kingoftf
Ehrenmitglied
- 47.505
Hier mal wieder was für die Flashaholics:
FlexOS, basierend auf CM 12.1, Dev ist Firebird11
[ROM] FlexOS [5.1.1] [cm-based] [weekly's] [… | LG G3 | XDA Forums
FEATURES
* FlexControl - All the tweaks and features at one place!
* Animation Control - Toast animations, Listview animations and system transitions.
* HeadsUp Customizations just like Cm11!
* Slim DSLV
* Navigation Bar Tweaks - On/Off Toggle, Dimensions
* Navigation Bar Tint
* Slim Advanced IME Features
* Statusbar Network Speed Meter
* Screen Sound Enable/Disable Toggle
* Camera Switch Sound Enable/Disable Toggle
* OmniSwitch - Use omniswitch alongside stock android recent apps or use it as primary.
* Recents FAB Button - Positions (Top left, Top right, Top center, Bottom left, Bottom right, Bottom center)
* LCD Density Adjuster
* Volume Steps
* Hide superuser icon in statusbar
* Double tap to sleep on navigation bar and status bar
* Instant reboot from power menu
* App Circle Sidebar
* Captive Portal - If disabled, a connection to google servers is not required in order to detect data connection.
* CyanogenMod Theme Engine
* Statusbar Clock Customization
* Volume Steps
* Inbuilt File Manager from OmniROM
* Quick pulldown
* Moar Material!
* Battery icon customization
*SlimPIE
* Statusbar Carier.
* Statusbar clock color.
* Statusbar clock font style.
* SlimPIE: Configurable sensitivity.
* SlimPIE: give user ability to reduce trigger heights if IME keyboard shows up.
* Ambient Display for certain devices.
* Statusbar: toggle for network activity arrows.
* Merged Battery Bar.
* Inbuilt Lantern Music Player.
* Sync, Screenshot, HeadsUp, NavigBar On/Off tiles on top of CM
* Gesture Anywhere
Download als Nightly oder als Unofficial
Download:
https://basketbuild.com/devs/FlexOS/d855/NIGHTLY
https://www.androidfilehost.com/?w=files&flid=31756
Der Dev weist darauf hin, dass er keinerlei Garantie übernimmt, wenn Euer G3 nach dem Flashen nur noch zum Flaschen öffnen oder als Bierdeckel zu gebrauchen ist, Flashen also auf eigene Gefahr....
Download Gapps:
[GAPPS][18-04-2015][5.x] PA-GOOGLE APPS Plus… | Android Development and Hacking | XDA Forums
Installation:
G3 mit voller Batterie, ROM und Gapps in den internen Speicher laden, Reboot in Recovery, Fullwipe ROM und Gapps flashen, Reboot, warten, fertig.
CREDITS
CyanogenMod
SlimRoms
OmniROM
crDroid
AOKP
AOSB
ThinkingBridge
Nico60, Temasek, Cristiano matos, snak3eat3r, etc.
@777jon
Leider noch keine Screenshots verfügbar
FEATURES
* Slim DSLV
* Volume Steps
* Volume Steps
* Quick pulldown
* Moar Material!
*SlimPIE
* Statusbar Carier.
* Gesture Anywhere
Download:
Download Gapps:
Installation:
CREDITS
CyanogenMod
SlimRoms
OmniROM
crDroid
AOKP
AOSB
ThinkingBridge
@777jon
