[ROM][24-Jan][D855][V20F]CRASH ROM V1.6 [Aroma Installer]
  • 310 Antworten
Wie gefällt sie euch?
  • Zufrieden
    Stimmen: 23 82,1%
  • Nicht meins
    Stimmen: 5 17,9%
  • Umfrageteilnehmer
    28
ShOoNuFf
Stamm-User
126
Weder ICH der Entwickler , Android-Hilfe.de oder XDA sind verantwortlich für jeglichen schaden an ihrem gerät die durch das flashen dieser Rom entstehen.
*Please don´t publish any mirror of my rom.
* I'm not responsible for any damaged caused by using this rom if you don´t follow the steps and precautions
I'm not a developer and not pretending to be one, I'm a android enthusiast.*
@My Wife and Kids*
@Cloudyfa (for let me use his Aroma Intaller save me from a lot of work)
@amarullz (for aroma installer)
@Dsixda (kitchen)
@Chainfire (superuser)
@_alexndr (help, support)
@gharrington (for 3minit mod)
@LG for stock base
@XDA
For my friends
@Criskelo (help and support)
@Kadoc (help and support)
@ffalete (help and support)
Please PM me if i missed someone*
Quote:
Diese ROM benötigt keinen FULL WIPE wenn sie performance Probleme haben ist es Empfehlenswert einen FULL WIPE durchzuführen.
* V20F Stock Base
* Stock Themed
* Add all the apps on multiwindow
* Add Callrecord
* NO Heavy mods Stock as posible with some of Crash Magic*
* Add Animations Weather on LockScreen
* Add camera mod 60 fps (Special thanks to @Dropdeaad2)(More info and support HERE)
* Add external SD write permissions
**FULL WIPE OPTIONAL IN AROMA
* Aroma Installer
* Rooted
* Tweaked for better experience
* Updated most of the apps
* Add Battery Stats (Special thanks to @chamonix)
* Add ES Explorer (Special thanks to ES Apps Group)
* Add AdWay (Thanks to AdWay Org)
* Add Download apk ( Thanks to MDJ Software)
* Add Trickster apk to control the kernels (thanks to @TeamTrickster)
* Add hundreds of ringtones, alarm, etc....
* Add Holo Reboot (Thanks to @Tim Scarborough )
* Add Key Plus (Special Thanks to @AppTuners)
CRASH ROM V1.5
* If you are runing V1 no wipes need it
* Based on 20F
* More Options in Aroma:
- Transparent Smart Weather
- Add boot sound
- On Google apps now you choose to REMOVE
- Nav Bar options 24,34,36 or stock
- Kernel stock now is available (optional)
* Update most of the system apps
* Add couple Tweaks for better wifi and 3G performance
* Update SU to 2.45
* BusyBox update to 1.23
* Rest is the same as V1
CRASH ROM V1.6
**wipe dalvik and cache before begining installation**
This is small changes if you feel fine with any previous version no need to flash this v1.6
* Base 20F
* Added T-Action (Special thanks to my dear friend @Claudyfa
* Add optional in Aroma Viper4 (Thanks to @AndrasLOHF for the steps HERE )
* Removed some scripts in aroma and fullwipe option too (hope this help with some users that experience data problems)
* Fixed stock kernel thanks to @Claudyfa (I need to dig more on it hehehe thanks @Skin1980)
* fix it Battery Stats apk problem
* Update most of the apps
Optional installierbar in Aroma
* LG Calendar
* LG Email Client
* LG Music Player
* LG Task Manager*
* LG Update Center
* LG Video Player
* LG Voice Mate
* Google Drive
* Google Gmail
* Google Hangouts
* Google Maps
Die restlichen GApps sind entfernt von dieser ROM können aber problemlos installiert werden vom Playstore.
* Battery Calibration apk (Thanks to @Néma)
* CPU Spy (Thanks to @Giuseppe Baglio)
* Led Manager (thanks to @MC Koo)
* Volumen Control (special thanks to @LaranSoft)
* Wakelock Detector (thanks to UzumApps)
* ZipInstaller (Thanks to beerbong)
* Thermal Control (70,75 and 80) (Special thanks to @Robshr)(LINK HERE FOR MORE INFO)
* 3MINIT Battery Mod (Special thanks to @gharrington)(More info HERE)
**3Minit battery mod right side clock
**3Minit Battery Mod Center Clock
**Stock Battery
ACHTUNG!!: SIE MÜSSEN EINEN DIESER KERNEL IM AROMA INSTALLER AUSWÄHLEN SONST WIRD DIE ROM NICHT STARTEN!!!!!!! (BOOTLOOP)
*Kernel Chupachups (Special thanks to @Skin1980)(FOR MORE INFO,HELP, AND SUPPORT OR DONATE CLICK HERE)
*Kernel Rin (Special thanks to @Tectas)(FOR MORE INFO,HELP, AND SUPPORT OR DONATE CLICK HERE)
Bitte machen sie eine Sicherung ( Backup ) ihrer Dateien bevor sie irgendwas Flashen. Nur zur Sicherheit!
Quote:
Wenn sie noch KitKat als Android System laufen haben bitte gehen sie nach diesen schritten vor :
(Links auf xda)[/COLOR][/COLOR][/COLOR]
Flash Last TWRP Recovery*HERE
Reboot to Recovery
Backup*Modem/EFS
Full wipe*(Dalvik, Cache, System & Data)
Flash*Lollipop baseband
WENN SIE LOLLIPOP ALS AKTUELLES ANDROID SYSTEM AM LAUFEN HABEN GEHEN SIE BITTE NACH DIESEN SCHRITTEN VOR :
(Link auf xda)
Dann
1- Put the rom in your internal or external sd
2- Reboot in Recovery Mod*
3- Flash the zip*
Fertig!
!!!!!!!BITTE INSTALLIEREN / FLASHEN SIE KEIN XPOSED UND DEREN MODULE DA DIESE MOMENTAN NICHT MIT ANDROID 5.0 LOLLIPOP KOMPATIBEL SIND!!!!!!!!
If you don´t have a MD5 Checking tool DOWNLOAD HERE:
https://www.androidfilehost.com/?fid=95897840722646155
MD5 329c4ffba0426c6084034b6436492364
ROM DOWNLOAD LINKS :
CRASH ROM V1_20F
Crash ROM v1.5 D855
Crash ROM v1.6 D855
NAVBAR MOD
Flash in Recovery
Contributors
Crash
ROM OS Version:*5.0.x Lollipop
ROM Kernel:*Linux 3.4.x
ROM Firmware Required:*Root,TWRP
Version Information
Status:*Stable
Current Stable Version:*V1
Stable Release Date:*2015-01-19
Created*2015-01-19
Last Updated*2015-01-19
XDA Link : [ROM][19-Jan][D855][V20F]CRASH ROM V1 [Arom… | LG G3 | XDA Forums
Reaktionen: f.h.73
Moin,
also die Rom ist wirklich schnell (gefühlt).
Im Antutu bringt die Rom mit den beiden Kernel nur 26000 Punkte. Warum auch immer.
Den Stock Kernel kann ich nicht testen da er sich zwar installieren lässt aber das Handy beim Reboot dann im fastboot Mode hängt!
Die Rom ist nicht groß verändert wurden...man kann die Apps selber Updaten 3Minit Paid zb)!!!
Unnütze Sachen sind von Haus aus schon weg oder lassen sich im Aroma installieren.
Greetz
Reaktionen: ShOoNuFf
Es ist schön und gut, wenn Roms hier auf android-hilfe.de vorgestellt werden. Aber eine 1zu1-Kopie mit Copy and paste sollte es nicht sein. Daher bitte ich den Threadersteller bis zum Wochenende den Eingangspost zu überarbeiten und auch zu übersetzen.
Danke!
Reaktionen: ShOoNuFf und f.h.73
Danke!
Was soll ich denn für dich übersetzten bzw ändern :)? Ist mein erster thread wusste nicht das man etwas beachten muss sorry ;).
Der ursprüngliche Beitrag von 12:29 Uhr wurde um 12:30 Uhr ergänzt:
BustedFly schrieb:
Moin,
Greetz
42.000 im antutu mit ChupaChups kernel natürlich mit Trickster Mod Einstellungen ;).
Der Dev legt keinen wert auf Benchmarks weil er sagt die sind zu leicht zum hintergehen. Ich hab auf einem G3 AnH 8.4 laufen und die kommt von der Smoothnes nicht an diese Rom ran. Ich hoffe sie gefällt euch viel Spaß beim flashen es lohnt sich ;)!
Schau dir die anderen Romthreads an, es sollte schon etwas in deutsch sein.
Okay werde ich tun ;).
Hoffe so ist es besser ;). Titel lässt sich igw nicht ändern. Halte euch auf dem Laufenden.
Reaktionen: bandit1976
Hey, kööntest du evtl die Bilder noch in einen Spoiler packen oder anhängen? Das zieht der Beitrag sonst ganz schön in die Länge :scared:
Hab jetzt den Stock Kernel zum testen drauf.
Nun gibts mehr im Antutu ca 44000 aber die Rom kommt nicht mehr so smooth rüber.
Welcher Kernel ( Rin oder Chupa Chups) ist denn besser (Akkulaufzeit) und mehr Fehlerfrei???
Bei dem ChupChups Kernel habe ich so das Gefühl das der DL über WLan langsamer ist als mit dem Stock...
Greetz
Werde das mit dem spoiler machen ;). Ich nutze ChupaChups schon immer finde den einfach super. Antutu ist total überflüssig finde ich persönlich. Flash dir einfach mal einen der 2 und stell sie dir dann im trickster mod nach deinen Bedürfnissen ein ;).'
Mit WLAN hab ich keinerlei Probleme läuft flüssig und stabil.
Reaktionen: BustedFly
Na ich werde das mal austesten mit den Kerneln.
Freu mich scvhon auf eine V2 dieser Rom.
Ja ich auch ;)
Hat der Stock Kernel jetzt doch funktioniert bzw. wie hast du ihn ans laufen gebracht?
Edit: Frage hat sich erledigt, habe es im anderen Thread gelesen, pfiffig gelöst!
Macht euch auf ein geiles update gefasst :).
Zitat von Crash :Hope you guys are flashcoholics like me hehehe I got v1.5 done with more options, performance and more in aroma including stock kernel option release the rom tomorrow. ASAP
Hugs
Kurz gesagt auf deutsch er hat v1.5 fertig mit mehr Optionen mehr speed mehr performance mehr aroma Einstellungen und und und ;).
Er und CloudyFa sind dir besten DeVs.
Poste das update sobald es da ist.
Bin auch schon gespannt wie ein Flitzebogen :scared:
Bin mir nur nicht so sicher welcher der beste Kernel für diese Rom ist.
Was mein Test (objetiv) bis jetzt ergeben hat:
Stock Kernel (von der ANHD 8.4, gesichert über TWRP)
Nicht ganz so smooth finde ich..dafür aber schneller DL über Wlan, Akku top.
ChupChups Kernel:
Sehr schnell (ausser im Benchmark), DL über WiFi langsam...und schwankend, zum Akku kann ich nix sagen
Rin Kernel:
Nicht ganz so schnell wie der ChupChups, DL über WiFi schneller aber nicht ganz so wie der Stock, Zum Akku kann ich auch nix sagen. Löschen einiger Apps gelingt nicht...nach Neustart wieder da..bei den anderen beiden Kernel alles gut.
Was den DL im WiFi angeht nun die Frage..liegt es an dem Kernel und des Einstellungen?
Zur Rom selber: Bin begeistert
Nicht so zu gemüllt wie andere Rom, Aroma Installer, Apps lassen sich selber Updaten (3minit zur Paid Version zb)
Denke da wird noch so einiges kommen bei der Rom....Ich freu mich mal drauf :thumbsup::razz:
Genau das ist was ich sage. Diese Rom ist nicht zu gemüllt und richtig sauber gemacht das gefällt mir so sehr dran. Ich finde das der ChupaChups kernel am besten läuft mit dieser Rom. Ich hab auch keine Probleme mit WLAN läuft alles perfekt. Ich flashe bei jeder Rom das baseband mit vll liegt es daran. Heute wir v1.5 hat Cash gesagt. Poste das Update sofort wenn es da ist. Ich bin total begeistert von dieser Rom.
Finde die Rom besser als ANHD, bloß WLAN hängt ziemlich. Gibt es ne Möglichkeit denn Stock Kernel irgendwo zu downloaden?
Hallo schön das die ROM dir gefällt, in weniger als 3 std kommt v1.5 raus und du kannst im Aroma installer dann Stock ,ChupaChups, oder Rin Kernel auswählen. Bis dahin bitte ich dic um Geduld ;).
Komisch hab keine Probleme mit WLAN. Falsch mal das LOLLIPOP baseband.
Na soviel Zeit habe ich dann noch und warte :biggrin: danke schon mal für die Info
Gerne ;)
CRASH ROM V1.5
* Based on 20F
- Add boot sound
* Update SU to 2.45
Der ursprüngliche Beitrag von 18:49 Uhr wurde um 18:51 Uhr ergänzt:
Hoffe habe dir die Info nicht vorweg genommen ShOoNuFf?
Kein Problem. Passe denn Startpost an ;) v1.5 butter weich kann es nicht glauben.... Ich liebe es !!!
jigga1986
  • jigga1986
reinold p
reinold p
I
  • Umfrage
  • itschaf
LZ_
kingoftf
  • kingoftf
Jan1977
