Hen Ry
Enthusiast
- 1.687
ErykineMT7 v1.1.0 - MT7-L09-L10 B137SP03 · KK-4.4.2
l MULTILANGUAGE l
jetzt mit/cust/hw/eu
Download: Mega
Changelog:
ErykineMT7 v1.0.0 - Basierend auf Stock B137SP03 - 4.4.2`
l MULTILANGUAGE l
Download: Mega
Features:
l MULTILANGUAGE l
Download: Mega
Changelog:
ChangeLog ErykineMT7
1.1.0:
1.1.0:
- Fixed settings LTE selection (maybe you have to delete settings data or Wipe data/factory to bring it back with 1.1.0)
- Re.edit animations for smooth sense between apps
- Changed dpi by default to 440 (it requires a reboot after 20 min first boot). To go back to 480 dpi, edit with some editor /system/build.prop to 480dpi, select 480dpi theme and reboot
- New theme Aurora created by me and based on other ones (thanks a busywait, Mix_BbN, iconfans, , fooox3 and maybe more people I forget now), edited things on theme that don't fit, or don't like.
- Edited nav bar theme images to 440dpi
- Modded lowmemorykiller settings to leave a bit more free ram
- Modified CPU and governor settings to get some more performance when screen is on.
- Enabled 8 cores with screen on and only 4 with screen off (battery saving with screen off)
- Try to fix dualsim settings to make it working on MT7-L10, but the most probably is dualsim not working on L10, only 1 sim as the base is for L09.
- Droping cachés+more free ram with screen off.
- Changed I/O scheduler to deadline and tweaked to performance.
- Modified appdrawer box with more apps to 440dpi
- Zipalign
l MULTILANGUAGE l
Download: Mega
Features:
Based on official stock ROM release: B137SP03
- Kernel stock 3.10.30 -00246-g907f1ad-dirty
- Rooted with SuperSU incuded - (Thanks to chainfire)
- Android L Themed by default... Based on Shape mod theme by papaver (thanks him) and modified by me to change some things I didn't like.
- AppDrawer included, no need to install a new lancher, having all features of EMUI, modified by me to get stylish drawer (thanks to JakedUp)
- Gapps Included (Gmail, GooglePlay, Maps, etc...)
- Optimized (tweaks) to get the best performance/battery.
- Tweaks scheduler, I/O, VirtualMemory and CPU
- LITED ROM, deleted unusable stuff and apps.
- init.d support
- Busybox support
- Sqlite3 support
- GPU 2D acceleration enabled by default.
- Decreased vm.heapsize to get better multitasking performance
- Other changes in build.prop
- Retouched animations scaling to get a smooth sense.
- More customizations and things included.
- Polaris Office
- Some other settings and files to get it fully working (thanks to KangVIP)
- Zipaligned
wie das wohl kommt?
