[ROM] X3 ICS CM7 [teammat3] (16.02.2012)
  • 420 Antworten
teammat3
Requires ROOT
Caracteristics:
-Pre-configured (language, region -> DE)
-Completely optimized to Huawei X3
-Free RAM : 80mb - 100mb (it does not matter the ammount of memory available, but yet, the way it is processed)
-Based on benru ROM, with MANY modifications, on build.prop, library files, etc..
-Android 2.3.7
-Rádio,Bluetooth, WI-FI working perfectly
-ROM with overclock
-Gmail, Market
-No-frills CPU Control
-Browser Original replaced with Dolphin Browser MINI
-Documents-to-go included
-All-Backup 3.0
-Titanium Backup
-Deleted many original apps that, for me, are dispensible, and have some better substitutes on Android Market
-Boot Animation Changed (ICS)
- All interface is ICS skinned.
- ICS Animations
- Status-bar tweaked
- 2 ICS Ringtones added
- Android market working
- PlayerPro replaced by Winamp (legal discussion) - 16.02.2012
- LauncherPro replaced by ZeamLauncher - 16.02.2012
- Many system icons changed to fit ICS freshness- 16.02.2012
- Memory improved - 16.02.2012
- ZeamLauncher AppDrawer icon changed (ICS) - 16.02.2012
- StatusBar edited - 16.02.2012
- Many build.prop lines edited e addded. (Reviewed all lines and tested many settings) - 16.02.2012
- Now, all ringtones included ring more than once. - 16.02.2012
- Some more fonts changed - 16.02.2012
- Some framework icons changed. - 16.02.2012
- Now only one version - 16.02.2012
- Some more bugs fixed - 16.02.2012
Quadrant Test (748 mhz) - 16.02.2012
Screenshots (this are on portuguese language, but the download provided is on German.)
Instructions:
1- Do all backups (contact, messages, etc..)
2- Turn off phone
3- Turn phone on by pressing the VOL+ button with the energy button at the same time.
4- Mount and storage
5- Format Boot, Format Cache, Format Data e Format System.
6- Back to the Recovery Clockwork main menu and select Install zip from sdcard
7- Select the first choice and search for X3 ICS CM7 [teammat3].zip on your sd card
8- Reboot system
16.02.2012 DOWNLOAD
Please give some feedback so WE can make this, one of the best costumized roms for our phone!
Reaktionen: MegaTheLance, a.w.labadi, apfelquark und 39 andere
Great, do this ROM any irreversible changes on my X3? I mean formating partition etc.
Can i return to stockrom without any problems?
thanks a lot!
wie sichert man kontakte und apps ?
Normal mit der App Gesamtsicherung (AllBackup) ist beim x3 standard drauf! Ist auch in dieser ROM enthalten!
das funktioniert mit der App bei mir nie...
Wie läuft die Rom? Gibts Probleme?
War so neugierig das ich sie gleich mal ausprobieren musste und ich muss sagen biss jetz keine Nachteile entdeckt, nur Vorteile Grafisch alles top Geschwindigkeit ist auch Top *freu freu*
edit: habe jetz auch keine probleme mehr mit der tastatur das P funzt wie es soll ^^
Installation hakte bei mir etwas.
Also nochmal gewipt und installiert und nach Neustart wurde dann auch die SD-Karte gemountet.
So rein gefühlt ist das die bisher schnellste Rom:thumbsup:
GPS-Fix war nach etwa 15 sec :).
Auch der Touchscreen funzt anscheinend etwas besser.
Bisher habe auch ich noch keine Probleme entdeckt.
Installation nach Anleitung, hat wunderbar und schnell geklappt. Touch ist super, alles läuft sehr flüssig.
Bisher zusammen mit der EclipseRom die beste.
Fehler habe ich bisher auch noch keine gefunden.
Aber noch ne Frage: Kann ich die Transparenz der Notificationsbar ändern?
Die ist oben ja quasi voll transparent, da sieht man eigentlich kaum was.
Gleich mal installiert und Total überrascht
Geschwindigkeit ist Echt unglaublich gestiegen im gegensatz zu dem Benru Release
Installation war problemlos und zugig
Geniales Release =)
Reaktionen: ideoshermano
Hat jemand das zurück Flashen probiert? Hab im Script für die Installation nämlich ein Format boot gesehen.
Kann jemand sagen ob es sich problemlos zurück flashen lässt?
This is the best ROM I ever used on this machine!!!!
Great!!!!!
Thanks for Your effort!!!!
maybe you can adjust the fingerprint of the original in build.prop ;-)
Code:
ro.build.fingerprint=Huawei/U8510/hwu8510:2.3.3/HuaweiU8510/C169B831:user/ota-rel-keys,release-keys
GOOD WORK ^^
Fast, so great! ^^
Habt ihr auch eine transparente energieleiste? Weiß nicht wo ich das abstellen kann...
ja hab ich auch, hab auch schonne seite vorne dran danach gefragt. das einzige manko bisher
Sehr schnelle rom!
Falls einer den Statusbar Hintergrund in schwarz und geänderte off icons haben will, kann er diese SystemUi.apk benutzen.
Könntest du villeicht eine update.zip mit den stock browser erstellen?
Die Browser.apk macht nur force close.
  • SystemUI.apk
Reaktionen: surferla und silver surfer
einfach aus einem Dateibrowser installieren oder über CMW?
Einfach die vorhandene apk in /system/app mit einem dateimanager überschreiben und neustarten.
ok werd ich machen
edit: gemacht, nach neustart ist gar keine leiste mehr da
zum glück hab ich vorm überschreiben die originale umbenannt...
Gib der app die benötigten permissions oder push das einfach via adb bei mir klappts.
ok geht, danke
O
OldCat
O
schnueppi
schnueppi
schnueppi
fenie
