[ROM] CloudyFlex - Android 4.4 für LG G2
  • 605 Antworten
kewkie
Stamm-User
212
Original Thread: [ROM][Jan 27] -=- CloudyFlex 2.2 -=- [D800/D801/D802/D803/F320] - xda-developers
  • Ported from Flex official ROM
  • Stock kernel
  • Odexed, zipaligned
  • Aroma installer
  • SuperSU
  • Busybox + runparts
  • init.d support
  • Removed volume slider
  • Debloated
  • AdAway host file
  • Flex ported camera
  • Latest GApps
  • Fixed vibration strength
    Fixed hissing sound
    Fixed weather widget
    Fixed camcorder issue
    Added fully Knock-Code support (D802/5/6)
    Added more LG theme
    Added G Pro 2 Camera (xdabbeb's 3.1.0 Camera)
    Using CloudyKernel
    Updated GApps
imgur: the simple image sharer
CloudyFlex 2.2 (MD5: 65953c9951272b2577fa4297a7814cde)
Just another Flex ROM? So what's the difference?
- You can get my full answer here. Ofc it's your choice to use it or not.
In the camera app, the onscreen buttons are slightly over the shutter button.
- You must hide front buttons for Camera app like my screenshots. The option's in Setting > Display > Front Touch Buttons
There're some setting menus with corlor issue, why?
- I tried my best to port and rework for all app, but some of them are hardcored into the system so it takes time to figure it out. For now, all of them seem to be working well.
If you find this issue somewhere, just send me a word and give me more detail about it (how and where I can see it).
Why you only include stock kernels?
Why you dont include 2G and flashlight toggles?
- I dont think they're that useful, see here.
I don't want this default navi bar size, can I install other ROM's mod? I think they'll be working well.
- The answser is NO. Dont install that mod from other ROM as it's not only the value to change the navi bar size but also many other system values for that ROM.
They're not fully compatible with this ROM. You're better download avaiable mod in Addons only.
I wanna try some images mod but they're not working with Flex ROMs. How?
- Most Flex ROMs use xhdpi as their main images resource, so you must edit your mod's flashable zip file a little bit (using WinRAR or anything else).
Go to vrtheme\system and change "drawable-xxhdpi" to "drawable-xhdpi" in all sub-folders. It will work.
My variant is VS980 and I really want the ROM. Please help me.
- Its in my todo list but may take time. Right now you can use tangjun's beta patch, it's fully compatible.
If you like my work, you can buy me a Beer
Ein paar persönliche Impressionen meinerseits zu dieser ROM und zur aktuellen Version (v1.1 bzw. 1.2 Beta)
#1
#2
#3
#4
Für alle die, die geil drauf sind :D
Reaktionen: TheMissingLink, paule1234, Andr0le und 7 andere
Hab sie jetzt,nach deiner Empfehlung im anderen Thread,auch mal probiert.Gefällt mir sehr gut.Alles läuft sehr flüssig und stabil.Bin schon sehr gespannt auf die v1.2.Aber eines konnte ich bisher nicht finden.Kann mir jemand sagen,ob,und wenn ja wie,ich den Hintergrund vom Lockscreen ändern kann?
MfG
Soweit ich mich an die flex Einstellungen erinnern kann, kannst du bei dem flex-lockscreen mit Wasser und Himmel den Hintergrund nicht ändern. Geht nur bei dem normalen lockscreen...
Reaktionen: chika
Danke!Du hast mich auf den richtigen Weg gebracht.Man muß bei "Bildschirmsperre auswählen" auf Pin gehen.Da kann man den Hintergrund wechseln.Dann einfach wieder auf die gewünschte Sperre wechseln.
Reaktionen: kewkie
@kewkie
Kannst du helfen das Must Icon für diese ROM anzupassen?
Reicht es aus die zip Datei auf das Handy zu kopieren und dann mit TWRD zu installieren?
Sind die Gapps auch automatisch enthalten?
Alles drin
Hab mal im ersten Post Screenshots eingefügt :)
@bahrosuz sorry hab da nicht so den Plan von.
@Powerschwabe wie schon gesagt ist alles enthalten. Basiert ja auf stock und somit ist gapps enthalten :)
Hat auf dieser Rom schon jemand den Dorimax Kernel getestet?
Bei mir ist sie mit dori 2. 1 im Einsatz. Und bis jetzt keine Probleme, alles funktioniert.
Bei mir läuft der 2.0 von doriman ohne probleme
Und die Beta kann man noch nicht auftreiben? ;)
Nein sorry, der dev hat mich drum gebeten und den will ich da nicht enttäuschen
Überhaupt kein Problem. Da ich soeben unabsichtlich anstatt nen altes Backup zu löschen, ein altes Eingespielt habe xD Habe ich mich entschlossen das hier mal zu testen.
Ich würde nur gerne die NavBar verkleinern, ist das mit G2 Tweaks z.B. möglich oder sollte man es lieber bleiben lassen. Hab das jetzt noch nicht ganz verstanden.
Ich habe die nav bar komplett weg da ich LMT nutze. Und keine Probleme.
Kann mir einer von euch erklären, warum die Empfangsbalken nicht den korrekten Wert anzeigen, bzw in gsam battery 100% niedriger Empfang angezeigt wird?
@ryper: das ist mit der donate Version von g2 exposed möglich...
Oder probiere das mal... https://www.android-hilfe.de/showthread.php?t=484507
@stöbener
hast du einen SS?
Entweder bei dei den addons die gewünschte größe runterladen oder mit G2 Xposed (donate version - kosten waren glaube ich 0,79€ und es lohnt sich definitiv)
Hab aus diesem Grund aktuell keine flex rom installiert. Ich meine, dass kewkie etwas in die Richtung auch mal in einem anderen thread erwähnte...
Ja bei der Rayglobe flex wurde da ein wenig getrickst, da wurden ein paar .png dateien ausgetauscht. Hier bei der CloudyFlex hab ich mir dieselben dateien angeschaut und bisher nichts gefunden.
Hab aber auch bisher nichts diesbzgl. gemerkt.
Bleibt ja auch letztenendes jedem selbst überlassen welche rom er nutzt oder auch nicht :)
Werde mir auch gleich nen backup machen und mal nen paar CM roms durchnehmen.
Reaktionen: stöbener
MB525
reppy
s2i9100
s2i9100
Rivaldo
