morpheus620
Android-Guru
- 2.561
Seit gestern gibt es eine AOKP ROM von pirrat aus dem 4PDA Forum.
Deep Sleep geht und auch alles andere.
Biite mal testen ob die Sprache deutsch dabei ist.
Changelog:
Installation:
Download:
http://www.mediafire.com/?g7sika6ea476r1k
Dolby Sound:
http://www.mediafire.com/?i2t9u7mpv37qct5
Bravia Engine:
siehe Anhang
Changelog:
Leider schlecht übersetzt von Google
New firmware AOKP, from our Chinese friends. CM10 basis (4.1.2)
1.Vychistil Chinese junk
2.Ispravil installation script.
3.Ispravil camera (no video filmed in 1080p) Keine Videos in 1080p möglich.
4.Ispravil sound.
5.Po default language is Russian.
6.Dobavil GAPS.
7.Dobavit Deep Sleep
8.Ostalnoe small things.
4.Ispravil sound.
6.Dobavil GAPS.
Installation:
1. Reboot in Recovery (Volume + button and On.)
2. do:
wipe data / factory reset
wipe cache partition
advanced / Wipe Dalvik Cache
format system
format cust
3. Go back to the main menu and select the item Install zip from sdcard - choose zip from sdcard - and select the firmware that you got rid of the root of the card.
4. Not what we do not touch, waiting for the end of the installation process.
5. We go to the main menu and select Reboot system now
2. do:
format system
format cust
Download:
Dolby Sound:
Bravia Engine:
siehe Anhang
