Sambia
Dauer-User
- 451
Freu mich darauf. Endlich wieder was zum flashen
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
Special Notes: This base have some complications during the test so I have to make the mods to be flash separately.Download the Aroma package and flash the mods you whan´t, Flash it soon as you finish to config the rom NO WIPES NEET IT Links at the end of this post
* BASED ON 20H
* No wipes Need It if you are coming from previous version
* Add Stock Kernel from base with init.d and permissive support added by @Crash
* Add all locks thanks to my freind @Cloudyfa
* Optional to remove in Aroma video editor
* Optional to remove in Aroma Tangible mod animation when plug in USB
* Optional to remove My Wellness
* Optional to remove Battery Stats
* Optional to remove Key Plus
* Optional to remove GSam Battery Stats
* Optional to remove AdWay
* Optional to remove Es Explorer
* Add Optional to install Modem from Base (recomended)
**The rest is the same as my previous version**
