R4G3
Stamm-User
- 50
Gueste2X "GoodBye" v2.0R
... one ROM to please them all
Basiert auf den besten Teilen aller offiziellen LG Gingerbread 2.3.4 ROMs v20E & v20M & v20Q & v20S plus Teile der CM7 Hybrid Revolution ROM!
Zusätzlich ist diese Rom mit dem neusten guestekrnL (Kernel) v2.2.1 ausgestattet, welcher extra für diese ROM erstellt wurde.
All thanks to Stefan Gündhör
Gueste2X GoodBye v2.0R (rebuilt, updated) als NVFlash Version oder CWM ZIP
Changelog neueste Version:- v2.0R
- NVFlash version added:
- allows you to unbrick your device
- allows you to go back from ICS and new bootloader directly to this ROM and Gingerbread bootloader + partitioning layout
- provides increased /system partition size of 512 MB, so it is compatible with tonyp/harsh ICS ROMs (full version)
- provides increased recovery partition size of 50 MB
- provides increased /data partition size of 1.85 GB
- Comes with CWM5 taken from Homero's NVFlash ROM, thanks and credits to him
- Noob-Secure installation process, user is told what to do and asked for permission
- Allows backup and restore of /data partition (when coming from Gingerbread-compatible partitioning layout)
- wipes internal SD card
- allows restoring of stock LG internal SD card contents (some music, apps,...)
- CWM ZIPs and general changes in all versions:
- upgrade to latest guestekrnL (kernel) v2.2.1 (release NOV 20 2012) - for providing latest features and maximum smoothness
- v20J RIL included per default. Best combination is with v20L BaseBand (available in download folder, install it for best power consumption!)
- Music Player Bugfix for v2.0 of the ROM already included
- updated ad blocker
- when performing /data wipe, you will get a system exactly like you had it directly after ROM flash, without losing any of the pre-installed apps of the ROM
- faster CWM installation process thanks to delivering /system partition contents as ext4 image file
- no more Aroma installation needed, best available guestekrnL will be installed per default (spica toolchain edition HOC)
Original Thread bei XDA: xda-developers - View Single Post - [NOV20][ROM][STOCK] Gueste2X "GoodBye" v2.0R - ultrasmooth [HYBRID][UNBRICK][RAMHACK]
Wenn du eine ROM willst die smoother, schneller und Energiesparender läuft als meine ICS Stock ROM Versionen, dann solltest du diese Version ausprobieren. Damit verdient das Speed endlich seinen Namen!
Download alle Rom Versionen: Goo.im Downloads - Browsing Gueste2X_GoodBye_v2.0R__NVFlash_or_CWM (Für Chrome User: falls du keine Dateien siehst, probiers mit Firefox)
Themes für die ROM (mit oder ohne Musicplayer in der Statusbar etc.): My Files (Themes nicht direkt nach dem Flashen installieren, Gerät erst einmal booten)
Download Boot Animationen: My Files
Installation:
Installation:
- NVFlash Version: Dateien runterladen, entpacken den Windows oder Linux installer starten ( APX Treiber zuerst installieren! Bei Ubunut64 ia32-libs)
- Akku entfernen, +/- Volume drücken und dann USB anschließen
Wenn du vom Gingerbread-Partitions Layout kommst kannst du deine Daten via backup und restore direkt im installer sichern. Die Interne SD Karte wird gewiped! - CWM Zip 3xx MB system partition: Einfach mit CWM flashen, evtl. Full Wipe vorher via CWM. Kann nur geflasht werden wenn du das GB Partitions Layout hast, nicht das von ICS.
- CWM Zip 5xx MB system partition: Einfach mit CWM flashen, evtl. Full Wipe vorher via CWM. Kann nur geflasht werden wenn du das GB Partitions Layout has mit >=512 MB /System Partitions Größe, nnicht ICS!
- Wichtig für alle Versionen: Installiere die THEMES nach dem du die ROM einmal gestartet hast. Falls der Market nicht geht einfach nochmal neu starten dann sollte es gehen!
Komplette Source vom KernerL https://github.com/StefanGuendhoer/guestekrnL_for_stock_v1.6.2_upwards
- Cyanogenmod APN List
- light-weight ROM d.h. Müll entfernt
- neuster guestekrnl
- Reboot Option im Shutdown Menu
- neuste Version vom fantastischen GuesteOC tweaking app by TrymHansen (Overclocking)
- Taschenlampe von CM7
- deodexed
- ext4 file system
- Optimiert auf Performance
- Unglaublich schnell und stabil!!!
- Verschiedene Themes und Bootanimationen zum downloaden!
- ROOT
- zusätzliches Gingerbread keyboard
- LG UI Home 2 Launcher, modded (ohne SNS)
- Unbrickt dein Gerät!!!
Changelog latest version:
- v2.0R
Diese Rom wurde von Stefan Gündhör erstellt, an dieser Stelle vielen Dank dafür!
Es ist wirklich die erste ROM mit das Speed seinen Namen verdient.
Ein Danke kann nicht schaden.
Übersetzung: R4G3
Übersetzung: R4G3
! ! ! Weder ich, noch Android-Hilfe ist für mögliche Schäden als Resultat der Befolgung meiner Anleitungen oder Nutzung der zur Verfügung gestellten Software verantwortlich ! ! !
