need a stable/not testing rom, but everyone could flash the new HP RC3 kernel over that for testing or benchmarking purposes: I've already tried to flash it on top of SP2 and it works fine. If you want a way back to neoblaze, just reflash SP2 - Regulatory domain setting is back in wifi advanced settings. (Weird enough, it disappears if you set the rom as not debuggable in ramdisk. Spica kernel was not the guilty part....) - Removed overscroll glow - THIS UPDATE IS NOT CUMULATIVE! FLASH SP1 FIRST! MEGAUPLOAD - The leading online storage and file delivery service
2.0SP3- Completely reworked framework to ensure compatibility with UOT kitchen - WARNING: It could be possible that after flashing this update, you'll need to relog into your synchronized accounts (Google, Twitter, etc.) and resync. Probably your wallpaper will be reset to the default one. MEGAUPLOAD - The leading online storage and file delivery service
__________________
OPTIONAL DOWNLOADS:
Neoblaze 15092011 - Custom Neoblaze Kernel with EXT4 (/system, /data and /cache) partitions and Pimp my CPU support (UV/OC) MEGAUPLOAD - The leading online storage and file delivery service (This kernel can be flashed on top of every release based on v20c, BUT it has EXT4 filesystem conversion built-in) - THIS KERNEL SHOULD WORK ALSO WITH FLAIR GB V3 ROM
CBMOD4V14 - Circular battery mod and other framework mods for v. 1.4 MEGAUPLOAD - The leading online storage and file delivery service
CAMERA MOD - Improved camera with higher bitrates (Thanks to AndiCP) http://forum.xda-developers.com/show....php?t=1268622
OVERSCROLL/REBOOT OPTIONS - Various options to add nice glowing effects on overscroll and many choices to poweroff menu (Thanks to trapacska) http://forum.xda-developers.com/show....php?t=1260858 - Here you will also find the easy way to get rid of LG lockscreen
NEW MARKET - Market v. 3026 for those not receiving the upgrade from google (Thanks to Lucfig) http://forum.xda-developers.com/atta...5&d=1316503317 - Alternative: Market v. 3113 (Thanks to Striatum_bdr) http://forum.xda-developers.com/atta...6&d=1316503401
BGB - Theme made by 75markus - wonderful theme with blue accents http://forum.xda-developers.com/show....php?t=1270327
APPWIDGETPICKER - Nice app that organizes your widgets and allows to use LG widgets with third party launchers (Thanks to boombuler) forum.xda-developers.com/showthread.php?t=780828
GPSFIX - For those having problems with GPS with 1.4/1.5/1.6 release, here is my patched services.jar coming from v20c based releases http://forum.xda-developers.com/atta...4&d=1316714446
GB ORIGINAL ICONS - For those wanting the original GB icons for notification bar alongside a nice "not circular" percentage battery http://forum.xda-developers.com/show....php?t=1305437
ERESTOR6'S THEME MORPHER A really great way to enhance your user experience with an invaluable collection of astonishing graphical mods http://forum.xda-developers.com/show....php?t=1287846
Andrev OC Adjuster From TrymHansen, a wonderful GUI for overclok daemon http://forum.xda-developers.com/show...7#post18273457
Myrt Undervolt GUI From TrymHansen, a wonderful GUI for undervolting your kernel [USE IT CAREFULLY!!!!!] http://forum.xda-developers.com/show...5#post18347505
CHANGELOG:
1.0 Initial Release [OBSOLETE]
1.1 Attempt to fix Wifi, GPS and Tethering issues - Ext3 Filesystem for /data and /system (USE BACKTOEXT3 BEFORE INSTALLATION!) - Stock kernel [OBSOLETE]
1.2 Multiple choices between stock and custom kernel and/or EXT3 vs. EXT4 filesystem - Removed preinstalled Flashplayer [OBSOLETE]
1.3 Switched to Neoblaze custom kernel and tweaked EXT4 filesystem for /system, /cache and /data partitions - Removed preinstalled Flashplayer [OBSOLETE]
1.4 Rebased on LG GB v20e and tweaked EXT3 filesystem for /system, /cache and /data partitions - Removed preinstalled Flashplayer - Removed circular battery mod (see optional downloads for a patch to reinstall it) - This version wipes your data during install [ACTUAL]
1.5 Neoblaze 15092011 custom kernel adapted for LG GB v20e - Tweaked EXT4 filesystem for /system, /cache and /data partitions - Removed preinstalled Flashplayer - Circular battery mod - Smaller clock on notification bar - Semi transparent notification curtain (Thanks to Kostja_V for letting me use his base) - Added proper support for init.d - This version wipes your data during install [OBSOLETE]
1.6 Neoblaze 21092011b custom kernel adapted for LG GB v20e - Extremely tweaked EXT4 filesystem for /system, /cache and /data partitions - Removed preinstalled Flashplayer - Circular battery mod - Smaller clock on notification bar - Semi transparent notification curtain (Thanks to Kostja_V for letting me use his base) - Added proper support for init.d - Solved horizontal scroll bug on right edge (Imperticus, you're a wizard!) - added latest Maps app - Reorganized scripts in /etc/init.d - Added overscroll glow and extended poweroff menu - added camera tweaks - This version wipes your data during install - SIMPLY REBOOT IF MARKET DOES NOT DOWNLOAD APPS[OBSOLETE]
1.7 All the features already in of 1.6 release plus: +20 Mb of ram gained by removing omadmaclient.apk (the LG ota updater) and patching Services.apk - Overclock daemon! Please uninstall SETCPU, PimpMyCpu, CPU Master before flashing the rom, as they are not compatible with the daemon - AD-HOC wifi support: you can now connect to this type of wireless networks - New APNS from latest CM7 Updated Google apps (new Maps, new Market) - Patched services.jar included for instant GPS fix - Appwidgetpicker included - Two flavours: NOWIPE for those coming from 1.6 and WIPE for those coming from other roms. Read the thread to properly set overclocking in this rom. [OBSOLETE]
1.8 Rebased on v20i with all the usual patches and mods of my previous releases - Back to old market: it will be replaced by the new one automatically after the first access, but this time you will not experiment issues with the "application is not compatible with this device" bug.- Revised deeply the S08volt_scheduler script: I always asked myself why the standard script from pimpmycpu did not help in changing schedulers on boot, now I got the answer and you can freely change the scheduler and it will stick on reboot (if you want to change undervolt settings and scheduler settings, edit the volt-scheduler file in /system/xbin) - Battery drain defeated: still not behaving like v10d but battery consumption is quite good - Cleaned /system/app and removed one file regarding LG remote support I forgot to remove in 1.7 - Deadline scheduler is now the default scheduler. Better than bfq in my tests - Removed extended poweroff menu as it was bugged. Waiting a new release from trapacska before putting it back in. - New Juwee ramscript included - SPECIAL NOTE: THIS IS A NO-WIPE VERSION, SO IT COULD BE USED "AS IS" ONLY BY PEOPLE COMING FROM 1.7. IF YOU ARE USING OTHER ROMS, FLASH 1.6 BEFORE FLASHING 1.8, COMPLETE THE SETUP WIZARD OPEN WIFI SETTINGS AND CONNECT TO ANY NETWORK, THEN REBOOT AND FLASH 1.8! IF YOU DON'T FOLLOW THESE INSTRUCTIONS, YOUR PHONE WILL BE PROBABLY STUCK IN A REBOOT LOOP [OBSOLETE]
1.9 Solved the issue with wifi settings (so I hope) - Theme Morpher (v20i) compatability - Reworked framework and systemui, now they are entirely based on v20i - Solved issues with installation process. Now we can install 1.9 directly (market works after the first reboot as usual) - Patched gtalk video call (need feedbacks, cherry picked from GR3) - Solved issue with poweroff - Reduced battery drain (so I hope, need feedback)- Now the icons on the status bar have the position they have in all other Android phones when wifi is active. - Solved the issue with network settings (need feedback) - THIS ROM WIPES YOUR DATA! BACKUP FIRST! SIMPLY REBOOT IF MARKET DOES NOT DOWNLOAD APPS. [OBSOLETE]
2.0 Spica 24bpp RC1 HP kernel - SuperchargerV6 update 8 in /system/xbin (the file is called v6sc.sh) - Rebased on v20e with libraries, part of the framework and apps from other releases - Google apps updated - Superuser and su binary updated - Es file explorer updated - Polaris office updated from v20j - Back to the old market: it will update by itself if you follow the installation instructions (reboot after the setup wizard) and it will not give any compatibility problem - Introduced gps.conf for faster GPS fix - THIS ROM WIPES YOUR DATA! BACKUP FIRST! SIMPLY REBOOT IF MARKET DOES NOT DOWNLOAD APPS. [ACTUAL]
UTILITIES:
BackToEXT3 - Flash it ONLY if you have chosen an EXT3 rom coming from an EXT4 rom (THIS WIPES YOUR DATA!) http://forum.xda-developers.com/atta...8&d=1316120010 Thanks to el charlie and Paul from Modaco
FAQ:
A collection of useful FAQ on this rom: http://forum.xda-developers.com/show...postcount=2126
CREDITS:
- Zeppelinrox for Supercharger [Script][U9 RC4!] ALL WHEEL DRIVE -=V6 SuperCharger=- FIX RAM & Launchers, 3G & KAK! - xda-developers
- Erestor6 for his initial V20C base
- Paul O'Brien from Modaco for his wizardries
- Juwee for the first ramscripts
- AndiCP for all camera mods http://forum.xda-developers.com/show...php?p=18321559
- TrymHansen for his wonderful apps and support
- Squide for being always here with us
- Fonsigno for his UI 2.0 widgets
- Sybregunne for andrev_oc
- Spica, Imperticus, Fajarep for their unvaluable work on the kernels
....and many others that helped sharing their ideas and work for free.
Quelle:
[ROM] 20111014- lg o2x gb stock mod by topogigi v. 2.0 - Back in black - xda-developers
			BY TOPOGIGI
FEATURES:
KNOWN ISSUES:
Good luck!
DOWNLOAD:
__________________
OPTIONAL DOWNLOADS:
CHANGELOG:
UTILITIES:
FAQ:
CREDITS:
Quelle:
		 (zumindest bei mir)
 (zumindest bei mir) Keine Ahnung wieso es nicht gehen will, hab schon mehrmals neugeflasht
