[ROM] LIMITLESS v10 | v30k | Marshmallow | D855/D855P
  • 57 Antworten
kingoftf
kingoftf
Ehrenmitglied
49.698
Hier noch ein Fundstück aus dem HTCmania und XDA.
Basis nun mit der Version 10 ist eine 30k
ROM [D855] ROM LIMITLESS STOCK DEODEXED v1.5 30b by CASSOLI
Thread auf XDA:
[ROM] LIMITLESS DUAL v4.0 | ODEX / DEODEXED | v30e | Marshmallow | D855/D855P
CHANGELOG v10.0:
- Full UX 5.0
- Base 30K
- Patch Security 01/05/2016
- Init.d
- Busybox
- 6 Toggles
- 3 Taps unlock Knock Code
- Navbar 32dpi
- SmartSettings
- SmartDoctor
- Tweaks performance and battery in build.prop
- Removed Google Apps
- Xposed working
Aroma options:
- Divine Beats Dolby Atmos v7 - Several sound enhancement options, excellent MOD recommend the installation. Removed ViperFX | Credits @TheRoyalSeeker XDA member.
- 3Minit - Several icon options for battery. | Credits @gharrington XDA member.
- XCamLG - Adds the camera extra Xcam version 6.2.4 MM. | Credits @xdabbeb XDA member.
Download:
Limitless_DUAL_V4.0_by_CASSOLI.zip | by Cassoli 2015 for G3
Download 4.1
Limitless_DUAL_V4.1_by_CASSOLI.zip | by Cassoli 2015 for G3
Download 5.0
Limitless_DUAL_V5.0_by_CASSOLI.zip | by Cassoli 2015 for G3
Download 7.0
Limitless_Custom_Stock_Rom_30A_v7.0_by_CASSOLI.zip | by Cassoli 2015 for G3
Download 7.1
Limitless_Custom_Stock_Rom_30A_v7.1_by_CASSOLI.zip | by Cassoli 2015 for G3
Download 8.0
Limitless_Custom_Stock_Rom_30K_v8.0_by_CASSOLI.zip | by Cassoli 2015 for G3
Download V 9
Limitless_Custom_Stock_Rom_30A_v9.0_by_CASSOLI.zip | by Cassoli 2015 for G3
Download V10
Limitless_Full_UX5.0_v10.0_by_CASSOLI.zip | by Cassoli 2015 for G3
Navbars
MEGA
Mod 3Minit
https://mega.nz/#!4kkiRCLb!qmrrdcbuu...gm4k-CJL-DFi5I
Mod Runde Ecken
MOD_BORDAS_ARRED_LIMITLESS_V1.5_BY_CASSOLI.zip | by Cassoli 2015 for G3
3Minit Deinstaller
https://mega.nz/#!EoU31aBI!JGwZyAjoa...IEJmJcVokTacPY
Fonts-Pack Stock
Lollipop_Fonts_Stock.zip | by blackcodetech for G2
Installation
Download der ROM aufs G3
Reboot in Recovery
Fullwipe Dalvik, Caché, System und Daten
Gewünschten Kernel auswählen
Gewünschtes Modem auswählen
Reboot (kann eine Weile dauern)
Einrichten
Flashen wie immer auf eigene Gefahr!!!
Für den Import von SIM-Kontakten den SIM-Manager benutzen, ist wohl ein Bug in der ROM
Screenshots:
01.jpg 02.jpg 03.jpg 4.jpg 05.jpg 06.png 07.jpg 08.jpg 09.jpg 10.jpg 11.jpg 12.png
Schaun wa Mal!
Muss erst Mal die Sense rausholen, viel zu viel Schnullifax!
Läuft aber!.....sehr gut!
Und, wer Schnullifax gern hat, da ist alles dabei, wirklich gut gemacht das Teil!
Reaktionen: kingoftf
Du flasht wohl auch jeden Tag ne andere ROM[emoji23]
Hatte die Rom geflasht, das dumme ist nur das sie nicht brauchbar ist da bei mir keine Sim Pin Eingabe kahm. Rom gleich wieder runter vom Handy und nun kann ich selbst bei meinem Backup die Sim Pin
nicht mehr eingeben. Voll blöd...
Bei mir das gleiche, keine SIM Abfrage und das ROM scheint sehr langsam zu sein.
Anderes Modem flashen, keine Stock-ROM mit Modem 30b erkennt die SIM
Schon traurig das das 30b Modem garnicht funktioniert....
Warum bietet man es dann überhaupt an???????
Reaktionen: jaloviina
Keine Ahnung, darauf hatte ein anderer Dev aufmerksam gemacht.
Das ist doch wirklich idiotisch, ein von vornherein nicht funktionierendes Modem (was ja auch bekannt ist) als Möglichkeit anzubieten... Und diese 6/7 verschiedenen 20er Versionen sind auch ein Witz, die haben sich bis auf Marginalien nicht unterschieden!
Es wirkt ein wenig als wäre das so hingeschustert ohne drüber nachzudenken? Türkei oder Asien würde ich tippen ;-)
Den Screenshots nach zu urteilen Brasilien. siehe Wetter widget
Steht auch so auf XDA:
1.6 ist draussen (als update) siehe XDA
Lohnt sich diese Rom im vergleich zur uniq?
uniq soll besser laufen, die Limitless läuft doch noch nicht so ganz rund laut den Usern bei HTCmania
Reaktionen: Black-Angel
Also ich hab die Limitless seit ein paar Tagen drauf und bei mir keine probleme. Wichtig war mir ne ROM mit LG Kernel, weil ich den XCeed nutzen wollte und ich meine, fast alle anderen roms kommen mit einem angepassten Kernel. Das hat bei mir beim Wechsel zum XCeed oft probleme verursacht. Aber ich denke, Geschwindigkeitstechisch nehmen die sich alle nicht viel ;-)
Ich habe die Rom heute geflasht und bei mir fehlt die Telefon App und die Kontakte App. Hatte jemand das Gleiche Problem?
Edit:
Gelöst... Hab einfach nochmal drüber geflasht.
Nehmen sich nicht viel (hatte mal die 1.6er probiert). Fulmics für mich runder ... Vorteil bei der Limitless: du bist auf 30c und nicht auf der B version. Ansonsten nehmen die sich nicht so viel, beide Deodexed. Ich finde die Fulmics hat mehr Pepp - aber Ansichtssache.
Reaktionen: mratix
ne doch.... nehmen sie sich viel in der Funktionalität !
Bekomme keine Schreibrechte auf meine externe SDCard, was bei Fulmics 4.2 ohne Probleme geht. Mit den Programmen WiFi File Explorer Pro gehts nicht und mit
dem Programm X-Plore auch nicht.
Hier mein Post auf xda Forum in der Limitless 2.0 Rubrik Seite 11 User: Pinarek:
Problem Writeaccess to my extern SDCard Sandisk 16Gb - Post #103
Edit:
Heute kam eine Antwort vom Brasilianer ccass: "Fixed in version 2.1...sorry" na ist ziemlich billig, meine Meinung ist, wenn man ein ROM rausbringt
darf so ein, für meine Begriffe schwerwiegender Fehler, das man nicht auf die externe SDCard schreiben kann, nicht passieren.
Habe schon wieder mein einzigartig gut laufendes Fulmics 4.2 mit dem Flykernel0.6 zurück gespielt aus der Sicherung, was auch tadellos funktioniert unter TWPR.
Später mal die 2.1 von dem Limitles ansehen und vor allem fehlen die schönen Anpassungstools wie sie bei Fulmics gleich mit drin sind.
Editiert, egal...
kingoftf
  • kingoftf
Splati
Splati
kingoftf
kingoftf
kingoftf
jigga1986
  • jigga1986
reinold p
reinold p
