[ROM][WFSDev] .sense [SENSE 3.5 zero][CODE: FREEFIRE][Beta 3]
  • 230 Antworten
ONeill
ONeill
Ehrenmitglied
6.091
Hallo Leute,
wieder einmal gibt es nun ein Sense 3.5 Rom. Diesmal von einem Mitglied des Wildfire S Dev Teams (WFSDev).
Der Entwickler hört im xda-forum auf den Namen benjamingwynn
Das ROM findet Ihr bei xda hier:
[WFSDEV][ROM][SENSE 3.5][WIP][TESTING] ".sense" - xda-developers
CODENAME: FREEFIRE
Was ist .sense?
Ein stabiles HTC Wildfire S und HTC Salse Rom. Es basiert auf dem HTC Explorer RUU und ist übertaktet.
Was beinhaltet das Rom?
Sense 3.5 core vom Explorer
ICS Wallpapers *unique to .sense*
ICS Ringtones/Notifications und sense ringtones *unique to .sense*
ICS Music app *unique to .sense*
MIUI Camera *unique to .sense*
Option zu original HTC theme genauso wie dotAURA *unique to .sense*
Screenshot feature (new)
Install to SD or internal feature (new)
Extended Quick Settings and Power Menu (new)
ICS fonts
No boot sound
ICS/Galaxy Nexus boot animation
Overclockable to 806mhz. (that's over 25% faster)*
Ram tweak to make .sense smoother and up to twice as fast
Less power consuming
Mobile brava engine for higher quality video playback
DATA2SD compatible / link2sd support pre-installed
New, faster Android Market (3.4.4)
Ad-free
Pre-Rooted
No HTC/Network junk
Full flash player
Deodexed and zipalined
Gingerbread keyboard and HTC keyboard
Nitrolag System for speed
XDA free pre-installed
Overglow effect
New (nice, black) down animation
Creadits
for providing useful sources
idogx
i needed to borrow some lib's from his ROM
m1ndh4x8r
overclockable kernel and data2sd installer
BigBearEvo
help with salsa support and mirrors
kanded
HTC
for making such a great UI as Sense
Google
android is open source.. give credit!
Everybody working on MIUI
music and camera apps
Everybody who worked on the UOT kitchen
over glow effect and percent battery
fshami
"borrowed" his init.d folder from his ROM for salsa support
orgoth
letting me borrow his server for direct link hosting
ONeill123
Resource site for .sense bug management, aroma installer script
Hintay
Language packages
Wie sieht .sense aus?
Problemlösungen
1. Wer das Problem hat, dass das Rom nicht startet, hat ein probierfreudiger XDA-User folgende Lösung gefunden, die bereits TheSolving erfolgreich getestet hat:
1. Installiert das Rom wie gewohnt, aber noch nicht starten!!!
2. Installiert danach folgende zip (Kernel): [Kernel] Euro 2.3.5 GB OverClock 806 MHz Kernel [6,1,2012] - xda-developers
3. Macht einen FullWipe
4. Startet das Rom normal :)
Changelog
Beta 3.0
- Bugfixes
- Beats audio bootanimation hinzugefügt
- "interessante" bootanimation hinzugefügt
- MIUI bootanimation hinzugefügt
- Kernel werden nun automatisch richtig geflasht (Easy install)
- WLAN gefixt
- Watermark on Salsa entfernt
- Updated Google Play (Android Market)
- Schwarzer Lockscreenring hinzugefügt (credit to BigBearEvo for making this)
- folgende Launcher können installiert werden (credit to BigBearEvo for the icons)
L 360 Launcher
L ADW.Launcher
L Go Launcher EX
L MIUI Launcher
L MXHome
L Launcher 7
L Zeam Launcher
L Balancer Launcher
L Regina 3D Launcher
L Stock Gingerbread Launcher
L QQLauncherPro
L Helix Launcher
- folgende MIUI Apps können installiert werden (credit to Henry_01)
L MIUI Compass
L MIUI Sound Recorder
L MIUI Music
L MIUI Gallery
Beta 2.0.1
- Fixed kein Boot
- Updated einige Kernel
- Fixed viele bugs
- busybox wird nun zum mounten und unmounten verwendet
- Updated AROMA
- build.prop tweaks und "aufgeräumter"
Beta 2.0
- Theme changer in AROMA hinzugefügt
- Pico support hinzugefügt
- Hero support hinzugefügt
- Heroc support hinzugefügt
- legend support hinzugefügt
- Liberty support hinzugefügt
- verbessterter marvelc support
- DATA2SD (finally!)
- Fixed Übersetzungen (French, German, Italian, etc.)
- europäische APK's werden verwendet
- Experimental options screen
- Nur supportete Kernel im Auswahlmenü
- Fixed swipe down lock
- Flashlight wird nun richtig installiert
- MIUI Datei Manager hinzugefügt
- Sense 4.0 Lockscreen hinzugefügt
- Neuere und bessere YouTube version
- Sense 4.0 Uhr Widget
- Geschwindigkeitstweaks
- CM7 Theme hinzugefügt
- Honeysense entfernt (vorerst)
- Passwortdialog im Browser nun richtig
- Gingerbread tastatur nun ohne "Schließen erzwingen" Fehler
- neues, besseres Arome design
- Grammatikalische Fehler behoben
- 3D Rosie entfernt
- neuere AROMA manifest binary
- Salsa Telefone werden nun auch als Salsa erkannt ;)
- HTC Tastatur ohne Probleme
- neuer Update link in GooManager
- Google Play Store anstelle von market
- NoThrillsCPU link fix in aroma
Beta 1.3
- Added Rosie 3D launcher from Sense 3.0 (seen on sensation, etc.) (may not work and could cause bootloops)
- DSP Equalizer should be fixed now
- OTA Updates fixed
- Fixed a bug where the Beats audio mod would extract into the wrong place when installing DSP as well
- Added Sense 2.1 camera
- Added Sense 2.1 music
- Added some experimental features including sense 2.1 widgets
- Added Cyanogenmod 7 music
- Fixed Sense 2.1 lockscreen
- Fixed major issue with Widgets false installing
- Re-coded honeysense theme in to flash correctly
- Moved framework.apk to the default system directory to fix some device bugs.
- Moved Gingerbread keyboard to it's rightful place
- Added "better facebook"
- Moved device cores to a new "devicesupport" folder
- More little bug fixes that were annoying me and others
Beta 1.2
- New install screen for what phone you have in aroma to make things less complex
- Cleaned up kernels and put them into there own folder
- Option for honeysense theme (by me)
- Removed HTC Updater
- Added option for Honeybread boot animation
- Loads of script fixes
- Fixed some bugs in script (nothing noticeable)
- Added option for users to not have OTA updates for .sense
- Fixed generic HTC bootanimation
- Added option for beats audio and a new audio mods section
- New option for stock android boot
- Fixed Sense music FC (thanks to ONeill123 for pointing this out and providing the required files)
- Fixed wrongly labelled *2sd mods
- Fixed account sync bug in settings
- Fixed salsa users sometimes reporting as having a HTC Wildfire S
- Made a new section for keyboards, although there are no actual keyboards except for HTC are listed
Beta 1
- AROMA Installationsassitenten hinzugefügt
- unzählige Mods und Tweaks hinzugefügt
- Salsa wird nun besser unterstützt
- Rom nun für Marvel, Marvelc und Salsa
- OTA-Support for Sense <------------ bisher bei kaum einem anderen Rom!
- beinhaltet nun 3 Kernel
Alpha 2
- Added loads of languages (unter anderem auch deutsch)
- Mostly European based
- Added glass theme
- Updated kernel
- Better support for "*M" Radio's
Alpha 1
- Sense 3.5 Kernel aktualisiert
- 3d gingerbread gallerie hinzugefügt
- ICS Music App
- Extended Quick settings und advanced power menü hinzugefügt
- Fehler beseitigt
- 600mhz default taktrate
- HTC Salsa support
- 5x4 App drawer in Rosie hinzugefügt (mehr technisch gesehen ;))
- Neue speed tweaks
- EXT4 Support
- Batterieanzeige in Prozent und blaues overglow hinzugefpgt (thanks UOT kitchen!)
- black down animation hinzugefügt (das beim ausschalten)
Bekannte Probleme
bisher keine gravierenden ;)
Download
Beta 3:
Nutzt bitte die Downloadsite von:
http://goo.im/devs/benjamingwynn/dotsense/dot_sense_beta_v3.0
Beta 2.0.1:
Goo-inside.me Downloads - Downloading dot_sense_beta_universal_v2.0.1.zip
Beta 1.3
Goo-inside.me Downloads - Downloading dot_sense_beta_universal_v1.3.zip
Beta 1.2:
Goo-inside.me Downloads - Downloading dot_sense_beta_universal_v1.2.zip
Beta 1:
Goo-inside.me Downloads - Downloading dot_sense_beta_universal_v1.1.zip
Alpha 2:
http://shq-systems.eu/dot_sense_alpha_marvel_v2.zip
Alpha 1:
http://shq-systems.eu/dot_sense_alpha_marvel.zip
will ja nicht meckern... okey will ich doch! :p
Bitte füge deinem Thread noch bitte die Changelog, aktuelle Fehler so wie die Bilder aus dem XDA-Thread hinzu. Das macht das ganze Optisch auf jedenfall schöner und jeder weiß direkt was einen erwartet.
Da du ja im WFSDev bist wirst du ja den Thread auf dem laufenden halten und denke deshalb machen die Sachen auch Sinn.
Ansonsten bin ich super gespannt auf die Rom :) aber hab erst seit einer Woche JxMatteo - ROM - V1.1 drauf und warte noch bis die Sense 3.5 Roms stabil laufen bzw einige Tage von Usern bestätigt worden sind.
grüße
Danke garnett, habe ich vergessen, ist nun hinzugefügt :)
Auch wenn ich vom Team bin, habe ich nur begrenzt zeit ;) Werde aber mein bestes geben. Was ich dir aber sagen kann ist, das die bisherigen Sense 3.5 Roms, also der hier und der von Matteo, sehr stabil laufen und man nur die Verbesserungen durch sense 3.5 merkt, außer das die sprache englisch ist.
Danke für dein Feedback :) du machst mir damit die Entscheidung allerdings nicht leichter mich erstmal über meine JX Rom 1.1 zu freuen und dabei zu bleiben :-D.
Aktuell bin ich noch mit dem Wildfire meiner Freundin beschäftigt und darf mich zum erstenmal mit UOT-Kitchen rumschlagen aber dann werde ich mal weiter sehen ;-)
grüße
Garnett
PS: Die Knowing Bugs fehlen noch... damit kann man ja vor allem vermeiden dass die Fehler unnötigt auffüllen und sich dann evtl. ständig wiederholen :)
[Wildfire S]
Zuerst eimmal mein Lob! Sieht wirklich toll aus im Vergleich zu Cyanogenmod 7.
Aber ich habe da so ein Problem. Und zwar immer wenn ich mein Handy aufdrehen will passiert nichts.
Also schon der HTC Bootscreen aber weiter komm ich dann halt nicht.
Ich hab es bisher nur einmal geschafft es zu booten aber ist mir nach ca. 1 Stunde abgestürzt und auch der Start hat fast 1 Stunde gedauert.
Weiß da jemand was es da haben könnte?
Gewipt habe ich vorher alles.
Wäre toll wenn mir wer helfen könnte weil ich finde das ROM echt super! :)
Wipe nochmal die daten, den cache und unter den advanced options den dalvik cache. Dann lädst du dir die alpha noch mal neu runter und installierst nochmal.
Gesendet mit meinen notorisch klein schreibenden Fingern von mrinem HTC aus gesendet.
Ne sorry funktioniert leider nicht :(
Sonst eine Idee was das Problem sein könnte ?
Weil ich ich will jetz endlich wieder Sense haben weil CM7 hat ja auch wieder nicht die beste Grafik.
Bzw. kann du mir sagen wo ich ein gerootetes Stock Rom für mein Wildfire S herbekomme? Hab schon einiges gegooglt aber ich find einfach nix.
Gleich mal Danke im Vorhinein.
Das du da nichts findest glaube ich nicht. Es gibt so viele Roms, die auf dem StockRom basieren und wo schon viel verändert wurde.
Wenn alles nichts hilft, holst du dir halt den Wildfire S Auto-Installer und kannst dann das System weiderherstellen zum Stock und nutzt dann auch gleich diese Anleitung in dem Installer zum Rooten dieses StockRoms.
Zu finden sind die Auto-Installers hier:
Login WFSDev Resource
Leider musst du dich allerdings erst registreieren.
Reaktionen: Faria97
hallo
sehe ich das richtig das es nun in der Alpha 2 version auch mehrer Sprachen gibt?
hat die schon jemand drauf?
Das siehst du richtig. Bin gerade am installieren. Wenn alles glatt gelaufen ist, ist jetzt auch deutsch mit oben.
Werde gleich den Thread aktualisieren.
ich habe ein Teil meiner SD-Karte auf ext3 formatiert
kommt dieses rom auch damit zurecht?
Jap, das ist kein Problem. Du müsstest allerdings deine apps mit titanium backup oder mybackup sichern und dann im neuen Rom wiederherstellen und erneut auf die ext-Partition verschieben, da die Links nicht mit in das neue Rom übernommen werden können (in gar keinem um das mal anzumerken ;))
ja schon klar
kannst mir auch sagen wie ich die dann auf die EXT3 verschiebe ?
bei CM7 geht das ja mit s2e
das geht ganz einfach mit link2sd (im Market erhältlich ;)). DOrt kannst adu auch das Mountscript erstellen und die Apps auch automatisch verschieben lassen.
Dazu reicht dann auch Basiswissen und Google :)
wollte eben "dot_sense_alpha_marvel_v2.zip" installieren. Habe es mit Rom Manager versucht, daten, cache und dalvik cache gewiped, aber nun dies:
AROMA INSTALLER Finished...
E:Error in /sdcard/dot_sense_alpha_marvel_v2.zip
(Status 0)
Installation abortet.
Kann mir dabei jemand helfen, oder sagen was ich falsch gemacht habe??
Danke!
gleiches problem habe ich auch
Hallo ONeill,
Aroma sagt OK, dann starte ich das Rom, aber es erscheint nur das grüne HTC-Logo auf weißem Hintergrund und das war's.??
Hmm, auch schon neu heruntergeladen von 4shared? Die zip habe ich verwendet.
Ich werde mich mal mit dem Dev in Verbindung setzen und ihn davon unterrichten.
DANKE FÜR DIE INFO!
Also mit dem neuen Downloadlink von dir hat es bei mir nun geklappt
leather-face
leather-face
leather-face
leather-face
leather-face
leather-face
