Juli.
- 26
Dirty Unicorns für unser LG G4 ist draußen und irgendwie hat noch niemand einen Thread dafür erstellt. Hier ist der Link zum Thread auf xda: [ROM][6.0.1][Unofficial] Dirty Unicorns 10.0 LG G4 [H815] [12 April 2016]
About Us:
Dirty Unicorns is a project that started out with no name. It was a project that was first based off AOKP back in the early days of Jelly Bean. In the early days it was just a one man show on one device, the EVO 3D. Since then, many others have joined the project and it has grown exponentially.
We have seen a lot of talent contribute to this project of ours. Big or small, the focus was always on contributing to the community. That is ultimately why we do what we do. After Jelly Bean, we decided to move to a new base, OmniROM. While AOKP was fun, OmniROM proved to be even more exciting base because it challenged us to see what we could do with a project that had different goals in mind. We learned a lot and again, gain contributors. With Lollipop, we moved to an AOSP base with a lot of patches from CAF to make our older devices function as they should. We grew even more and learned a whole lot more.
It has been an awesome learning experience and is still not over! We are still learning every day and continue to move forward. Lastly, we DO NOT accept, nor ask, for donations. We don't believe in that. Everything that is necessary to keep this project going is out of our own pocket. Gerrit, Jenkins, Websites, Devices, etc. We will never ask for a dime. All we do ask, is that you have patience, search, read and try to enjoy the process with us!!
Kernel Source:
https://github.com/CyanogenMod/andro...el_lge_msm8992
Flashing Instructions:
- Verify that you're using the latest version of TWRP
- Perform a FULL WIPE as described below if coming from another ROM or a different version of Android
(A full wipe is when you wipe system/data/cache)
- Flash the latest version of this ROM
- Flash recommended GAPPS linked below
- Reboot and ENJOY!!
**If you fail to follow these instructions, please don't bother reporting any bugs**
**If you use Xposed, please don't bother reporting any bugs**
**If you use another kernel, please don't bother reporting any bugs**
Change Log:
Code:
Credit and Thanks:
We would like to give thanks to everyone that contributes to the Android community, big or small because every bit counts. Although we can't list each and every contributor within the Android community, we would like to highlight some of the teams and individuals that have made it possible NOT only with just this version of DU but throughout the years because we don't ever want to forget where we came from nor those that have helped us!
Special thanks to:
@Predatorhaze for testing the ROM
That said, on behalf of the DU team we say THANKS to....
JMZ Software
Baby Jesus
Code Aurora Forum
Omni ROM
Android Open Kang Project (AOKP)
Android Ice Cold Project (AICP)
XDA-Developers
SlimROMs
Preludedrew
Max Weninger
Team Black Out
CyanogenMod
Pure Nexus Project
**If we have left someone or some team out, we apologize and please PM us**
Download Links:
Version 10.0 - DU_h815_6.0.1_20160412-1846.v10.1-DIRTY-DEEDS.zip | by nitin1438 for G4
GAPPS - index · powered by h5ai 0.26.1 (http://larsjung.de/h5ai/)
Frequently asked questions:
The download link is slow, can you provide a mirror?
From time to time, we perform maintenance on our website but we do not authorize any mirrors. Please have patience!
I'm on a TEST BUILD and have this bug, can you help?
Please keep any discussion about test builds in the G+ community!
How can I get Viper4Android working?
Check this thread out This guy right here> +Lennon Barnes Making it easier to have the…
Are you coming from a ROM with Layers?
Make sure you remove your 'overlay' folders and perform a FULL WIPE
My battery stats are all messed and reporting the wrong percentage, what can I do?
Stop using another kernel. Do a FULL WIPE and flash the ROM again
Is this ROM CM based or AOSP based?
This ROM is based off AOSP
Does this ROM have layers or the CMTE?
This ROM uses the CM theme engine
Pulse doesn't work with [insert music app]
Check this thread out https://plus.google.com/101146731143...ts/TcSzc61xuVx
I'm getting a FC from the theme chooser, what gives?
This is due to restoring data/apps from Google. Go ahead and clear data and cache for theme chooser and theme provider then reboot you should be good moving forward.
I changed my LCD density and now the navbar looks weird, what gives?
This is currenly an issue that we are aware of and addressing. For now after you changed density reset navbar layout or stay on the stock density.
Other Links:
G+ community - https://plus.google.com/u/0/communit...28866939227235
ROM Source - Dirty Unicorns · GitHub
Gerrit - Gerrit Code Review
Crowdin (translations) - DirtyUnicorns — Translation Project on Crowdin
Jira (Bug Report / Feature Request) - System Dashboard - Dirty Unicorns
XDA: DevDB Information
[ROM][6.0.1][Unofficial] Dirty Unicorns 10.0 LG G4 [H815] [12 April 2016], ROM for the LG G4
Contributors
nitin.chobhe
Source Code: Dirty Unicorns · GitHub
ROM OS Version: 6.0.x Marshmallow
Based On: AOSP
Version Information
Status: Testing
Created 2016-04-13
Last Updated 2016-04-13
About Us:
Kernel Source:
Change Log:
Code:
Code:
Version 10.0
12 April 2016
First build
- First Release of MM
For a detailed change log, check http://gerrit.dirtyunicorns.com/#/q/status:merged,n,z
Credit and Thanks:
Special thanks to:
JMZ Software
Baby Jesus
Code Aurora Forum
Omni ROM
XDA-Developers
SlimROMs
Preludedrew
Max Weninger
Team Black Out
CyanogenMod
Pure Nexus Project
Download Links:
Other Links:
Contributors
nitin.chobhe
Based On: AOSP
Version Information
Status: Testing
Created 2016-04-13
