TheSolving
- 4
hei Leute, schaut euch mal das Rom hier an, ich finds eingentlich ganz cool, auch wenn es noch ne Beta ist und noch nicht alles zu 100% läuft
Screenshots sind im Anghang!
original Post:
[ROM]TrianaDroid v0.8 [WIP][ICS/GB][DATA2SD][GAPPS] - xda-developers
wie installiere ich das Rom?:
1. über Cusom Recovery ein Backup machen
2. ext Partion erstellen (Recovery --> advanced --> Partiton SD Card) (Größe: 1GB, Swap: 0)
3. SD-Karte mounten und Rom auf die SD-Karte laden
4. Full Wipe machen (Wipe Data/Factory Reset, Wipe cache Partiton, Mounts and Storage Menü --> format /sd-ext und advanced --> Wipe Dalvik cache)
5. auf "install .zip from SD" und das Rom auswählen
6. Reboot System now
was noch nicht 100% arbeitet :
- Failure forced closed the first time you try to change some of the launcher, try again, and you allow it.
- SWAP partition does not work.
- When it locks and unlocks the drawer is in applications, this is dropped.
- Can not delete icons dockbar.
Updates:
v0.5
- Changes in the Settings application
- Some default values changed in the application "SettingsProvider".
- First release in HTCMania
v0.6
- Added 15 new icons of ICS (Messages, Browser, Settings, Calls,
Music, Video, Search, 3D Gallery, Downloads, Contacts, Camera, Email,
Calculator, Calendar)
- Modified the lockscreen to resemble that of ICS
- Added application Email
- Removed bootanimation makes it very slow and the ROM is not properly
- Removed application "QuickSearchBox" duplicate
- Small change in the Settings application
v0.7
- Changed the application icon in Settings
- Added Spanish-English dual translation to the Launcher
- Added notification bar ICS
- Updated application ESFileManager
v0.8
- Updated Superuser app.
- Added original ICS messaging app.
- Added original ICS sounds.
- Added ICS text fonts.
- Added music application of ICS.
- Removed Youtube application.
- Removed Maps application.
- Reduced the size of the ROM 20 MB.
- Added keyboard original ICS, with some modifications.
- Added Flash Player.
- Removed keyboard GingerBread.
- Updated binary superuser.
- Fixed text color issues in the notification bar.
- Theming complete ICS.
v0.9
- Fixed problem in the startup configuration that caused FCs.
- Update to Google Android Market Play.
- Updated application GoogleQuickSearchBox.
- Added camera application of ICS.
- Updated application IS FileManager.
- Added GingerBread messaging application.
- Added Calculator ICS.
- Fixed text color problem in the implementation of Bluetooth.
- Changed the icon of the music application.
- Fixed some errors in translation into Spanish.
- Changed some icons.
- Deleted folders resolution images for mobile xhdpi, hdpi and LDPI.
- Added patch to fix problem of slow GPS.
- Added patch for BeatsAudio sound.
- Fixed problem with the black background of the unlock screen.
- Added support for encripctación recoverys to amend.
- Reduced the size of the ROM 2 MB.
Download Links:
TrianaDroid v0.5 >>>>> TrianaDroid v0.5 FINAL(EN).zip
TrianaDroid v0.6 >>>>> TrianaDroid v0.6(EN).zip
TrianaDroid v0.7 >>>>> TrianaDroid v0.7.zip
TrianaDroid v0.8 >>>>> TrianaDroid v0.8.zip
TrianaDroid v0.9 >>>>> TrianaDroid v0.9.zip
original Post:
Updates:
v0.5
v0.6
v0.7
v0.8
v0.9
Download Links:
