kingoftf
Ehrenmitglied
- 57.439
Hier der Nachfolger der Dirty Unicorns Lollipop.
Erste Version als MM.
Dirty Unicorns stammt aus den Zeiten von Jelly Bean, damals noch aus AOKP entwickelt.
Nach Jelly beschlossen die Dev, als Basis OmniRom zu nehmen, es wurde also zu AOSP gewechselt.
Ab Lollipop mit Patches von CAF, als Basis ebenfalls AOSP.
Als Features bringt das ROM DU Updater, Themes "DU Certified" und Dirty Tweaks.
Und als Schmankerl die Smartbar.
Als Themes kann man die von CM installieren.
Thread auf XDA
[OFFICIAL][6.0.1_r13][D855] Dirty Unicorns v10.0 [DU TBO GAPPS]
G+ Community
https://plus.google.com/u/0/communit...28866939227235
Changelog 10.2
Version 10.2
- Update to Android 6.0.1_r43
- New and improved DU changelog app
- Show more accurate internal storage capacity
- Allow screen recording to record up to one hour
- Allow screen recording in landscape
- Replace hamburger menu icons with horizontal ellipsis
- Allow system_app access to setenforce
- Fix font changes for clocks
- Fix notification LED NPE
- Add in-app search bindable actions and resources
- Fix recents passing through Google search bar
- Fix off-center date on lockscreen when no alarm is set
- Fix hotspot client AP count
- Fix InCallUI contact image position
- Add SMS/MMS limitation feature
- Enable turn on data when MMS received feature
- Update Chromium to LKGR
- Use circular reveal for showing/hiding task manager panel
- Update SmartBar editor popup menu logic and animation refresh
- Update OmniSwitch
- Show the option for 'Show running apps' for AOSP recents
- Re-center lockscreen notifs
- Add a carrier config for default value of WFC user setting
- Allow Smartbar to unlock recent apps button and make it removable
- Fling: Up swipe left/right support
- Enable quick pulldown for all
- Add a check to see whether the wallpaper's size has changed
- Point Ambient display tile longpress action to it's own settings
- Various CMTE fixes
- Various optimizations and fixes
- Updated translations
Gerrit Code Review
Download:
http://download.dirtyunicorns.com/files/d855/Official/DU_d855_6.0.1_20160506-0255.v10.2-OFFICIAL.zip
Gapps:
index · powered by h5ai 0.26.1 (http://larsjung.de/h5ai/)
(wobei die opengapps auch problemlos funktionieren)
Installation
Download der ROM und Gapps aufs G3
Reboot in Recovery
Fullwipe, wenn von einer anderen ROM kommend, bei vorheriger ROM mit Layer wird empfohlen, den OverLay Ordner zu löschen.
ROM und Gapps flashen, Reboot und warten...... Und dann einrichten.
Flashen wie immer auf eigene Gefahr und ohne jegliche Gewährleistung seitens Android-Hilfe oder der Dev der ROM.
Credits:
JMZ Software
Baby Jesus
Code Aurora Forum
Omni ROM
Android Open Kang Project (AOKP)
Android Ice Cold Project (AICP)
XDA-Developers
SlimROMs
Preludedrew
Max Weninger
Team Black Out
CyanogenMod
Pure Nexus Project
Thread auf XDA
G+ Community
Changelog 10.2
Version 10.2
- Update OmniSwitch
Gerrit Code Review
Download:
Gapps:
Installation
Reboot in Recovery
Credits:
JMZ Software
Baby Jesus
Code Aurora Forum
Omni ROM
XDA-Developers
SlimROMs
Preludedrew
Max Weninger
Team Black Out
CyanogenMod
Pure Nexus Project
