[ROM]: Zeus v1 by Huexxx GB 2.3.4 V20N
  • 378 Antworten
mikle_01
mikle_01
Dauer-User
398
Es gibt ein neues ROM Zeus v1 by Huexxx.
Basiert auf N00BY0815 und Redy's ROM; jedoch mit weiteren Features:
v0
- Refformated ramdisk in order to use ext4
- Modified default.prop with ro.secure=0 to gain root access
- Completely deodexed and zip-aligned
- /system/etc/flex/flex.xml: FLEX_COUNTRY_CODE="COM" to be universal
- build.prop: ro.product.locale.language=es and ro.product.locale.region=ES,es to - boot on spanish language (flash this patch to set english by default, v2 will come in english...)
- Corrected original Busybox from nandroid
- Read buffer of MMC devices raised to 1024
- Deleted the majorty of LG widgets and apps
- Includes original Gingerbread Launcher with new wallpapers
- Includes my battery icons with percentage and chromatic change
- Includes APN to all companies (from CM7)
- Changed Bootanimation
- Enhanced gps.conf to run better and fix faster (enhanced for spain, follow this thread in order to modify /etc/gps.conf with your country/region)
- Patched hosts file to remove ads
- Added eRecovery to access CWM repeatedly pressing physical keys at boot.
- Market updated to version 3.4.4
- Modified DNS servers at resolv.conf to increase market speed
- Added sounds (from CM7)
- Several tweaks added to build.prop
- Added some apps: BatteryCalibration, Convertor Pro and Quick Boot (included too at xanadu's mod, thanks!)
v1:
- Added HTC IME mod v27 by jonasl like default keyboard
- Added apps Terminal Emulator, Appwidgetpicker and Google Quick Search
- Added Nano Text Editor and bash
- Added sysro y sysrw scripts to easily change /system write premissions
- Added init.d folder support
- Part of the tweaks moved from build.prop to init.rc
- Patched libsqlite.so to increase SQL database read speed
- Deleted libGLES_android.so to increase 3d performance
- Modified APNs config to fix Orange World E
Reaktionen: Duffboon und SaschaKH
Coole Sache - gleich mal aufspielen und gucken wie die so lüpp :D
Soll ja rennen wie Sau, wenn man sich das im XDA-Forum mal durchliest. Werde es die Tage wohl auch mal testen.
Absolut zu empfehlen das ROM: +1!!
Schnell, flüssig, keiner Ruckler, Akku sieht auch bis jetzt gut aus (geht in Sleep Mode). Hab den Go Launcher X und mit Titanium alle Apps zurück installiert. Alles funktioniert. Bin seit langem bereit, mich vom CM7 zu "trennen".
Du kannst zurück auf 10c oder 10e flashen (Anleitungen dazu gibts hier im Forum genug) dann rooten (Black jack) und dann die ROM von Huexxx installieren - alles in allen ca. 30 Min. Arbeit :blink:
Das einzig Neg., was ich entdeckt habe, ist die (in jedem ROM mal wieder auftretende und bekannte) GPS Fix time. Dauert elend lange - manchmal findet es gar nix. *grrrrrrrrr*
(..)Bin seit langem bereit, mich vom CM7 zu "trennen".
Wie sind denn so die Konfigurationsmöglichkeiten? Die sind (noch) mein Hauptgrund bei CM7 zu bleiben...
das könnte daran liegen:
Huexx hat GPS auf Spanien optimiert.
Ja habe ich schon gemacht -> von "ES" auf "DE" geändert. Bringt nix. Absolut kein Funktion. "GPS status and Toolbox" und A-GPS Reset hat nix gebracht.
EDIT: Eben noch mal die CyanogenMod ROM 7 zurück geflasht; GPS innerhalb von ~5 Sec. Muss also am "Zeus Rom" liegen.
Ist das ROM in deutscher Sprache oder mit dem Patch nur auf Englisch zu bedienen?
Ist auf deutsch.
Reaktionen: Crusher67
Moppel001 schrieb:
Du kannst zurück auf 10c oder 10e flashen... ...alles in allen ca. 30 Min. Arbeit :blink:
Hab ich gemacht, alles in allem sehr zufrieden, gibt ordentlich Gas :thumbsup:
Allerdings hab ich nicht die von dir erwähnten 30 Minuten, sondern eher über 3 Stunden gebraucht. Das Black wehrte sich mit Händen und Füssen gegen einfach alles. Doch letztendlich habe ich über die Tücken der Technik gesiegt :flapper:
Ich weiß nicht ob es nur bei mir so ist, aber ich habe diese draufgeschmissen und da sind mir eineige sachen aufgefallen:
- meinen ram hab ich nach 5 std betrieb nicht mal mehr auf 120 MB freien Ram gebracht, und dass mit mehreren Taskkiller (liegt es an dieser Custom rom oder an der stockrom?)
- und meinen akku musste ich innerhalb von 5-7 std wieder aufladen, und das fast ohne nutzung ( nur 1-2 std davon mit mobilfunk inet und wlan) und ansonsten war es in meiner hosentasche.
Sind diese dinge bei euch auch so oder bin ich in diesem fall ein auserwählter? (habe einen full wipe vor dem flashen gemacht)
Installier mal "CPU Spy" und schaue, wie prozentual die CPU Auslastung ist. Habe festgestellt, dass das "Zeus ROM" mal in Deep Sleep geht - und mal nicht. Beim CM7 z.B. geht das OB wirklich (sowie WLAN auch aus ist) kontinuierlich in den Tiefschlaf.
Nach Reboot des Zeus hab ich jedoch festgestellt, dass es wieder ging...merkwürdig:blink:
hab die rom auch drauf ´..und gps geht leider bei mir auch nicht..
Ich hab mein GPS auch nicht hinbekommen - und ich hab viel ausprobiert: etliche Tools und manuell die /etc/gps.conf geändert....geht einfach nicht *grrrrrrrr*
Also ich hab seit ein paar Tagen auch die Zeus drauf und hab mittlerweile keine Probleme damit. Anfangs lief die ROM ziemlich träge und hakelig. Es dauerte beispielsweise fast eine halbe Minute bis ich aus den Kontakten heraus ein Gespräch führen konnte...
Bei mir lag es scheinbar am Launcher!? Nachdem ich den Launcher-pro installiert hatte geht Zeus ab wie die Feuerwehr :)
@ mikle: GPS funzt ebenfalls tadellos, fix dauert unter einer halben Minute. Was nicht nur für's Cachen von Vorteil ist ;-)
Beste rom mit nova. Akku wlan inet super!
spiele ( fifa12 od. GTRacing) funktionieren super. Keine problem
TOP
Sent from my LG-P970 using Tapatalk
V2 ist draussen. Weiß jemand und die notification geht wue in cm? Machte ja bislang Probleme
Gesendet von meinem LG-P970 mit Tapatalk
JaR01
Kr0n05
Kr0n05
  • blasterxox
blasterxox
  • bundschuh
SaschaKH
SaschaKH
