[ROM] CM11 crDroid - Android 4.4.2 für LG G2
  • 25 Antworten
Dodge
Dodge
Dauer-User
672
neue CustomROM, basierend auf CyanogenMOD11 und AOSP mit mehr Extras und Features! :)
Features
HALO
PEEK (Das neue ActiveDisplay)
Quick-Tiles Einstellungen
Eingehender Anruf im Hintergrund
Navbar-Einstellungen
Slim Recents
Volume Steps
Lockscreen Benachrichtigungen
Alle Features
Halo;
Screenshot quick trash;
Power menu QS tile (simple press to go into power dialog or long press to go into reboot dialog);
Power menu added in navring targets;
Incoming call in bakground;
Navigation bar dimensions;
Enable or disable navigation bar;
Low battery warning options;
Lockscreen PIN keypad shuffler;
Lock before unlock (Show sliders before secure unlock);
Notification drawer custom background and transparency;
Notifications row transparency;
Custom clear all recents button (place it in any corner of the screen);
RAM bar;
Option to hide app's status bar notification icons;
Status bar clock and date customization;
Open source Google dialer;
Volume panel configurable timeout;
Screen recorder;
Wakelock blocker;
Media Scanner behavior on boot;
Notification reminder;
Notification reminder flip interval;
Smart Pulldown;
SlimRoms recent panel;
Slim recent with option to show in left side and switch sizes (100, 85 and 70%);
Slim recent add favorite mode (click on app icon in recent panel to choose as favorite);
Ability to switch between recent panel styles (Stock or SlimRoms);
Improved scrolling cache;
Ability to Enable/Disable Smart Wake covers;
Ability to disable hardware keys via nav bar settings (Only visible in devices with hardware keys and enable through overlay);
Keyboard: toggle to enable/disable full screen on landscape;
Keyboard: force auto rotation on IME;
Keyboard: force to show always enter key;
Live volume steps;
Custom navbar recent long press (none, last app, screenshot, kill app, notifications panel, QS panel, power menu);
Long press back to kill configurable timeout;
People lookup settings;
Option to enable notifications with screen on;
SlimRoms Location tile with addition of labels for all states;
Brightness slider in expanded notifications panel;
Option to disable widgets frames on lockscreen;
Lockscreen notifications;
Telo Radio (Connection manager);
Smart call;
Option to show small tiles with text under them;
Gesture lockscreen;
Pause, resume or stop downloads from notification area;
Download
Build 4 d802 vom 22.05
PA GApps
Kitkat-Baseband für AOSP-Custom-ROM
Installationsanleitung
Bei Erstinstallation: (= Clean)
► Installiere Kitkat-Baseband
► Wipe data/Factory Reset
► Installiere ROM
► Installiere GApps
► Neustarten
Bei Update: (= Dirty)
► Installiere ROM
► Neustarten
Danksagungen & Credits
Cristiano Matos
elia222
CM Team
Slim Roms Team
ParanoidAndroid Team
temasek
Omniteam
faux123
show-p1984
kufikugel (Lars Greiss)
myfluxi
neobuddy89
David
Und vielen mehr...
Original Thread
[ROM] [WIP] [4.4.2] [HALO] [CM11] **crDroid** [Build 3] [D800-??] - xda-developers
Github
https://github.com/cristianomatos
ROM-Infos
Anbieter: Cristiano Matos
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.4.x
Basierend auf: AOSP, CyanogenMod
Wie bei jeder ROM gilt auch hier..
weder ich, die xda-devs, noch das Android-Hilfe-Forum ist für jegliche Schäden haftbar,
flashen und benutzen auf eigene Gefahr!
Reaktionen: merhans, DaBeat0, syscrh und eine weitere Person
Läuft super! Bloß hab ich seit der letzen Mahdi das Problem, das mein Neigunssensor nicht mitmachen mag.. :O
Hervorragend, das war's, danke! :)
Wie ist das Rom so?:confused2:
Habs erst seit 10-12 Stunden drauf.. superflüssig, läuft sehr rund, zur Akkuperformance kann ich noch nichts sagen.
Optisch ist es klassisch CM halt, Theme Chooser peppt da schon einiges auf..
Bugs konnte ich bis auf die falsche Baseband nicht feststellen.
ActiveDisplay fehlt, kann aber mit acDisplay (https://play.google.com/store/apps/details?id=com.achep.activedisplay&hl=de) nachgerüstet werden.
Muss ich noch ein Baseband nach flashen?
Und warum genau? Meine funktioniert alles wie es soll.
Mal eine Frage wenn ich G2 anmache geht das ja mit 2x tippen...ausmachen geht bei dem Rom nicht so?:confused2:
Die Baseband beiinhaltet alle Treiber, incl Wifi, Gyro und co.. meine StockRom kam anscheinend mit den Treibern vom CM nicht klar, hat daher den Neigungssensor nicht ansprechen können - ist jetzt aber behoben :)
Also ich bin von dieser hier viel zufriedener wie mit der MahdiROM :thumbup:
Also bis jetzt geht Wifi etc. alles so wie es soll. Kann man das denn nach der Einrichtung noch nachflashen oder nicht so gut?:confused2:
Doch, kannst du nachflashen.. aber wenn alles schon so funktioniert, lass es :) - "never change a running system!"
P900 schrieb:
... ausmachen geht bei dem Rom nicht so?:confused2:
Sorry das hab ich nicht gesehen.. wird nicht klappen, da der Launcher dies unterstützen muss. Aber du kannst die Statusleiste doppeltippen, dann geht das auch!
Einschalten kannst du es unter Einstellungen - Oberfläche - Statusleiste - Standby durch doppeltes Tippen ☑
Wie genau muss man denn tippen will nicht.
auf die Statusleiste, ich habs vorhin probiert.. mittig doppelt getippt, auch wenn die Leiste von der Benachrichtigung runterschaut. Andernfalls würde ich Screen Off and Lock - Android-Apps auf Google Play empfehlen, ist eine gute App mit Verknüpfung im Launcher oder Statusleiste mit vielen Animationen und Effekten.
Wenn ich oben tippe dann öffnet sich immer ein Reminder...tut sich sonst nix.
Screenshot?
Nach Neustart hat es einmal geklappt sonst kommt das.
Achso :) Anscheinend ist das eine Verknüpfung der Uhr/Datum für eine Erinnerung, hast du mal an einer anderen Stelle getippt?
Build 2 ist online!
Downloadlink: Dev-Host - cm-11-20140501-crdroid-build2-d802.zip
Changelog schrieb:
Build 2 - 01.05.14
- Up to date with all CyanogenMod commits until today (May 1 2014 - build time);
- Latest theme manager updates;
- QS extended options (tiles per row - 3, 4 or 5 -- custom background color, custom text color, custom background pressed color, transparency);
- DSP Manager: Center frequency param to bassboost;
- DSP Manager: Stereo widener effect;;
- Made bolt and % text of battery bar icon full black instead of 70%. It's better for the eyes when battery is almost empty;
- PA PEEK (Working as a different option with Lockscreen Notifications);
- Appbar from ChameleonOS;
- Open apps from Appbar in floating window by long pressing;
- Some general fixes in Appbar to avoid JB days when it disappear for unknown reason;
/startpost aktualisiert.
bis jetzt läuft alles TOP :) Vielen Dank für die Rom
