Ra1n3R
Ich nutze 7zipper aus dem Playstore. Funktioniert zu 100% und kann man direkt auf der SD im Pad entpacken...
Download:
Download:
#!/system/bin/sh
echo "2048,3072,6144,15360,17920,20480" > /sys/module/lowmemorykiller/parameters/minfree
echo "0" > /proc/sys/net/ipv4/tcp_timestamps
echo "1" > /proc/sys/net/ipv4/tcp_tw_reuse
echo "1" > /proc/sys/net/ipv4/tcp_sack
echo "1" > /proc/sys/net/ipv4/tcp_tw_recycle
echo "1" > /proc/sys/net/ipv4/tcp_window_scaling
echo "5" > /proc/sys/net/ipv4/tcp_keepalive_probes
echo "30" > /proc/sys/net/ipv4/tcp_keepalive_intvl
echo "30" > /proc/sys/net/ipv4/tcp_fin_timeout
echo "404480" > /proc/sys/net/core/wmem_max
echo "404480" > /proc/sys/net/core/rmem_max
echo "256960" > /proc/sys/net/core/rmem_default
echo "256960" > /proc/sys/net/core/wmem_default
echo "4096,16384,404480" > /proc/sys/net/ipv4/tcp_wmem
echo "4096,87380,404480" > /proc/sys/net/ipv4/tcp_rmem
echo "4096" > /proc/sys/vm/min_free_kbytes
echo "0" > /proc/sys/vm/oom_kill_allocating_task
echo "0" > /proc/sys/vm/panic_on_oom;
echo "0" > /proc/sys/vm/laptop_mode;
echo "0" > /proc/sys/vm/swappiness
echo "50" > /proc/sys/vm/vfs_cache_pressure
echo "90" > /proc/sys/vm/dirty_ratio
echo "70" > /proc/sys/vm/dirty_background_ratio
echo "8" > /proc/sys/vm/page-cluster
echo "64000" > /proc/sys/kernel/msgmni
echo "64000" > /proc/sys/kernel/msgmax
echo "10" > /proc/sys/fs/lease-break-time
echo "500,512000,64,2048" > /proc/sys/kernel/sem
echo "500" > /proc/sys/vm/dirty_expire_centisecs
echo "1000" > /proc/sys/vm/dirty_writeback_centisecs
busybox mount -o remount,noatime,noauto_da_alloc,nodiratime,barrier=0,nobh /system
busybox mount -o remount,noatime,noauto_da_alloc,nosuid,nodev,nodiratime,barrier=0,nobh /data
busybox mount -o remount,noatime,noauto_da_alloc,nosuid,nodev,nodiratime,barrier=0,nobh /cache
rm /dev/log/main
echo "sio" > /sys/block/mmcblk0/queue/scheduler
<extended order="11" type="83" label="CUST" size="16384" readonly="false">
<extended order="16" type="83" label="SYSTEM" size="1310720" readonly="true">
<extended order="11" type="83" label="CUST" size="1310720" readonly="true">
<extended order="16" type="83" label="SYSTEM" size="786432" readonly="true">
[B]#Zwingt den Launcher im Speicher zu bleiben[/B]
ro.HOME_APP_ADJ=1
[B]#Erhöht die Bild-Qualität, auf Kosten des Speicherplatzes[/B]
ro.media.enc.jpeg.quality=100
[B]#Vergrößerte Anrufverzögerung [/B]
ro.telephony.call_ring.delay=0
[B]#Je höher die Zahl desto eher reagiert euer Gerät aufs Scrollen[/B]
windowsmgr.max_events_per_sec=150
[B]#Wie oft euer Gerät nach einem Wlan Signal sucht, größerer Wert kann Batterie sparen.(Ich würde ihn auf 3600 stellen)[/B]
wifi.supplicant_scan_interval=180
[B]#Kann die Batterielaufzeit verlängern[/B]
pm.sleep_mode=1
[B]#Ermöglicht wahrscheinlich einen besseren Tief-Schlaf[/B]
ro.ril.disable.power.collapse=0
[B]#Entfernt das debugging Icon von der Anzeige in der Status Bar[/B]
persist.adb.notify=0
[B]#Erhöht die Touchscreenempfindlichkeit[/B]
debug.performance.tuning=1
[B]#1 = Hardware Beschleunigung / 0 gleich aus[/B]
video.accelerate.hw=1
[B]#Erhöht die Qualität der Bilder[/B]
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000
[B]#Verbesserte 3G Datengeschwindigkeit[/B]
ro.ril.hsxpa=2
ro.ril.gprsclass=10
ro.ril.hep=1
ro.ril.enable.dtm=1
ro.ril.hsdpa.category=10
ro.ril.enable.a53=1
ro.ril.enable.3g.prefix=1
ro.ril.hsupa.category=5
[B]#Erhöhte Media & Streaming-Leistung[/B]
net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,16384,256960
[B]#Deaktiviert schwarzen Bildschirm (Problem nach einem Anruf)[/B]
mot.proximity.delay=25
[B]#Verbesserte App-Kompatibilität[/B]
ro.kernel.android.checkjni=0
[B]# Flags[/B]
ro.config.hw_menu_unlockscreen=false
[B]#Verwendet keine Dithering-Oberfläche (verbesserte Bildqualität?)[/B]
persist.sys.use_dithering=0
[B]#Wahrscheinlich schnelleres öffnen von Anwendungen [/B]
dalvik.vm.dexopt-flags=m=v,o=y
[B]#Für Verlust des Dienstes (Scharfschaltverzögerung)[/B]
ro.mot.eri.losalert.delay=1000
[B]#Qualcomm-spezifische Tweaks [/B]
debug.qctwa.statusbar=1
debug.qctwa.perservebuf=1
com.qc.hardware=true
[B]#Um einen Geschwindigkeitsschub zu erhalten[/B]
dalvik.vm.dexopt-flags=v=n,o=v
LeonC68 schrieb:Gut die cust zum flashen ist 4 MB die Partition selbst hat eine Größe von 16 MB da bin ich etwas durcheinander gekommen beim lesen.
LeonC68 schrieb:Aber eines kann ich sagen "ist die beste Rom fürs Mediapad" habe Sie schon vorher auf XDA gefunden und installiert.
wohak schrieb:An Wunder durch neue Firmware mag ich nicht glauben.
Wolfgang
