Comec
Stamm-User
- 420
PopEi schrieb:@Shirocco und alle die es interessiert
Meine Einstellungen zum Benchmarktest
https://www.android-hilfe.de/forum/huawei-mediapad.488/quadrant-bench-werte.247810.html#post-3332361
#!/system/bin/sh
#This is a simple script which allows the user to create .odex files to
#"optimize" dalvik
# Decad3nce
# :D
odexfilesframework=/system/framework/core.odex;
odexfiles=/system/app/Phone.odex;
# Delete dalvik-cache
echo "Clearing dalvik-cache";
rm /data/dalvik-cache/*;
dexopt_core()
if [ -f "$odexfiles" ]
then
echo "Decad3nce Dexopt: .odex files present in /system/app, exiting";
exit;
else if [ -f "$odexfilesframework" ]
then
echo "system/framework already has .odex files, exiting";
exit
else
echo "Decad3nce Dexopt: dexopt-wrapper on framework core java archives, do not interrupt";
dexopt-wrapper /system/framework/core.jar /system/framework/core.odex;
dexopt-wrapper /system/framework/ext.jar /system/framework/ext.odex;
dexopt-wrapper /system/framework/android.policy.jar /system/framework/android.policy.odex;
dexopt-wrapper /system/framework/services.jar /system/framework/services.odex;
fi
fi
dexopt_system()
then
echo "Decad3nce Dexopt: system/app already has .odex files present, exiting";
exit;
else
echo "Decad3nce Dexopt: dexopt-wrapper on system applications, do not interrupt";
for i in /system/app/*.apk
do
odex=`echo $i | sed -e 's/.apk/.odex/g'`
echo "Decad3nce Dexopt: dexopt-wrapper $i $odex"
done
fi
if [[ "${1}" == "FR" ]]
then
dexopt_core;
exit;
else
if [[ "${1}" == "SA" ]]
then
dexopt_system;
exit;
else
if [[ "${1}" == "ALL" ]]
then
dexopt_core;
dexopt_system;
exit;
else
echo "Directions: "
echo "This script allows you to create .odex files"
echo "to optimize dalvik runtime"
echo ""
echo " How to use: "
echo " FR - Framework"
echo " SA - System Apps"
echo " ALL - Framework/System Apps"
echo ""
echo ""
echo " WARNING! WARNING! WARNING!"
echo " DO NOT DEXOPT SYSTEM APPS THEN FRAMEWORK."
echo " ALWAYS DEXOPT FRAMEWORKS THEN SYSTEM"
echo " APPLICATIONS."
echo " WRONG ORDER WILL RESULT IN ANDROID"
echo " RUNTIME ERRORS."
fi
fi
fi
PopEi schrieb:cRom Pop.Com. v.1.0 / Root ~RC~ (23.05.2012) only German by PopEi, based on official German ICS 4.0.3 -- C167B003 release
Änderungen:
Alle Fremdsprachen
-ArabicPack
-BosnianPack
-BulgarianPack
-CangjiePack
-Catalan
-CroatianPack
-CzechPack
-DanishPack
-DutchPack
-EstonianPack
-FarsiPack
-FinnishPack
-FrenchPack
-GreekPack
-Hungarian
-IcelandicPack
-IndonesianPack
-ItalianPack
-JapanesePack
-KoreanPack
-LativianPack
-LithuanianPack
-MacedonianPack
-MalayPack
-NorwegianPack
-PinyinPack
-PolishPack
-PortuguesePack
-RomanianPack
-RussianPack
-SerbianLatinPack
-SlovakPack
-SlovenianPack
-SpanishPack
-SwedishPack
-ThaiPack
-TurkishPack
-UkrainianPack
-VietnamesePack
-ZhuyinPack
-en-GB_kh0_sg.bin
-en-GB_ta.bin
-en-US_lho_sg.bin
-en-US_ta.bin
-es-ES_ta.bin
-es-ES_zl0_sg.bin
-fr-FR_nk0_sg.bin
-fr-FR_ta.bin
-it-IT_cm0_sg.bin
-it-IT_ta.bin
System App:
-Phonesky
-File-ManagerApps
(Original-App) = aus dem Google-Play-Store
-Superuser.apk (Original-App)
-Amazon.apk (Original-App)
-Google Play-Store_v.3.5.19.apk (Original-App) (voll funktionsfähig bei kostenpflichtigen und free Apps)
-host.txt (vorgefertigt)
-Remount.apk (Original-App)
-ES Datei Explorer.apk (Original-App)
-AdAway.apk (Original-App) (Werbungsblocker)
Wenn ihr Probleme mit der AdAway-App habt, dann weil ihr sie schon mal installiert hattet und sie Log-Dateien auf die externe sd-card abgelegt hat, einfach alle Log-Dateien von dort löschen und das Problem ist behoben
Wie man eine externe USB Tastatur mit QWERTY mit englischer Sprache wieder zum laufen bekommt!
Alte löschen und folgende 4 Dateien (klick mich) einfügen unter:
system/usr/keychars/
und den Neustart des Pads nicht vergessen
--Superuser + su by Comec
-init.D Unterstützung by Comec
-Deutsche Tastatur für externe Geräte by ComeccRom Pop.Com. v.1.0 / Root ~RC~
ZippyShare Download
-------Part 1--------Part 2--------
Viel Spaß !
Edit:
>Ich habe die cRom heute noch mal neu hochladen, ich hatte vergessen die Trashordner zu löschen.
Wer die cRom schon drauf hat, einfach unter: cust / den Trash-0 Ordner und unter: system / den Trash-0 Ordner löschen<
LeonC68 schrieb:Hallo Michael,
bitte warte drei Ladezyklen ab.
Das ist bei einem Flash von einer Firmware notwendig, erst danach kannst Du den Akku Verbrauch beurteilen.
Claudia
