[ROM] Pardus HD RoM™ Reborn - Android 4.2.2 für LG G2
  • 128 Antworten
Pendroz
Pendroz
●●●●●●●●●●●● Pardus HD RoM™ Reborn ●●●●●●●●●●●●●
● Based on International UK 10A ( Big Thanks [MENTION=4302669]gh.rohit[/MENTION] )
● Deodexed
● Rooted
● init.d Support
● Busybox Support
● Tweaks for Battery life
● Tweaks for Smoothness
● Tweaks for less lag
● Default LG theme changed to Pardus HD Theme
● Remove All Bloatware
● Removed " Slow charging notification " which pop ups after connecting usb cable
● SuperSU 1.86
● Transparent LG Wheater
● Improved Virtual Memory
● Removed volume and brightness slider
● Disabled Boot sound
● Quickboot
● Update Gapps and libs
● Call record
● Added Nexus 5 sounds
● Custom Bootanimation
● And many more.
[ Full Wipe Only !!! ] Link: PardusHDRomReborn.zip | by Pendroz for G2
MD5 Sum: 51134B8E3D299A89696E1C77D064599B
Thank you in advance for your assistance
Code:
* Connect your LG G2 to your computer via USB port.
* Copy the downloaded file (zip.) On your Sd card.
* Start your mobile Recovery (Press and hold the power button and the volume down low When the LG logo appears,
- Release and again press the same button one second keys. You will be prompted to press the power button 3 times in a row, LG G2 starts in Recovery.
* Perform Wipes (overwrite): wipe data / factory reset, wipe cache partition, advanced \ wipe dalvik cache.
* Install the rom: Install zip \ choose zip from sdcard Install \ zip file.
* Wait for the setup, once the rom installed, select reboot system now.
* Your LG G2 reboots
* Wait 5 minutes for system stability !
Wanam , _Sale_ , Kryten2k35 , Robbie Hood , criscan , IganKuhz , raffaele88 , manikant_009 , Hardcore , Amarullz , AndroidGX , pglmro , LegendK95 , Turkbey , Agabey_42 , CQNSTANT!NE , mike1986 , soroush0313 , indie , raubkatze , _JKay_ , mythtrandyr , anbech , PartimusPrime , anukilimanoor , Chainfire , Winterlove , gh.rohit , Fenhyks , tangjun269 , bigfau , Jank4AU , Jishnu Sur™
An important note !!!
If you want to port or use it in your own roms or mods speak to me first.
This has nothing to do with rom Pardus Linux project - There has not been for commercial activities
Der ursprüngliche Beitrag von 14:28 Uhr wurde um 14:28 Uhr ergänzt:
Reserved...
Reaktionen: kuppenhorst, stöbener, Dodge und 3 andere
Er ist der Dev dieser ROM. Und hat auch im Galaxy S3 Forum einen ähnlichen Thread (auch englischsprachig).
Also ist es kein "reines Kopieren" wenn es von ihm kommt oder? :).
Ob er deutsch kann weiß ich nicht aber die ROM sieht sehr gut aus!
Werde ich mal bei Gelegenheit antesten.
Läuft perfekt.!!!
Gesendet von meinem LG-D802 mit der Android-Hilfe.de App
Bei mir funktionieren die Kamera mods von xda nicht.
ich bekomme es nicht installiert! Weder im TWRP oder im CWM ... hat jemand eine Idee? Bricht ab mt einem Fehler.
Welche Version von TWRP benutzt du?
Habe 2.6.3.4 drauf ....
lies bitte nochmal den Startpost im TWRP Thread. Du brauchst eine ältere Version!
Viele Grüße
Handymeister
Allen noch Frohe Weihnachten. So ganz mit der älteren Version von Trwp stimmt nicht, gestern hatte ich auch es mit 2.6.3.4 version geflasht allerdings zweimal hintereinander.
mit cwm 6.0.4.4 funktionierts einwandfreie. allerdings bekomme ich am Ende des einstellungswizard immer nen FC. passiert sowohl mit cwm als auch mit TWRP.
hatte zuvor die SimRom mit aktiviertem Art. und seit dem hab ich die Probleme bei StockRoms. ob es mir Slim zusammenhängt weis ich nicht.
der ein oder andere hat wohl auch Probleme damit wenn man mal im xda Thread schaut.
Nach knapp 2 Wochen wollte ich mal ein Resume für dieses Rom geben.
Absolut Geniales Rom
Läuft Absolut stable
Akku Laufzeiten sind für meine Verhältnisse Extrem Gut
Leuft Blitzschnell, keine ruckler, keine lags nichts.
Hoffentlich bringt Pardus irgendwann auch ne 4.4.2 Rom raus ( wenn die mal endlich erscheint )
Ich weiß nicht ganz ob die frage dämlich ist :) aber ich frag vorher bevor ich ein Teuren Briefbeschwerer habe.
Und zwar benutze ich Aktuell dieses Rom
[ROM]|4.2.2|D802|Pardus HD RoM™ G-Flex |Fast|Stable|DeBloated|DeOdexed|23.01.2014|
kann man da jeden möglich Custom Kernel vom 802er Flashen ???
zb den von Hell-core ???
ich habe Deinen Post hierher verschoben. Bitte Rückfragen zu den ROMs künftig direkt im jeweiligen Thread stellen.
Viele Grüße
Handymeister
Tja tut mir leid. Bei mir funzt der kernel.
Die neu Version ist raus mit 4.4.2.
Hab sie ca. 2std drauf und bis jetzt sehr gut.
Ich hab sie seit gestern Abend schon drauf, läuft gut. Hatte jedoch einen Softreboot beim hinzufügen eines Widget.
Bei mir geht das ohne Probleme
Hab mehre hinzugefügt und wieder entfernt
