HeXtheone
Also ich habe den Fehler nicht mehr seit dem ich auf Paranoid Android 2.57 - 12.01.2013. geupdated habe. Haben jetzt beide eher zuviel Rechte (777) anstatt 775, aber besser als zu wenig.
Paranoid Android 2.57 - 22.01.2013.
Changes:
- Kernel updated to 3.0.60;
- A lot of changes in kernel about gpu, display drivers;
- Working HDMI (picture and audio) - with glitches on homescreen and other apps (a lot of flickerings and shifts/overlapping of images, sometimes a couple of cable plug/unplug helps to stabilize the picture), but with fully normally working video playback;
- Added OTA update via Goo Manager (if i will release any new roms - they will be available directly from goo manager);
- Added auto set of 755 permission to storage/sdcard1 for those who have problem after switching storages.
Working:
- Everything.
Problems:
- Some problems with apps that uses camera;
- Glitches/flickerings/shifting of image via HDMI.
Links:
- Paranoid Android 2.57 - 22.01.2013 (mirror) (or directly from app Goo Manager);
- Kernel with OC possibilities (will be added later);
- Google apps (20121011).
If you want to update from latest cm10/pa rom - you need at first to flash rom, than gapps, than wipe cache+dalvik-cache.
To get working hdmi on latest uploaded cm10 rom you can flash boot.img from this release.
Ich zitiere mal die Upgradeanleitung von Huawei:Aotearoa schrieb:Wie komme ich denn jetzt wieder zu der Huawei Rom?
Hiero schrieb:Pizzamampf das geht hier so nicht, da er TWRP als Recovery hat!
Wiegesagt hier muss erstmal die original Recovery geflasht werden.
