[ROM] SlimKat - Android 4.4.2 für LG G2
  • 602 Antworten
blueHD
blueHD
WICHTIG:ICH ÜBERNEHME KEINE VERANTWORTUNG FÜR DIE RICHTIGKEIT DIESER ANGABEN
Die in meinen Augen bisher beste AOSP-KitKat-Rom für das G2!
Features:
  • Fully customizable quick settings the new way with new included music tiles and features
  • Notification drawer and quicksettings background as well with tablet support now
  • Notification transparency
  • Notification drawer shortcuts
  • Hide carrier label on notification drawer
  • Wifi access point is shown in notification drawer
  • Easy full swipe access between notification drawer and quicksettings
  • Quick pulldown for quick settings
  • Quick settings style options
  • Battery icon the new slim way reflected on quicksettings as well
  • Full Clock and date customization on status bar
  • Statusbar brightness control
  • Fully revamped navigation bar and navigation ring customizations much more ehanced to 4.3
  • Fully global menu customization the new way
  • SlimCenter
  • Mute Volume adjust sound
  • Ascending ringtone
  • Quiet hours new extended version
  • Mute Camera shutter sound
  • Control safe headset warning
  • Volume rocker music control
  • Less frequent notification sounds
  • Power connectivity alert
  • Fully customizable volume panel
  • Display rotation options
  • Fully customizable auto brightness hysterese
  • CRT animation the new way with new animation as well
  • Notification light options
  • Battery light options if device supports it
  • Volume rocker wake
  • Wake up on charge
  • Slims full customizable low battery warning
  • Enable/disable camera widget on lockscreen
  • Enable carousel animation on lockscreen
  • disable initial page hints on lockscreen
  • start widgets maximized on lockscreen
  • Fully revamped lockscreen target options
  • Lockscreen shortcuts
  • Lock before unlock the new way
  • Pattern size customizing
  • Systemwide blacklist support for calls and sms/mms
  • Slims Privacy Guard the new way
  • Auto keyboard rotation feature
  • Disable fullscreen keyboard
  • IME selector notification
  • Show permanent enter key on keyboard
  • Volume key cursor control
  • SuperUser
  • Mediascanner behaviour on boot
  • Wifi country code
  • Camera smart capture
  • Camera picture quality
  • Camera gps indicator
  • Camera colour filter options
  • Camera complete menu revamp the new way
  • Gallery video smart control
  • SMS/MMS has completly all feature back from 4.3
  • None intrusive incall UI
  • Dialer has all features back from 4.3
  • Torch app
  • System wide immersive mode aka expanded desktop
  • and tons of fixes on google code, revamps on old code, new features and polishing of old features and for sure a lot we still forgot to list here
Changelog Beta 2
klick
Changelog Beta 1.9
klick
Changelog Beta 1.6
  • update to 4.4.2
  • major cleanup on googles code
  • Quiet hours refactor and ringer mode
  • Slim lockhandle configurable
  • fix possible NPE on back button
  • fix statusbar background transition in certain cases
  • add for talkback content descriptions to navbar for ppl which are not able to see
  • fix notifications cut off on slim dpi
  • optimizing on image drawable handling
  • allow to disable QuickSettings completly
  • better Dialog handling on some places in Settings
  • show help dialog the first time the user enter a feature screen
  • fix keyboard crash on suggestions
  • music tile configuration options
  • battery tile new click/longpress behaviour
  • update NovaLauncher
  • update SlimIRC
  • a lot upstream and fixes over all devices
  • a bunch of optimizing and fixes in the base
Wenn Ihr von einen anderen Rom bzw. Stock Rom kommt:
1. Lade und speicher die aktuelle Beta im internen Speicher
2. boote ins Custom Recovery
3. Mach ein NANDROID-Backup des aktuellen ROMS!
4. Fullwipe (Data Wipe und Factory Reset) !!! ACHTUNG: Alle Einstellungen und Daten werden gelöscht !!!
5. Flashe die Beta
6. Flashe die Gapps
7. Reboot
Upgrade von einer früheren Version
1. neue Version herunterladen
2. bootet ins Custom Recovery
3. Flashe die neue Version (evtl. auch neue Gapps)
4. Reboot
Original XDA-Thread
SlimRoms-Homepage
Reaktionen: slayer111, Turcin, copagrindin und 2 andere
GEIL! Von SlimRom 4,4! War immer mehr als zufrieden mit den Roms!
Der ursprüngliche Beitrag von 19:51 Uhr wurde um 21:19 Uhr ergänzt:
Konnte folgende Version weder mit CWM noch mit TWRP flashen ?!?!
Downloads - d802
Was passiert denn?
Bekomme eine Fehlermeldung...
Wüsste jetzt nicht was ich da falsch gemacht haben soll.
Gerade CM 10.2 drüber geflasht, ohne probleme!?
Direkt beim Flashen? Nimmst Du vielleicht ein älteres Recovery? CM11 kann man z. B. auch erst ab TWRP 2.6.3.3 installieren.
Diese Meldung kommt...
Habe es wie im TWRP Thread beschrieben, mit der 1. Variante geflasht. es handelt sich hier um die 2.6.3.2 Version also nicht die neuste.
Vielleicht liegt es daran.
Dann probier es bitte mit dem TWRP 2.6.3.4
Sehe jetzt im offiziellen Thread allerdings nur die 2.6.3.3 Version??
Hat nun funktioniert mit der neusten Version von TWRP (v2.6.3.4).
Sollte man dazu schreiben!!
Der ursprüngliche Beitrag von 22:33 Uhr wurde um 22:37 Uhr ergänzt:
Man kann wohl noch nicht die Pixeldichte einstellen... Finde ich etwas ärgerlich!
Dann hab ich mich irgendwie verflasht? ich glaub ich hab 2.6.3.0 und irgendwie auch erst keine neuere gefunden(jetzt aus dem thread hier ja)
OTG funktionierte nicht,hab ich mir das twrp update gezogen drüber geflasht,otg geht jetzt aber ich hab immer noch die alte Version, komisch.
mal twrp updaten dann probier ich die auch mal
Jo, ist leider noch nicht drin, aber mit Hilfe von Texdroider DPI "nachrüstbar" ;)
Reaktionen: Bollwerk39
Werde die SlimRom jetzt auch mal testen. Auf dem S3/S4 und Nexus 7 hatte ich sie schon mal drauf und war recht angetan davon. Wie ist denn die Kamera bei der Slim?
Läuft wunderbar flüssig, bis jetzt sind mir noch keine Probleme aufgefallen :)
Hätte eine Woche slimkat1.6 getestet und lief ohne Reboots , am Wochenende mal wieder cm drauf und heute wieder Reboots.
Werde am Abend wieder auf Slimkat wechseln.
1.9 ist raus. Langsahm wirds interessant. Ich denke die werde ich auch mal testen
Reaktionen: Interfritz
